Old April 21st, 2004, 11:02   #1
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Default frequently asked torque specs
Torque specifications (Ft-lbs)
ALH engine:
(always replace bolts in bold)
-Drian plug (19mm) 22
-Cam bearing cap (13mm) 15
-Vacuum pump (13mm) 15
-Valve cover (5mm allen) 7
-Cam sprocket (19mm) 33
-T-belt tensioner (13mm) 15
-IP sprocket bolts (13mm) 18
-Pendulum mount to Body mount:(16mm) 30 + 1/4 turn
-Engine mount to engine bracket:(18mm) 44 + 1/4 turn (updated bolts [grey in color] are 74 ft.lbs. trans and engine side)
-Crank shaft bolt: 88 + 90 degrees
-Crankshaft main bearing bolts: 48ft lb + 90 degrees
-Connecting rod bolts: 22 + 1/4 turn (oiled threads and contact surfaces)
-Oil pan bolts (10mm/5mm allen) 11
-Bell housing to oil pan (16mm) 33
-Front seal carrier bolts (10mm/5mm allen) 11
-Rear seal carrier bolts (10mm/5mm allen) 11
-Harmonic balancer bolts (6mm allen) 18 Ft Lb
-Flywheel to crank bolts: 44 + 1/4turn
-Pressure plate to flywheel bolts: 10 ft lb
Loosen and tighten gradually and diagonally (for DMF)
-Bell housing to engine block: 60
-Starter bolts: 50
-Oil filter housing bolts (10mm/5mm allen) 11 + 1/4 turn
-Serpentine belt tensioner (13mm) 18
-Thermostat housing (10mm/5mm allen) 11 don't over do this puppy
-Large timing belt roller:(16mm) 30 + 1/4 turn
-Small upper timing belt roller bolt(13mm) 15
-Small lower timing belt roller nut (13mm) 15
-Intake Manifold to head bolts (6mm allen) 18
-Cylinder head bolts (12mm 12pt.) tighten in the proper sequence to 30, then 44, then 1/4 turn, then 1/4 turn
sequence:
10 4 2 6 8
7 5 1 3 9
-Injection pump to bracket bolts (13mm) 22
-Injector retainers (13mm) 15 ft lbs
-Water pump bolts (10mm/5mm allen) 11
-Engine mount bracket to engine bolts (16mm) 33
-rivnuts (17mm) 30
-Wheel Lugs (17mm) 89
-Glow Plugs (10mm) 11
-Transmission mount to "bracket that holds transmission" (the 2 big 18mm bolts that hang the tranny from the mount) - 100nm (74ftlbs)
-Dog bone (aka) Rear Transmission Mount (aka) Pendulum Support...
-Rear 2 bolts (to subframe) 20nm + 90deg (15ftlbs + 1/4turn)
-Front 2 (to tranny) 40nm + 90deg (30ftlbs + 1/4turn)
-Drive Shaft to tranny - 40 Nm (30 ft lb)
(According to Bentley, it's done in 2 stages... first tighten them diagonally to 10 NM (7.4 Ft*Lbs), then tighten them diagonally to 40 NM (29.5 Ft*Lbs) (that is: if those are 8 mm bolts... the 10 mm bolt cars are tightened to 70 NM --ymz)
-transmission (manual) drain/fill plugs 18 ftlb.
-C.V. axle: M8-30ft.lb, M10-59ft.lb
-Tie rod end nut 33 ft lb, confirmed
-Tie rod end to tie rod 37 ft lb
Ball joint to spindle (self-locking nut): 45 Nm
Ball joint to control arm (use new bolts): 20 Nm plus an additional 90* turn
Sway bar end link at control arm: 33ft lb
Strut retainer bolt and self-locking nut (bolt that goes through spindle, holding the strut in place; replace hex bolt. Bolt point must point to the front of vehicle): 60 Nm plus an additional 90* turn; Never less than 90*
Rear, upper shock mount: 30Nm (22ft -lb.) + 1/4 turn (90 degrees)
Caliper to carrier (8mm allen; caliper->carrier pins): 28 Nm
Carrier to spindle("ribbed combi bolts"): 125 Nm
Brake hose to caliper(banjo union and bolt): 35 Nm
Tie rod end self-locking nut: 45 Nm
runonbeer is offline   Reply With Quote
Old April 21st, 2004, 11:44   #2
mgwerks
Fuel Economy: 51/47/42
rob
I have a bentley and will get these to you in the morning if no one else has by then
mgwerks is offline   Reply With Quote
Old April 21st, 2004, 11:48   #3
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Oil pan bolts around the perimeter are 11 ft/lb and the onest that go into the tranny case horizontally are 33 ft/lb. Don't ask me how I know these offhand. I would think it would be real hard to torque those 11 ft/lb ones in some spots.
