Old January 12th, 2005, 20:15   #1
fase2006
Fuel Economy: 50/45/43
Default How many quarts of oil does a A4 Jetta TDI take?
I searched, I read my owners manual, and I can't find it.
I've read about the vischsoities, etc, in the FAQ, I got the proper oil, and I don't know how much oil my car takes. I can't find it anywhere.
It's like the unwritten thing that everyone knows.
Please quick response. thank you.
fase2006 is offline   Reply With Quote
Old January 12th, 2005, 20:16   #2
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
4.75
Put 1 gallon in first and check it. That last .75 has a bad habit of not coming out when draining.
POWERSTROKE is offline   Reply With Quote
Old January 12th, 2005, 20:18   #3
fase2006
[censored].
I hate walmart.
They only had 1 container left of 1 gallon of rotella t syntehtic 5w30.
and I wanted to do the change tomorrow. damnit!
If I put in 4 quarts, and only drove for 10 miles or so at 35-40, would I be ok?
Old January 12th, 2005, 20:26   #4
POWERSTROKE
TDI(s): 2002 Golf
[censored].
I hate walmart.
Yes. I bet you put the gallon in and you only have to put less that 1/3 of a quart in to top it up. Some say that 1 gallon is enough. I have found that it takes a little over a gallon, with a full drain. I usually add 4.5 quarts. I let it drain for a while though.
Old January 12th, 2005, 20:33   #5
fase2006
sweet, thank you!
Old January 12th, 2005, 21:21   #6
Philip
watch your measurements, I messed up the quarts/liters when I changed the oil the first time and put in way too much oil.
Philip is offline   Reply With Quote
Old January 12th, 2005, 22:43   #7
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
>>1 container left of 1 gallon of rotella t syntehtic 5w30. <<
Did you mean 5W-40 ??? In the Blue bottle, yes ????
You should be fine with just the 3.7 L (1 US gal.) for a little while... just don't rev the engine too high...
Yuri.
ymz is offline   Reply With Quote
Old January 13th, 2005, 04:08   #8
fase2006
yeah, er, i meant that.
Ok
btw, I paid $12.84 for that at Walmart. Good price or no?
I've been to Napa, another place, and a McLaughlin, none of them have the oil I need. bleh.
Old January 13th, 2005, 04:11   #9
fase2006
Default Re: How many quarts of oil does a A4 Jetta TDI take?
What about a coolant change, where do I get the coolant? (McLaughlin, pep boys, autozone, walmart?)
I'm going to check the FAQ and walkthru's for how to do a coolant change, but if it's not in there, once I drain it, do I have to flush it?
Thank you, I appreciate it. First time ever doing any real maintance to a vehicle. I realized I'd have to take care of the TDI when I got it, and I realized I'd have to learn things. I do read the forums, and I've learned a lot about misclinanious problems, but something as simple as a coolant change leaves me dazzled.
Old January 13th, 2005, 06:06   #10
scooperhsd
Sorry - your VW dealer only (or other places that carry VW's coolant).
scooperhsd is offline   Reply With Quote
Old January 13th, 2005, 06:08   #11
scooperhsd
BTW - what year is your TDI ? If it is a 2004 or later - you need the special VW505.01 oil, and that Shell Rotella doesn't meet that standard yet.
Old January 13th, 2005, 11:02   #12
ymz
>>I paid $12.84 at Walmart<<
The only better price would have been to pick it up at WalMart in New Hampshire... (no sales tax)...
Coolant: G12+ Are you sure you need to change it? Look at your coolant reservoir... is the color nice and cranberry-like? If yes, you're probably fine, and have no need to spend money right now!!
Yuri.
Old January 13th, 2005, 14:03   #13
fase2006
Coolant looks ok,
it looks like a light cranberry color though, but solid. kinda dark out though
Boy the fuel filter is easy to find, wait till the kids in auto see this. We had a nissan pathfinder in a few weeks back, one of the kids parents vehicle, and the fuel filter was a ***** to access, even on the lift, and was strapped in with a flimsy rusty strap with rusty bolts.
I told them my fuel filter was easy to get to, right in my hood, and they called shens.
er, they said i didnt know what i was talking about.
btw, it's a 2000.
Old January 13th, 2005, 21:14   #14
Powder Hound
Powder Hound's Avatar
If you want to get that last 1/2 quart (500 ml) out, then you need some kind of vacuum suction device with a tube such that you can stick it into the small orifice (not the big one in the middle) in the oil filter housing and down about 8-10 inches or so. This will allow you to evacuate the oil cooler, which won't drain any other way.
If you don't clean the cooler out, then you'll only need a gallon of oil for a change.
Powder Hound is online now   Reply With Quote
Old January 14th, 2005, 03:58   #15
fase2006
where is the oil filter, btw? general area, like accessible from the hood or what?
Page generated in 0.17479 seconds with 9 queries
[Output: 115.97 Kb. compressed to 96.04 Kb. by saving 19.93 Kb. (17.19%)]
