Follow up post...
Well, I finally got the old booster out this past Saturday. The only way I could get the booster rod disconnected from the brake pedal was to cut the rod in half, then remove the pedal from the vehicle and then remove the plastic piece from the pedal assembly. Keep an eye out for the little metal ball seat that is behind the plastic seat. Remember to reinstall it before you reinstall the plastic seat assembly. Once removed it was an easy task of just sliding the cut rod portion through the back side of the plastic piece. Of course, if you have the removal tool, it is not necessary to cut the the rod in half. I called the dealer and they said they could get me one in a week. Oh, another precaution is to disconnect the wiring harness for the brake light switch. If you don't do this, once you remove the brake pedal assembly, the brake lights will remain on.
That said, the next task was to remove the booster assembly from under the hood. This took a little "forcefull" massaging but I was able to remove it. I will say that in order to remove the booster assembly required removing the three ABS controller retaining nuts as well as disconnecting the electrical connector from the ABS unit. I did not disconnect any of the brake lines from the ABS unit as suggested. I really didn't want to go through the hassle of bleeding the entire ABS unit if I didn't have too. Extreme care must be taken though when you are attempting to remove the old booster unit. Pay close attention to "everything" as there are alot of things that get in the way.
Same warning goes for when you are attempting to install the replacement unit as well. Once you get the replacement unit somewhat in place, stop here and go under the dash and reinstall the plastic seat that connects the booster rod to the brake pedal. Don't forget the little metal ball seat that goes behind the plastic rod seat. I used a little grease to keep it in position while I reinstalled everything. Then reinstall the plastic seat and booster rod back into the brake pedal assembly. If you don't do this while the booster assembly is still loose from the fire wall, you do not have any room to reinstall everything under the dash...
Once all of the above is done, secure the booster assembly with the four nuts removed from under the dash. Reinstall the brake pedal assembly, all of the underdash panels and proceed back under the hood.
Under the hood, you will need to reinstall the master cylinder, the air cleaner box and cover and the electrical connetions from both the master cylinder and MAF sensor. When I was reconnceting the brake lines from the master cylinder, before I tightened everything up, I let the lines bleed some fluid through them before I locked them down. I then took my power bleeder and started at the right rear caliper and back bled everything by forcing brake fluid back though all the lines.
I still have a few things to check yet. Mainly the adjustment of the brake light switch. There have been several posts about the adjustment of this switch. Although I don't understand at this point how it could affect the operation of the booster assembly as there is no electrical connection between the two components, I want to make sure that everything is where it should be... Hopefully tonight I'll test drive it and be back on the road...
