Old May 17th, 2004, 16:24   #1
truav8r
Default Topping off G12 - where to get deionized water?
I got a gallon of G12 today, just to top off the reservoir. (No leak, it was just delivered with the coolant at the "Min" line). I had assumed I could use distilled water, but the bottle says to mix with de-ionized water. Now wally world has everything, but not that [img]/images/graemlins/smile.gif[/img] Where do I find deionized water?
Also... the coolant I bought was part #G 012 A8FA4. It appears to be the "new" red variety? Any problem mixing this with my existing pink/orange G12??
Thanks.
- sean
truav8r is offline   Reply With Quote
Old May 17th, 2004, 16:47   #2
MOGolf
MOGolf's Avatar
The coolant you got is backward compatible with previous versions of G12 and G11.
Distilled water will work just as well. Grocery stores often have distlled and de-ionized water by the gallon bottle.
MOGolf is offline   Reply With Quote
Old May 17th, 2004, 18:31   #3
Joe Fisher
TDI(s): NA
I did the *exact* same thing yesterday. My coolant has been right below the Min. line in the overflow reservoir for forever.:-/
I had to guy a gallon of G12, I used about 5 ounces of it. As for the distilled Water, as Mogolf says, I just bought mine at the grocery store in a gallon jug.
Joe Fisher is offline   Reply With Quote
Old May 17th, 2004, 19:13   #4
truav8r
Thanks Glen & Joe.
Old May 18th, 2004, 19:57   #5
Benlinus
How often should you flush and fill the coolant? I've gone about 40K since I bought mine with 55K on it, so I figure it's about time.
I'm thinking I'll just buy the coolant and bring it down to Valvoline Instant Oil Change. They've got that "sucker-outer" thing. I figure they'd charge me $10 or something and I'll be in and out in 20 minutes.
Benlinus is offline   Reply With Quote
Old May 21st, 2004, 16:56   #6
MOGolf
MOGolf's Avatar
VW's coolant is a good product and doesn't need to be flushed. Leave it be, top up as necessary, or refill whenever the system is opened up for component replacement (e.g. water pump replacement).
Old May 21st, 2004, 17:23   #7
VelvetFoot
VelvetFoot's Avatar
I remember attempting to flush a coolant system a bunch of years ago. I was never sure about the mix = had to use one of those specific gravity ball thingys. Not to mention that I wasn't using distilled water. Both factors I think would argue for not flushing.
VelvetFoot is offline   Reply With Quote
Old May 21st, 2004, 18:36   #8
truav8r
Ok, so I topped up the coolant with G12 and distilled water. Peeking down into the coolant tank, I noticed some fine "dirt" particles that seemed to be sitting near the bottom of the tank. I have never opened the coolant tank before this.
Anything to be concerned about? Just normal radiator crud??
- sean
Old May 22nd, 2004, 05:33   #9
MOGolf
MOGolf's Avatar
It's normal. Don't worry about.
Old May 22nd, 2004, 05:59   #10
drroccostein
Fuel Economy: Still in Break in Period
Casting sand, as said before normal
drroccostein is offline   Reply With Quote
Page generated in 0.14333 seconds with 9 queries
[Output: 88.57 Kb. compressed to 74.73 Kb. by saving 13.84 Kb. (15.62%)]
