Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
Thread Tools Search this Thread
Old May 23rd, 2004, 15:55   #1
Kennedy
Default Oil Coolers... You have options guys. LOOK!
I know the concept of auxillary oil cooling is a hotly debated issue and I don't want this post to center around the validity or requirement for oil cooling. Here's some new parts that fit, make of it what you will.
- My opinion: First, let's not call it an oil cooler, it's an oil/engine coolant heat exchanger. It serves to bring the engine oil up to normal operating temperature (NOT) more quickly, as well as it keep it there under loads. Jeff @ Rocketchip has made many comments as to the importance of keeping the oil at NOT with souped up engines that run higher egt's (i.e. chipped). I strongly feel that all TDI engines could benefit from having an uprated heat exchanger as they serve to bring the engine to NOT quicker and keep it there better than stock cooler.
Dieselgeek sells a kit on his site, which is merely an oil cooler for a V6 4motion Passat (or at least appears to be). I found this out last week while changing Eric's oil in his 4motiion gasser Passat. Thanks again Eric for the cluster work.
Anywho, to the meat here:
The wimpy single coil exchanger on the left is the stock cooler on the MKIV tdi...
The middle cooler is a stock gasser V6 4motion Passat oil cooler, which appears to be identical to the Dieselgeek oil cooler. I used to have a Dieselgeek OC on my auto and it bolts right up. I've confirmed the V6 the 4motion Passat will also bolt up as well. It should be noted that although it bolts right up, it stresses the coolant lines a bit, as they aren't long enough to connect to the lower connectors on the cooler. I belive Oldpoopie discussed how difficult it is get that the little booger in place a while back.
Dieselegeek sells these for $210 complete, which isn't a bad price. If you know a good parts counter, you can get everything for about $185 new.
The part numbers you'll need are:
028117021E OIL COOLER (should come with upper gasket)
038117061 LOWER COVER TO OIL COOLER WITH SEAL
Now, the big daddy on the right is the oil cooler from a 04 130HP PD Passat. It will bolt right up as well, as Lito has been running it for a few weeks now. The coolant connectors sit on top of the cooler... you can either trim your coolant lines about 2 inches, or leave them long (just zip tie the excess). Install is a snap according to Lito.
All the parts you need can be gotten for about $200 from vwparts.com (call Jerry!), or any other parts vendor out there that you know and trust.
038117021B OIL COOLER
038117070B SEAL
There ya go...
Oil cooling options for all.
Kennedy is offline   Reply With Quote
Old May 23rd, 2004, 16:16   #2
Davin
[ QUOTE ]
[/ QUOTE ]
Wow... that's a monster cooler! Lito, can you chime in on how well this thing works? Do you have an oil temp gauge?
Davin is offline   Reply With Quote
Old May 23rd, 2004, 18:03   #3
NoPlugz
I got the V6 4motion cooler for $75.00 on Ebay. Looks new, smells new......works like new. [img]/images/graemlins/grin.gif[/img]
NoPlugz is offline   Reply With Quote
Old May 23rd, 2004, 18:57   #4
DZLPOWR
I love it! The first thing I noticed on our new 04 Passat is the oil cooler. I think my exact words were "damn, that's a big oil cooler". Of course the salesperson had no clue what I was talking about. Looks like another mod for my 98 NB TDI. Thanks for the info.
DZLPOWR is offline   Reply With Quote
Old May 23rd, 2004, 20:43   #5
tongsli
Davin,
Unfortuneately, I removed my oil temp gauge when I added the NAVI. I lost my single din location for the gauges. But I can tell you when I did have it and when I was running the V6 4-motion Passat oil cooler my oil temps were never an issue. Summertime on really hot days(95+) and it'd climb another 5-7 degrees but no higher.
Chris is right, the oil cooler/heat exchanger keeps the temperature close to 190-200 deg or so(normal operating temperature). It's about how quickly the coolant can take away any additional heat(to your oil) generated by your phat injectors, chip, etc, etc. The larger the heat exchanger, the more efficient it does it's job.
The 150hp TDI has a larger oil cooler as well, just not as large as the Passat's.
A note about the Passat TDI installation: You have to cut apart the two hoses and cut the 90 degree bend off as well.
