Old August 8th, 2004, 16:43   #1
JettaTDI777
TDI(s): Sold It
Default Resetting brake wear indicator light on dashboard
I have an '01 Jetta TDI just did the front pads and rotors and the front brake pad wear indicator light on the dash did not go away. I flipped through the Haynes manual and it actually mentioned a wear indicator harness needed to be unplugged. Do I need to go back and disconnect the harness or can I reset it through vag-com?
JettaTDI777 is offline   Reply With Quote
Old August 8th, 2004, 18:38   #2
Cincy_Mike
Fuel Economy: Avg: 41mpg -- mostly city
Here's a related thread
Cincy_Mike is offline   Reply With Quote
Old August 11th, 2004, 20:33   #3
JettaTDI777
TDI(s): Sold It
Would i be able to disconnect the battery for a while so that it might reset it on the ecu's memory?
Old August 12th, 2004, 09:47   #4
pghPAtdi
pghPAtdi's Avatar
Fuel Economy: 57/40/34
My light went out when I plugged the harness into the new pads. Did the new pads you installed have the harness hanging off the backside of one of the pads? Actually the mintex pads I bought came with 4 pads, 2 of which have the harness so I just cut one of them off.
Dave
pghPAtdi is offline   Reply With Quote
Old August 12th, 2004, 10:04   #5
JettaTDI777
TDI(s): Sold It
My new mintex pads actually didn't have a harness on any of them unless it's located somewhere by the caliper? When I pulled the old pads off it didn't have them either.
Old August 12th, 2004, 10:42   #6
pghPAtdi
pghPAtdi's Avatar
I have an 01' jetta too. Mine has the sensor. My light came on when my pads got so thin the heat burned the wire off the pads and it was just left hanging there. Take another look for a stainless steel bracket by the caliper which would be holding the harness. You might find a dangling wire which use to be on your old pads. The wire/plug comes right out of the back of the pad near the edge, so you couldn't miss it. 3-4" long.
Dave
Page generated in 0.07618 seconds with 9 queries
[Output: 67.95 Kb. compressed to 59.12 Kb. by saving 8.83 Kb. (12.99%)]
