Old January 10th, 2005, 17:13   #1
pgdub
Default Vacuum Tube
[image]http://pics.tdiclub.com/showphoto.php?photo=16184[/image]
I was looking at my engine today and noticed that a vacuum tube was dissconnected and couldn't figure out where it connects to. The tube that is dissconnected is circled in green in the photo, and it is in the group of three tubes and is the larger of the three. Van anyone help me locate where this larger vacuum tube connects, the car is a 2001 TDI.
Thanks in advance, PGDub
pgdub is offline   Reply With Quote
Old January 10th, 2005, 17:20   #2
Luv My 02 TDI
Fuel Economy: 52/48/44
Default Re: Vacuum Tube
The one connected to the T connection?
It comes from the T to your Air Filter box?
It goes in the air filter assemply under and behind #4 the MAF.
Do you have about 8 inches of tube hanging out?
Luv My 02 TDI is offline   Reply With Quote
Old January 10th, 2005, 17:38   #3
pgdub
yeah it comes off the "T" fitting, its the larger of the three hoses, where of the filter does it connect?
Old January 10th, 2005, 17:40   #4
pgdub
Yeah there is about 8 inches, "under and behind the number 4", i dont know what the number 4 is?
Old January 10th, 2005, 18:00   #5
Luv My 02 TDI
#4 is the MAF it connects here...
This is looking from the Dirvers Side View Mirror under the HOOD. Its behind the AirFilter BOX.
B I G _ S I Z E Photo
Old January 10th, 2005, 18:09   #6
pgdub
Yes, that is exactly what i was asking about, does it just sit there or does it connect to sumthing, because there is nuthing for it to connect to on my car, so i assume it just sisters there, or do u glue it there or sumthing?
Thanks for help and that picture.
Old January 10th, 2005, 18:11   #7
Luv My 02 TDI
Click on the BIG size.
You will see the END of the Tube and a Little of the PLASTIC part it slides over...
Old January 10th, 2005, 18:13   #8
pgdub
Shoot, i dont have that on my car, mabye it broke off or something, there is no hole there for anything for it either, should i just seal it off with a golf tee or should i leave it open?
Old January 10th, 2005, 18:18   #9
Luv My 02 TDI
No Idea.... My photos are from a 2002...
But are you sure you dont have a hole under the MAF connector?
Old January 10th, 2005, 18:20   #10
pgdub
yeah 100% sure, it seems like the connector was glued there, but it came off somehow, and there is no passage to the airfilter it was just a connector to hold the hose it seems...
Old January 10th, 2005, 18:23   #11
Luv My 02 TDI
Maybe some one else will chime in..
I pulled on my tube and ut was not budging.
I don't want to break it. Does it look as it something was in that location...
Maybe do a search on Air Filter or Air Box and see if any photos or directions for removing it. Might tell a little about that tube.
Old January 10th, 2005, 18:58   #12
Luv My 02 TDI
Well it's bed time I hope you figure this out...
Old January 10th, 2005, 18:59   #13
pgdub
alright thanks for all the help, maybe someone else knows whether or not that the line is supposed to flow through or just be sealed.
Thanks again for all the help.
Old January 10th, 2005, 20:15   #14
MOGolf
MOGolf's Avatar
That line should connect to the air filter box. Do not seal it off. It is supposed to supply filtered air to the control valves for EGR and boost, which those valves use to regulate the EGR and boost by switching between the filtered air and vacuum.
MOGolf is offline   Reply With Quote
Old January 10th, 2005, 20:31   #15
pgdub
do you think it will be a problem if i just leave it hanging out?
Page generated in 0.18620 seconds with 9 queries
[Output: 112.88 Kb. compressed to 93.11 Kb. by saving 19.77 Kb. (17.52%)]
