| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta/Golf (99.5-2004) & New Beetle. Both VE and PD engines are covered here. |
View Poll Results: Headlights: What colour of E-Codes?
Yes
140 |
95.89% |
No
6 |
4.11% |
September 15th, 2004, 16:16
#1
top post dawg
Coolant Migration Sticky !! : 0
"I took it to the dealer and pointed out that I had discovered what looked suspiciously like coolant fluid in the tailight housing."
For some reason that image has stuck with me - - very graphic.
Should someone create a brief sticky thread so people can check their cars? This issue was addressed in 2001 yet people are still finding it today in 2003MY cars.
As previously noted, the only thing worse than coolant migration is CCV+EGR
Official TSB =>
September 15th, 2004, 16:21
#2
Gadget Guy
Coolant Migration sticky?
It should be put at the top of the 'How To's' thread perhaps? Hmm... Maby people wouldn't see it there. This is defintally an issue that EVERYONE needs to know about.
-Jason
September 15th, 2004, 16:45
#3
Heck yes! This is one serious problem that people need to be aware of.
September 15th, 2004, 17:00
#4
TDI Lifer
Hell,  I preach about it everywhere I go......
September 15th, 2004, 17:14
#5
-Jason
 ...and the fix is so simple
September 15th, 2004, 17:22
#6
"...and the fix is so simple"
No, the prevention is simple. The fix is far from simple...
September 15th, 2004, 19:05
#7
Do we really know for sure that the weep hole will prevent coolant migration?
I melted the hole on my 03 but I am watching carefully for and leaks and or updates on this board.
I left the orange gasket in place for now. I have thought about finding a wrecked Jetta and making a short harness with soldered on spade connectors. That way if there were any warranty issues it could be removed and the original wiring would stock.
gg
September 15th, 2004, 20:04
#8
Dieseldorf, that picture is really too dark to see much. Have a free copy for your use: Click Here
September 16th, 2004, 06:12
#9
It will prevent it (the weep hole). As the bottle pumps it out (if it is defective) it will (the fluid) go out the easiest passage, which would be the weephole. It wouldn't force itself through the seal. Thats why you keep the seal, and drill the hole.
September 16th, 2004, 06:34
#10
Wouldn't a hole on the housing promote corrosion on the connectors? Mine's an '02 with 88k miles. I think i'm safe since no migration is present
September 16th, 2004, 06:38
#11
No. The connector covers the connectors when plugged in.
September 17th, 2004, 16:56
#12
top post dawg
ttt
September 17th, 2004, 17:56
#13
Hi DD, That's F'd up! I don't get to meet you at the Fest, yet I discovered a coolant migration problem on an 03 Jetta 1.8T that was being chipped by Jeff of RC. I say that this issue should be one of the first things to check on any VW you come in contact with, especially if you are seareching for a used one. Later!
September 19th, 2004, 17:54
#14
top post dawg
September 19th, 2004, 20:01
#15
Hmm, I'm fairly new with a 2004 Jetta TDI, is this something I need to be concerned about?
| Thread Tools |
Search this Thread |
