Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old September 2nd, 2004, 07:38   #1
Blue_Thunder
Default Optimal RPM for maximum fuel efficiency
Could somebody tell me what the optimal RPM would be for my TDI-PD for maximum fuel economy? I've read 2,000 RPM and 2,500 RPM.
2,000 RPM on my TDI-PD, DSG Beetle puts me at precisely 60 miles per hour, in sixth gear.
2,500 puts me up around 65-70 mph.
So, does anyone have technical knowledge on what the most efficient RPM is for highway cruising?
Thanks.
Blue_Thunder is offline   Reply With Quote
Old September 2nd, 2004, 07:53   #2
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
2000 rpm will net you better fuel economy than 2500 rpm. The max torque in the PD is supposedly available from 1800-2400 rpm. Wind resistance comes into play over 60 mph, so slower = better mileage.
hth
-tom
tditom is online now   Reply With Quote
Old September 2nd, 2004, 07:54   #3
Drivbiwire
Zehntes Jahr der Veteran
The best range falls within the 1900-2200 rpm range give or take.
DB
Old September 2nd, 2004, 08:00   #4
tditom
DBW- Do you have anything like that for the PD engine? The VW web site states 177 ft-lbs from 1800-2400 rpm.
-tom
Old September 2nd, 2004, 10:06   #5
Blue_Thunder
Wow, once again tdiclub.com has proven itself to be a truly amazing source of information.
Old September 2nd, 2004, 15:44   #6
maxforce
Fuel Economy: Great on all
I will give up a couple of miles per gallon to try and keep the intake clean and have a more "spirited" drive. I shift at 3k to 3500 and have averaged 49.2 for 25000 miles. As high as 55mpg.
maxforce is offline   Reply With Quote
Old September 2nd, 2004, 19:25   #7
dbb635
I have a Tip with 19000km on it now, I usually get 750-800km per tank vented with about 58.5litres. If I'm not mistaken, that works out to about 30mpg us and 35 Imp MPG. I cant understand how I regularly see 50+ with these cars, I know I am in traffic for a minimu of 1hr per day, but 15 pg diff seems quite high. I'm not complaining, just confused...
dbb635 is offline   Reply With Quote
Old September 2nd, 2004, 20:14   #8
Ramsey
Fuel Economy: 48/44/37
The tiptronic is still an automatic, and they all lose efficiency in the torque converter. I rarely hear of automatics doing better than 38. main reason I didn't get the passat wagon.
Ramsey is offline   Reply With Quote
Old September 3rd, 2004, 07:14   #9
fresheverytime
TDI(s): 2004 TDI PD
My best tank so far is 901kms with the Tiptronic... 54.6l to fill (vented) -> Low fuel light came on as I was pulling into the station.
33000kms on the dial and:
Lifetime average of 6.27 l/100kms (37.54 mpg)
Best tank of 5.13 l/100kms (45.86 mpg)
fresheverytime is offline   Reply With Quote
Old September 3rd, 2004, 20:50   #10
TornadoRed
TornadoRed's Avatar
I know I am in traffic for a minimum of 1hr per day, but 15 pg diff seems quite high. I'm not complaining, just confused...
I spent 90 minutes driving home this evening, about 30-35 miles. Mostly in 1st and 2nd, occasionally 3rd gear. This tank will suck for fuel mileage.
If you want to see 45-50 mpg (US), then change your job and residence so you have a nice long 55 mph drive with no stoplights or traffic.
Old September 3rd, 2004, 23:38   #11
Wee_Car
Fuel Economy: unknown
I think you will find your best fuel economy at about 1500 rpm or at 45-50 mph. My wife regularly gets high 50's with her '03 manual on a 26 mile commute with only two traffic lights and a steady 45-50 mph speed. My moms '04 tiptronic can't get out of the mid 30's and I doubt it will gain much more, even after breakin. When I drive my wifes car, I shift at least 1000 rpm higher and drive at least 10 mph faster. My fuel economy is about 45 mph, so there is a big hit on how you drive these things. BTW my Ford powerstrokes get their best fuel efficiency at about 1400 rpm according to the computer.
Wee_Car is offline   Reply With Quote
Old September 29th, 2004, 10:36   #12
Xgaz
I've noticed the same for my Tiptronic, so now I'm driving it as if it's a manual tranny.
Anyone know if that will make a difference in the milage?
Xgaz is offline   Reply With Quote
Old September 30th, 2004, 04:50   #13
TDIMAXIMA
TDIMAXIMA's Avatar
For canadian drivers, I get between 900-950 km's a tank right around the fuel light comes on. I drive 98% on the highway of probably an average speed above what is posted. I think my mileage is ok, but not amazing, but my speed is the reason, Im regulary over 3000rpms.
TDIMAXIMA is offline   Reply With Quote
Old October 2nd, 2004, 10:39   #14
PolarBear
Fuel Economy: 5.2 L/100Km
My present average is 5.3L/100km on an average of 50litres fillup. My best up to date is 5.1L/100 (968.8Km on 49.4 litres). My driving is mostly highway with an avg. speed of 120Km/Hr. I shift @ 2000rpm to 2100rpm and easy on the accelerator. Heck of a difference with my previous vehicle: 1/2 ton Chevy Pick-up with 125Litre tank Ouch!
PolarBear is offline   Reply With Quote
Old October 3rd, 2004, 12:41   #15
rickdick80
Fuel Economy: 45.4 / 41.4 / 38.7
DBW-
Does that graph only represent WOT curves? I wonder if the torque peak
[edit: it is my understanding that torque peak and BSFC peak tend to be nearly on top of one another]
occurs at the same engine speed at 10% throttle, 20% throttle, etc. Does anyone know if torque peaks tend to shift due to throttle input?
rickdick80 is offline   Reply With Quote
Page generated in 0.18279 seconds with 9 queries
[Output: 115.03 Kb. compressed to 95.18 Kb. by saving 19.85 Kb. (17.25%)]
