Old June 15th, 2004, 16:25   #1
tdibigd
Fuel Economy: 44/41/37
Default How much refrigerant?
Replaced my A/C compressor the other day. Can anyone verify the R134 capacity of the Jetta TDI A/C system? I've heard 2 different figures - 24 ounces and 41 ounces.
Anyone know for sure?
See pictures of my mangled compressor clutch in the A4 maint. forum.
tdibigd is offline   Reply With Quote
Old June 16th, 2004, 05:48   #2
stayalert
Fuel Economy: mid forties
paper bentley says 24.7 + 1.8oz I don't know why it says plus 1.8..
Rob M Concord, MA
I'm frantically trying to fix a non-functioning mag. clutch...don't know yet why its not working...could be low pressure, could be something else..any thoughts that may help my effort??
Rob M Concord, MA
stayalert is offline   Reply With Quote
Old June 16th, 2004, 05:55   #3
stayalert
paper bentley for '99 -02
rob M
Old June 16th, 2004, 15:45   #4
ZX1100F1
TDI(s): none
the "+ 1.8oz" is in reference to oil.
ZX1100F1 is offline   Reply With Quote
Old June 17th, 2004, 16:34   #5
professor
I would expect that there is a pressure switch that keeps the compressor from running if the ref. level is low. It is designed to keep it from running if it can't circulate the oil. If the ref. is only slightly low, the compressor short-cycles because of this switch. There should also be an anti-ice switch on the evaporator, which controls the compressor.
professor is offline   Reply With Quote
Page generated in 0.11771 seconds with 9 queries
[Output: 60.93 Kb. compressed to 53.47 Kb. by saving 7.46 Kb. (12.25%)]
