Old September 5th, 2006, 11:12   #31
mk3
mk3's Avatar
Fuel Economy: 46 lifetime
Default Some ALH engines have different harmonic balancer and different torque
If you search for this part number N-103-036-03 you should find a posting by me explaining why on my 2003 ALH engine (and some others) the torque spec for the Harmonic balancer bolts is :
10 Nm + 90 degrees turn
Always replace!
VW dealers do not know this ( mine didn't)
03 Jetta TDI 5-spd (221k mi) PP520 Nozzles, IQ 5.8
Plastic impeller-OEM Waterpump
01 Passat V6(160k mi)
mk3 is offline   Reply With Quote
Old September 5th, 2006, 13:50   #32
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Thanks for tracking this one down... BTW: your other posting is in the A3 forum... you should really have it moved...
10 nm ??? That's not very much... 7.3756 ft*lb... even with the addtional 90 degrees...
We replaced my timing belt yesterday, and although I had replacement bolts, we re-used the originals... Since they weren't replaced during the first timing belt replacement either, I think one of these days I'll just replace them on principle... (They looked great, BTW...)
Yuri.
2003 TDI Jetta Wagon 196722 miles 41.5 months
ymz is online now   Reply With Quote
Old September 5th, 2006, 18:39   #33
mk3
mk3's Avatar
Default Thanks!
I did a search for "Harmonic Balancer bolt" and blindly posted that without noticing I was in the wrong Forum... Thanks for pointing that out! I think I fixed it now.
btw, 10 Nm + 90 degrees is a lot of tension, I can assure you because I just did this on my car. I was worried I would round out the hex keys. Try it and you will see ; )
Old March 17th, 2007, 14:46   #34
tdifamilyx2
Looking for the Torgue Specs for the Rear Shock Absorber Top Bolts for a 97 Passat. Thanks
tdifamilyx2 is offline   Reply With Quote
Old March 17th, 2007, 15:41   #35
paramedick
paramedick's Avatar
18 ft/lbs
An all TDI Family!!
Old October 24th, 2007, 15:31   #36
akliven
akliven's Avatar
TDI(s): 2000 golf
Default injectors torque
I'm putting in pp520's and can't seem to find the 15mm injector "cap"? torque. the thing that holds the injector to the housing/spring assembley. any idea. thanks
rob
akliven is offline   Reply With Quote
Old October 24th, 2007, 15:44   #37
ymz
The PDF says 33 ft*lbs - but that's not really enough... According to Kerma, "screw down the nozzle retaining nut with a wrench until it bottoms out on the injector and is "snug". Then take a deepwell socket and breaker bar and tighten it 30 degrees."
The injector hold-downs are only 15 Ft*Lbs...
Yuri.
Old October 24th, 2007, 15:50   #38
akliven
akliven's Avatar
TDI(s): 2000 golf
Yuri.
thanks. Its been a long tedious process rebuilding this engine but since i have it apart i might as weel upgrade it.
rob
'00 Golf w/ rebuilt motor. vnt-17, pp520 injectors, vr6 clutch.
tdi maintenance = steep learning curve.
Old October 25th, 2007, 11:38   #39
rawdon1
rawdon1's Avatar
TDI(s): 2002 Jetta
Default torque specs
torque specs front axle nut ?
rawdon1 is offline   Reply With Quote
Old October 25th, 2007, 12:03   #40
ymz
Do you have a Bentley service manual??? Be careful not to have any weight on the wheel when you start loosening the front axle retaining nut !!!!!!
To install:
Tighten 12-point nut to 200 Nm and loosen 1/2 turn.
Turn wheel hub 180 ° .
Tighten again with:
50 Nm + 60 ° additional turn (make marks... 2 "corners" of the nut equal 60 °)
It also says to "Coat with oil before installing the axle shaft:
The splines of the outer joint
The thread of the outer joint
Wheel hub splines
The contact surface and threads of the 12 point nut."
(BTW: for those that have cars with a bolt instead of the 12 point nut: NO OIL on the threads of the bolt !!!!)
Yuri.
Old November 24th, 2007, 15:04   #41
lupin..the..3rd
lupin..the..3rd's Avatar
And how about the rear axle nut for '04 Jetta? (The big 30 mm 12 point nut).
TIA!
lupin..the..3rd is offline   Reply With Quote
Old December 3rd, 2007, 10:59   #42
Vindiesel6
Fuel Economy: 42 - 52 mpg
What is the proper torque spec for the 6 front axle bolts holding the axle to the transmission flange? Thanks.
2002 Golf GLS TDI RC3 with Sprint 205's, ON CCV, OMI, TT 2.5" Cat-back stainless steel exhaust, Boostvalve, Eurojet SMIC, Bilstein HD & neuspeed softsport springs, swaybars, strut tower brace, lower tie-bar, short shifter, etc.
2002 Golf GLS TDI ON CCV, Bilstein HD & neuspeed softsport springs, short shifter.
Vindiesel6 is offline   Reply With Quote
Old December 3rd, 2007, 21:14   #43
ymz
According to Bentley, it's done in 2 stages... first tighten them diagonally to 10 NM (7.4 Ft*Lbs), then tighten them diagonally to 40 NM (29.5 Ft*Lbs) (that is: if those are 8 mm bolts... the 10 mm bolt cars are tightened to 70 NM)
Yuri.
Old April 5th, 2008, 07:38   #44
Shainer
Shainer's Avatar
Fuel Economy: 35
What about the use of anti-seize and locktite? Are there locations either one of these products are required or banned?
SOLD! - 02 Jetta w/ automatic transmission. KERMA 1852 Turbo, KERMA Custom Tune. Custom center console mounted Defi Red Racer Gauges (Boost, EGT, Oil).
Torque is King! Those who don’t believe are destined to follow!
Shainer is offline   Reply With Quote
Page generated in 0.15619 seconds with 9 queries
[Output: 124.58 Kb. compressed to 103.27 Kb. by saving 21.31 Kb. (17.11%)]
