Old January 16th, 2005, 22:43   #1
Papachristou
Papachristou's Avatar
Default Sprint 520 vs PP520
i am sure there has been much debate on this subject, but i am going to order injectors after i finish my high pix, but i wanted to hear some of the pro/cons of the sprint520 and pp520's. power gains, economy, reliability etc. thanks in advance
Papachristou is offline   Reply With Quote
Old January 16th, 2005, 22:52   #2
gern_blanston
Fuel Economy: 51/47/40 (Same as the CBR)
Dyno plots with the PP520's -vs- stock are abundant, and there is absolutely NO down side to having 'em. I get the same mileage as before (as long as I keep full-throttle romps down to 2 or 3 a day) I have no smoke, nothing but grins. Easy installation, 20% more power, same fuel economy. It's a no brainer.
gern_blanston is offline   Reply With Quote
Old January 17th, 2005, 01:59   #3
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
Aghghghghghgh! I HATE YOU JP!
I'm getting moditis again
I hold you responsible
nicklockard is offline   Reply With Quote
Old January 17th, 2005, 08:12   #4
gern_blanston
The nice, warm hangar and Mr. Tim's tools are all ready for you to do the install when you get your nozzles, Nick. Come on over and join us on the dark side.
Here's a little motivation for ya': Blue = you, red = me.
Bwaaahahahahahahaha!!!
-ps- I am ignoring the fact that you put a D/G shifter kit in this weekend
Old January 17th, 2005, 10:58   #5
Papachristou
what kind of gains can u expect with the sprint 520's? they are about half the cost of the PP520's
Old January 17th, 2005, 15:55   #6
KERMA
KERMA's Avatar
Expect about 10 hp and 20 ft-lb torque gain over stock with the Sprint520.
Some dynos have shown as high as 112 hp and 215 ft-lb with the PP520 on an otherwise stock car (ALH). Generally, though, you can count on about twice the torque gain and about 5-10 hp more with the powerplus versus sprint over stock ALH injectors.
One downside to the PP520 that "gern" failed to mention is the wait time for the different Powerplus nozzles. Shouldn't be too bad of a wait for the time being, though.
KERMA is offline   Reply With Quote
Old January 17th, 2005, 18:20   #7
gern_blanston
What KERMA isn't mentioning is that although I had to wait about 4 months to get mine,
<font color="red"> IT'S WORTH THE WAIT!! </font>
Old January 17th, 2005, 18:31   #8
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
Default Re: Sprint 520 vs PP520
So if I decided to jump up from Sprints to PPs, the difference would be noticable?
Hmmm.............
mannytranny is offline   Reply With Quote
Old January 17th, 2005, 20:06   #9
DaveC
You should also consider the fact that with PP520 your clutch is much more likely to slip and cause problems.
The clutch in our beloved TDI's is the weak link in the drive train. Getting an aftermarket clutch is expensive and problems are possible with it.
DaveC is offline   Reply With Quote
Old January 17th, 2005, 20:09   #10
gern_blanston
Not too many clutches slipping out there with just the PP520's, are there?
Old January 17th, 2005, 20:56   #11
KERMA
KERMA's Avatar
Hmmm.............
Giuseppe intended the Powerplus 520 to upgrade the TDI 110 with more torque. Those cars come from the factory with 150P520 nozzles (sprint520 equivalent). So, yes.
Old January 17th, 2005, 21:14   #12
KomarekTDI
KomarekTDI's Avatar
Fuel Economy: 54/47/43
I added the PP520's with about 30k miles on an '03 Golf and absolutely love them! I now have 52k miles and have been down the drag strip quite a few times. The only time the clutch has ever slipped was on a REALLY cold morning. I always accelerate pretty hard and look forward to adding the aftermarket clutch so I can go with the PD150 turbo and RC 3.1 chip.
Few other notes about the PP520s: very noticable power increase, MUCH easier to pass on 55mph 2 lane roads, and merging onto 70mph expressways became much more fun. 100mph comes pretty quickly when you roll onto the throttle in 5th (so I heard). Best mod money I have ever spent on a vehicle. Fuel economy really depends on how you drive it. I accelerate pretty hard all the time and still get at least 650 mi / tank and could have easily broken 800 on an all highway tank from Detroit to Maine (my wife needed to stop with 786 miles and the fuel light hadn't come on yet - doh!)
Smoke is also not an issue. I have played with my IQ a little bit and can see a little smoke in the mirrors when there are headlights behind me in the evening. The smoke was a little easier to see after I added a rear-exit exhaust/mufflerectomy but would clear after a second or two of full throttle.
My recommendation - go with the PP520s and invest in the CAT 2 micron fuel filter. I'd do it again in a second. I also highly recommend the Dieselgeek Race Shift kit - these mods greatly improve the fun factor of the car.
KomarekTDI is offline   Reply With Quote
Old January 17th, 2005, 21:20   #13
mannytranny
TDI(s): 02 Jetta
My only concern is with the clutch. Temps here are never below 30, and 99% of the rest of the time, it is much warmer.
How much might a cluch job cost? Im guessing that the VR6 clutch is the only way to go here.....
tx
Old January 17th, 2005, 23:28   #14
nicklockard
Torque Dorque
Here JP, rub some rock salt in it, that sea salt is for wussies!
Oh well, I guess I've got that DG-SS. Nyah nyah nyah nyah
(that was for the bwahahahahahaha!)
****Must.....Resist....the pull of....the DARK FORCE....***
Old January 18th, 2005, 06:41   #15
Papachristou
you guys talked me into it, hopefully i will have my pp520's sooner than 4 months.
Page generated in 0.16406 seconds with 9 queries
[Output: 120.15 Kb. compressed to 99.77 Kb. by saving 20.37 Kb. (16.96%)]
