GeWilli
This might be around somewhere else... but since I just went through it and finally figured out how to decode the PR-G76/L39 type info on the spring data, its time to share...
For the exercise I looked up a 2001 Jetta... (springs are same for everything but there might be a different color or two to add for different years)
I looked only at "Sports-type Running gear" springs
And what ya see there are those color dots (i'll get to examples in a second). Now you'll also see the P data in the far right column (in EPC/ETKA).
THAT is where the spring rate data can be decoded from... Sooo To decode THAT into specific weight ranges... click on ELA-Pages
That will take you to a window that will decode the spring rate... for example, going through the 2001 jetta:
3 green
1 brown
PR-G76/L24
weight range of 596-630 kilograms (2.2 pounds per KG - so 1314-1389 pounds) (thats for the front side of the car)
1 violet
4 yellow
PR-G76/L13
631-670 KG
2 green
4 white
PR-G76/L34
671-710 KG
1 violet
1 pink
PR-G76/L21
711-750 KG
2 blue
3 white
PR-G76/L08
751-780 KG
2 blue
2 white
PR-G76/L39
781-830 KG (1722-1830 pounds)
(notice the pattern?)
These are listed in order of appearance in the part catalog... The L number corresponds to the weight range of the spring, the G76 means sports-type gear...
Currently I'm running the PR-G76/L21 1 violet 1 pink spring set in my car. and i love it! Great spring rate. Pretty damn close match for the car - considering its right at about 3,000 pounds total weight with me in it.
Okay... now about the REAR...
simple - two choices (well for the most part)
PR-UA9 or
PR-1JC (PR-UB3 also)
UA9 is comfort suspension and is the only one listed for the Jetta
1JC is the sport-type for the Golf (so is UB3).
No decoding of the weights though.
(speculation comments removed - specifically the ones Peter references below - no need for incorrect info to be spread around)
3 green
1 brown
PR-G76/L24
1 violet
4 yellow
PR-G76/L13
631-670 KG
2 green
4 white
PR-G76/L34
671-710 KG
1 violet
1 pink
PR-G76/L21
711-750 KG
2 blue
3 white
PR-G76/L08
751-780 KG
2 blue
2 white
PR-G76/L39
PR-UA9 or
