Old July 19th, 2004, 09:37   #1
joshua1976
TDI(s): Golf Mk5 TDi
Default Golf TDI Power loss
Hi all,
I've recently bought a mk4 2001 golf TDI, I've noticed theres a real power loss at around 2500/3000 revs. The car drives ok around town but on the motorway its really noticeable.
I've tried disconnecting the MAF, when i do this i lose the initial power i've got in those revs upto 2500/3000 but beyond that the performance is just the same. Could it still be the MAF or is it likely to be more serious.
Thanx in advance for any help/advice.
Jay
joshua1976 is offline   Reply With Quote
Old July 19th, 2004, 09:55   #2
Rustynuts
Fuel Economy: 57 Imp. mpg
How many miles / kilometres has it done. If it's up to 50k or so. it could be the intake blocked, unless it's been cleaned already. Here's a link to how to clean it. Here's another, look at "Intake manifold cleaning 101". See if these help.
Welcome aboard.
Regards.
Rusty.
Rustynuts is offline   Reply With Quote
Old July 19th, 2004, 10:10   #3
joshua1976
Its actually done 88000 miles, fairly high for its age, but should still have plenty of life left in it.
Occasionaly the car does seem to get the power back that it should have but only for a brief second, then it just goes.
jay
Old July 19th, 2004, 10:20   #4
McBrew
McBrew's Avatar
Fuel Economy: 54/50/44 (usually running B100)
It's still possible that you have a bad MAF. You want to check the air path... from the snow screen and air filter to the intake manifold. Also, you should confirm that the VNT rod on the turbo is working. Try moving it by hand (not easy), or have someone use Vag-Com to test it. Could be a sticky rod or a bad N75 valve.
McBrew is offline   Reply With Quote
Old July 19th, 2004, 15:35   #5
JettaTDI777
TDI(s): Sold It
I had the same symptoms on my 01 jetta tdi took it to the dealer and they replaced it. There is a service bulletin for the mk4 body style i believe.
JettaTDI777 is offline   Reply With Quote
Old July 19th, 2004, 16:03   #6
wanders
wanders's Avatar
Fuel Economy: AVG 48 MPG Best- 53 MPG
I see that you are over 70,000 miles. I'm pretty sure VW extended warranty on MAFs is to 70K. Try an experiment. See http://forums.tdiclub.com/showflat.php?C...rt=8#Post788044
Hey, for $2.00 and 5 minutes time,how can you lose?
wanders is offline   Reply With Quote
Old July 20th, 2004, 05:56   #7
joshua1976
Thanx everyone for your advice, it has been much appreciated. I have just fitted a new MAF sensor, got an exchange from vw 75+vat, the car now drives loads better, no loss of power at 2500revs.
Thanx again,
Jay
Page generated in 0.14144 seconds with 9 queries
[Output: 73.08 Kb. compressed to 63.04 Kb. by saving 10.05 Kb. (13.75%)]
