Old October 13th, 2004, 12:48   #1
JettaTDI2000
Default How to Reset Check Engine Light
Hi,
is there a way to reset the Check Engine Light without using speacial tools? I had Auto Zone read the code for me, but they won't reset the light, so I need to do it myself.
JettaTDI2000 is offline   Reply With Quote
Old October 13th, 2004, 13:29   #2
mainer
i belive that you just disconnect your battery
mainer is offline   Reply With Quote
Old October 13th, 2004, 14:02   #3
HopefulFred
HopefulFred's Avatar
Fuel Economy: ~39 USMPG
some of them will go away after some number of starts - it depends on the code and condition (if the condition persists, obviuosly, CEL will too).
The "right" way would be with a VAG tool, but if you had that, you wouldn't have gone to AutoZone would you...
I would bet for a temorary code, disconnecting the battery for a reasonable length time (I think it needs to be more than just a second or two) would speed the process along. Of course, you'd have to reset your radio presets.
HopefulFred is offline   Reply With Quote
Old October 13th, 2004, 14:14   #4
syncroserge
syncroserge's Avatar
Check similarly name thread i.e. "Resetting Check Engine Light???" in this section.
syncroserge is offline   Reply With Quote
Old October 13th, 2004, 18:52   #5
JettaTDI2000
Thank you all! Looks like I am going to have to look for someone in my area with a VAG.
Old October 14th, 2004, 05:36   #6
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
Did you fix the problem? If so, put the key to on position, wait for the glowplug light to turn off, then turn key to off. (don't start the car) Repeat this 3-5 times. Sometimes this will reset the code, as the ECM has then fired up 3-5 times without detecting the problem. Otherwise you will need someone with a Vag-Com to reset the code (which is the better way to do it).
Toronto_Vento is offline   Reply With Quote
Old January 9th, 2005, 14:11   #7
alanmcd
Fuel Economy: 53/48/45
I have a 1999 Jetta TDI with the new body style wiht a check engine light active. I have tried to disconnect the battery and do the trick of turning the key on (5-7 times without turning the engine over) and letting the glow plug light go out. Nothing seems to work to reset the CEL. Any other ideas besides getting it reset with the electronic device? Also, I did not loose my radio presets. The only indications that I noticed was the tripometer reset to "0".
alanmcd is offline   Reply With Quote
Old January 9th, 2005, 18:38   #8
MOGolf
MOGolf's Avatar
Default Re: How to Reset Check Engine Light
alanmcd, you need to (1) find out why the light is on, (2) fix it, then (3) find someone with a software interface that can clear codes. None of the things you tried will ever turn off the light.
MOGolf is offline   Reply With Quote
Old January 10th, 2005, 20:05   #9
BioDzel
JettaTDI, you said Autozone read the code, but won't reset the code for you--can you just borrow the OBDII scanner, take it out to your car, and reset it yourself? That's what I did after installing my RocketChip (which Jeff warned me would cause the CEL to go on).
BioDzel is offline   Reply With Quote
Old January 11th, 2005, 11:48   #10
onehotspud
onehotspud's Avatar
Fuel Economy: 59/45/36
The way that I would get autozone to reset mine is:
1. Ask them to scan and give you code
2. Leave
3. "Fix it"
4. Go back and say that you "Fixed it" and ask them if they will clear it for you
Mine were all glow plug failures. And one MAF failure (I unpluged it and forgot to plug it back in before I started it). Nothing serious. As MOGolf said, if it is a real problem, get it fixed first. Sometimes those codes really are something.
onehotspud is offline   Reply With Quote
Old January 11th, 2005, 12:34   #11
GoFaster
Moderator at Large
Something to re-iterate:
You can NOT turn off the MIL (aka "check engine light") without first ACTUALLY fixing the underlying problem. If you don't fix the underlying problem, it will either not be possible to reset the code, or it will reset temporarily but come back as soon as the fault gets detected again.
As for disconnecting the battery ... this persists from the early days of automotive electronics, even though there are far more vehicles with OBD-II on the road now than there ever were with older systems. On any vehicle with OBD-II, faults are stored in permanent memory. You could disconnect the battery for 1.3 million years, and it will still remember it.
Sometimes fixing the actual fault is easy, sometimes it isn't. I've forgotten to plug in the MAF, too ... that was an easy one.
GoFaster is online now   Reply With Quote
Old May 9th, 2013, 06:56   #12
laserguy
TDI(s): 2001 Jetta
I did the key off an on trick the light went out for how long who knows???
laserguy is offline   Reply With Quote
Old May 9th, 2013, 09:08   #13
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Wink
The light is no a Christmas tree it has a real purpose in life. The question is NOT the light. The real question is why did the light come on.
Fix the real problem then the light will go away and the real problem along with possible damage to your car or our safety.
Joe Meehan
2002 NB Silver Ohio BAA HUM
Joe_Meehan is offline   Reply With Quote
Old May 9th, 2013, 12:06   #14
jettawreck
jettawreck's Avatar
At least for about as long as the problem/issue stays away.....
Get it scanned properly w/VCDS and depending on the code(s) results, get the issue(s) repaired. Or, it'll be back-again and again.
2004 Cadillac SLS (wife's)
Old February 18th, 2015, 18:58   #15
dieselkid96
What if the CEL is related to a complete egr delete and a true straight pipe exhaust, is there anyway to turn it off with VAG-COM?
dieselkid96 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Page generated in 0.18824 seconds with 9 queries
[Output: 119.05 Kb. compressed to 98.67 Kb. by saving 20.38 Kb. (17.12%)]
