Drivbiwire
Zehntes Jahr der Veteran
- Joined
- Oct 13, 1998
- Location
- Boise, Idaho
- TDI
- 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
Nope its not air in the fuel line, Its not the cam timing because you pulled the engine through by hand right???? right
And of course you followed the procedure EXACTLY the way it was posted...Ahh but it did not start so what could it be? 99% of the time its the injection pump lock pin. But of course you are thinking that you got it in the hole...Well guess again.
Below is the step by step including a picture that shows where the pin must be oriented to. The pin will insert anyhere on the pumps rotation but there is only one proper hole for this. If you use a mirror you can see the hole. If you are really in doubt remove the pulley and visually identify the hole in the pump. At the 11:00 oclock position is a sucker hole that most people seem to install the pin into. This hole/casting area is just far enough out of time that you will not get the car started. Another factor is the internal spring pressure inside the pump causes the pump to align with this casting. If you simply push the pin in, the pump has already aligned itself to the wrong orientation.Rule of thumb is that you ALWAYS need a crecent wrench to rotate the pump into the proper orientation. Follow the below procedure and the car will start:
DO NOT REMOVE THE ENGINE MOUNTS, leave them installed for this procedure
-Remove the valve cover
-remove the vacuum pump
-Insert cam lock tool
-Loosen BUT DO NOT REMOVE THE TENSIONER NUT
-Loosen the 3 bolts on the injection pump
-Loosen ALL THE TENSION on the belt tensioner
-Remove the cam pulley
Because you cant find the injection pumps alignment hole remove ALL 3 bolts then remove the injection pump pulley and look at the pump so that you can see where the proper hole is for alignment.
Red is incorrect, the yellow line is the proper alignment...yes that much off is all it takes and why so many people seem to get it wrong.
DO NOT TIGTHEN ANYTHING till its expressly stated to do so!!!
-Rotate engine so that its at TDC on the flywheel
-Reinstall the injection pump pulley and leave the 3 bolts loose Read: Loose NOT finger tight
-Insert the injection pump lock pin in the CORRECT HOLE this time
-Wrap the belt around its proper path over the pump Make sure that the Injection pump lock pin is centered in the hole so that you can adjust timing one way or the other.
-Reinstall the cam pulley
-Look at the injection pump lock pin, if its not centered in the hole do over till it is!!!
Now:
-Cam pulley is on the shaft and the nut is installed by hand and not torqued
-Injection pump lock pin is installed IN THE CORRECT HOLE THIS TIME and CENTERED in its elongated hole (give or take left or right of cener is ok)
-Cam is locked down
-Flywheel is EXACTLY, not close, but EXACTLY at TDC!!!!
NOW:
-Set the tension on the tensioner and torque down the nut.
-VERIFY engine to be at TDC!!!!
-VERIFY the injection pump lock pin to be centered in its hole
-TORQUE the cam bolt to 33 ft-lbs~
-VERIFY the engine is at TDC!!!!
-Snug up with a ratchet each of the 3 bolts on the injection pump pulley just enough to hold the pulley. Now snug them up then go back and tighten them down with the final torque.
-Remove the cam lock tool
-Remove the injection pump lock pin
-Reinstall the vacuum pump
DO NOT START THE ENGINE YET!!!!
-Pull the motor through by HAND and NOT THE STARTER!!!!
-You should feel good compression and the engine should pull through at least 1 revolution of the cam pulley
Now start the car, the car should start and fire immediately!
DB
Now:
-Cam is locked down
NOW:
DB
