Old October 18th, 2004, 08:46   #1
RichCA
Default Can\'t resurface dual mass flywheel?
Just as I decided to buy the spec, the performance place that I was going to get install it said:
"Essentially, dual mass flywheels are one-time-use only. We can de-glaze your original dual mass flywheel, but we can not make any sort of guarantee about the longevity of the surface finish, nor can we guarantee against clutch chatter."
Now I'm not sure again what to do. Can anyone tell me my options? Maybe the VR6/G60 combo would be easier?
Incase it matters my car has about 38000 miles on it.
Thanks,
Rich
RichCA is offline   Reply With Quote
Old October 18th, 2004, 08:50   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Rich:
[decoder] "We don't own the equipment to service and re-surface DM flywheels." [/decoder]
Old October 18th, 2004, 08:53   #3
RichCA
That's what I figured. If anyone knows of a place in the Toronto or Niagara area that can resurface it please let me know.
Thanks again,
Rich
Old October 19th, 2004, 05:54   #4
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Why not just go to a salvage yard and get a 228 mm G60 flywheel. It'll bolt on with no problem and I only paid 60 bucks for mine. Not too many cars fail because of a bad flywheel so it's usually pretty safe to get one this way.
Good Luck
Sootman is offline   Reply With Quote
Old October 20th, 2004, 18:55   #5
Big 1
Fuel Economy: 54mpg
I would personally pick up a stage 2 kit from spec.
Big 1 is offline   Reply With Quote
Old October 25th, 2004, 13:03   #6
Sebpt
Sebpt's Avatar
Thanks,
Rich
I have Spec Stage 1 with my 50,000 mi stock flywheel. When I changed my clutch, I just cleaned the flywheel with alcohol. The surface was perfectly flat with no wear at all. No problems at all. I don't know if this would help you but it certainly worked on my car.
Sebpt is offline   Reply With Quote
Old October 28th, 2004, 09:23   #7
TdiAvenger
TdiAvenger's Avatar
228 mm G60 flywheel
can you tell me what this comes on for code noobs
TdiAvenger is offline   Reply With Quote
Old October 28th, 2004, 09:36   #8
Drivbiwire
Zehntes Jahr der Veteran
Get out of the "Old School" line of thinking! The DMF flywheels will not need ANY resurfacing. I have yet to see or even hear of for that matter any flywheel with wear grooves or uneven surfaces.
For the most part all that is needed when installing a higher clamp force clutch on one of these flywheels is simply wiping it off of any dust and maybe rubbing it down with a Scotch Brite pad (green or red) to break the glaze and help bed in the new clutch material...thats it.
If you have the flywheel machined its ruined and the clamp forces are now unknown. The distances between the pressure plate and flywheel are extremely critical in keeping the clutch under optimum pressure.
DB
Old October 28th, 2004, 11:19   #9
jackbombay
jackbombay's Avatar
TDI(s): A4 Jetta
Fuel Economy: 57/43/32
228 mm G60 flywheel
Corrados and A3 jetta's I've been told.
If a dual mass flywheel really does need resurfacing Dan Hall Automotive in Portlan Oregon can resurface them.
-Jack
jackbombay is offline   Reply With Quote
Old October 28th, 2004, 15:40   #10
lam121
Fuel Economy: 40 MPG (avg.)
DB
well let me be the first to tell you. im not sure what else my shuddering can be attributed to besides a 'faulty' clutch disc. i did the spec stage II upgrade in april (yes i did make my flywheel look nice and shinny again). there has been shuddering ever since. i recently had to replace my transmission (bad syncros - nothing to do with the clutch) and my mechanic gave it the once over treatment again because he said he could not find any machine shop in the area to resurface it. (i should have sent it to spec) but there is still shuddering.
it is my understanding that when you change a clutch disc, the new clutch disc has to 'mate' with you old flywheel. that would be the manufacturer's recommended break in period. the old flywheel has 'grooves' that the old disc created and therfore fit nicely in, from spinning your tires, regular wear and tear, whatever. the new disc will not fit into these old grooves. when you resurface, you cut the flywheel flat to have the new disc grip the flywheel and start making itself at home with the flywheel. if you have any input, advice, or even a more correct description of what happens, i would greatly appreciate it.
lam121 is offline   Reply With Quote
Old October 31st, 2004, 11:55   #11
lam121
Page generated in 0.14434 seconds with 9 queries
[Output: 97.39 Kb. compressed to 82.21 Kb. by saving 15.18 Kb. (15.59%)]