L
tongsli is offline   Reply With Quote
Old May 23rd, 2004, 20:48   #6
AtomicDog
What's the highest oil temp that is considered to be safe? It's not uncommon for my oil temp guage to read ~210F w/ just my Upsolute chip. Maybe I could use one of these coolers...
AtomicDog is offline   Reply With Quote
Old May 24th, 2004, 07:11   #7
vwnumber3
Send a message via AIM to vwnumber3
I would like to know too. In this heat with the AC going I have been around 220 or a little better when warmed up. I may need the passat oil cooler too!
vwnumber3 is offline   Reply With Quote
Old May 24th, 2004, 07:12   #8
Peter Cheuk
Gasser :P
Would these fit an A3 TDI (AHU)?
Peter Cheuk is offline   Reply With Quote
Old May 24th, 2004, 08:47   #9
hpc
WOW! A big motha! Just did a parts search on 1stvwparts
and came up with $173.28 plus shipping. THe parts are
listed as stuff for the 3.2L gasser.
Nice post Chris!
Cheers,
lon
hpc is offline   Reply With Quote
Old May 24th, 2004, 09:34   #10
Birdman
this is great for the mountians but my highly modded engine never goes over 190 unless on a mountian then have seen it get to 210 which is still safe in my book.
now the BIG hills out west this would help. Just MHO
Birdman is offline   Reply With Quote
Old May 24th, 2004, 20:16   #11
Kennedy
[ QUOTE ]
[/ QUOTE ]
That's a damn good price. You'll probably need to order the oil cooler cap, as the OEM mount uses a stud with a spin on filter.
Old May 25th, 2004, 08:26   #12
VWRacer1
[ QUOTE ]
[/ QUOTE ]
Minor point...a larger heat exchanger has a greater heat transfer capacity, but isn't necessarily more efficient. [img]/images/graemlins/smirk.gif[/img]
Someone asked about oil temps. I run synthetics in my race cars, and the oil company recommends 220°-230° F for maximum thermodynamic efficiency. Anything from 200° to 250° is okay for sustained running. Below that and the engine is not considered fully warmed up, and much above that the oil starts having stability problems.
VWRacer1 is offline   Reply With Quote
Old May 25th, 2004, 08:35   #13
tongsli
[ QUOTE ]
[/ QUOTE ]
Tell my why it isn't more efficient?
If my capacity is larger, and even at the same rate of heat transfer from oil to coolant, if I'm processing twice as much hot oil as you are then why wouldn't a larger capacity oil cooler be doing a more efficient job?
For that matter, at the same heat tranfer rate, ANY amount larger than the OEM/Stock oil cooler is an advantage. Right?
L
Old May 25th, 2004, 11:14   #14
VWRacer1
[ QUOTE ]
L
[/ QUOTE ]
The term "efficient" suggests the achievement of maximum result with minimum effort, whereas "effective" emphasizes the actual production of an effect when in use. A larger heat exchanger is more effective (has a greater heat transfer capacity) than a similar smaller one, but is not necesarily more efficient. As I said, a minor point... [img]/images/graemlins/smile.gif[/img]
To your second question, yes, a larger heat exchanger is a good thing if the engine is loaded more than the stock exchanger can effectively handle. I.E., if one finds that the oil temp is going much above, say 230°F, then a larger oil cooler will help keep temps in line. Just as one shouldn't let oil get too hot, it is also important to ensure that it gets hot enough. Unlike an intercooler, where cooler is ALWAYS better, letting the engine oil stay too cool is not good for the engine.
Old May 25th, 2004, 12:37   #15
tongsli
Racer...got it. Effective, yes I agree [img]/images/graemlins/smile.gif[/img] I also agree that too cool is not good, but it theoretically would never get cooler than 190 degs and would probably stay as you say withing the 190-210 Normal operating window.
Bottom line is...as folks keep piling on the mods: 11mm pump, injectors, chip, etc,etc, this really needs to be on the list as well. I'd certainly do this before I'd put on a different fuel filter.
L
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.11494 seconds with 11 queries
[Output: 91.55 Kb. compressed to 84.88 Kb. by saving 6.67 Kb. (7.29%)]