POWERSTROKE is offline   Reply With Quote
Old April 21st, 2004, 12:24   #4
tsterkel
AND RIVNUTS!, thanks!
[ QUOTE ]
ALH engine:
Drian plug: 22
Cam bearing cap: 15
Vacuum pump: 15
Valve cover: 7
Cam sprocket: 33
T-belt tensioner: 15
IP sprocket bolts: 18
Engine to Body mount: 30 + 1/4 turn
Engine mount to body mount: 44 + 1/4 turn
Crank shaft bolt: 80 + 90 degrees
*Oil pan bolts:
*Front seal carrier bolts:
*Rear seal carrier bolts:
*Flywheel to crank bolts:
*Pressure plate to flywheel bolts:
Starter bolts:
*Oil filter housing bolts:
Serpentine belt tensioner: 18
Thermostat housing:
*Connecting rod bolts:
Large timing belt roller: 30 + 1/4 turn
Small upper timing belt roller bolt:
Small lower timing belt roller nut:
Intake Manifold to head bolts:
*Cylinder head bolts:
Injection pump to bracket bolts:
Water pump bolts: 11 (?)
Engine mount to engine bolts:
So, obviously you can tell that I have been frequently asking myself what some of these are.
I don't have a bently (well I do but...long story)
and I work on my car alot. I'd rather not over torque a bunch of stuff on my car.
If any of you guys know these, I would sure appreciate you letting us all know what they are. I'll come back and edit this post as they come along.
I did a bunch of searching, but trying to find specific stuff like this is a bear if you don't already know where to look.
I'll put a star by the ones I really need.
Thanks!
(and could we stickey this till it gets filled in?)
If anyone has any suggested additions to the list, I'll stick 'em on here.
-rob
[/ QUOTE ]
tsterkel is offline   Reply With Quote
Old April 21st, 2004, 12:40   #5
mgwerks
Rivnuts are 30 ft/lbs.
Old April 22nd, 2004, 05:16   #6
runonbeer
This was really just a roundabout way to avoid asking directly for these torque specs:
found 'em yet 'werks?
Old April 22nd, 2004, 18:17   #7
runonbeer
bump
Old April 22nd, 2004, 20:46   #8
MOGolf
MOGolf's Avatar
[ QUOTE ]
[/ QUOTE ]
60Nm + 1/4 turn
13Nm (2 part flywheel); 20Nm (1 part flywheel)
30Nm + 1/4 turn (oiled threads and contact surfaces)
tighten in the proper sequence to 40Nm, then 60Nm, then 1/4 turn, then 1/4 turn
MOGolf is offline   Reply With Quote
Old April 23rd, 2004, 06:14   #9
runonbeer
thanks MOGolf.
Old April 26th, 2004, 12:27   #10
runonbeer
This is so handy [img]/images/graemlins/smile.gif[/img]
Old April 26th, 2004, 17:29   #11
MOGolf
MOGolf's Avatar
*Front seal carrier bolts: fit sealing flange with all bolts lightly tightened, then tighten in alternating sequence to 15 Nm
*Rear seal carrier bolts: 15 Nm
M12x55 (qty 3) 80 Nm
M12x150 (qty 2) 80 Nm (starter bolts)
M10x50 (qty) 3) 60 Nm
M7x12 (qty 3) 10 Nm
Starter bolts: 80 Nm
Thermostat housing: 15 Nm
Small upper timing belt roller bolt: 20 Nm
Small lower timing belt roller nut: 22 Nm
Intake Manifold to head bolts: 25 Nm
Injection pump to bracket bolts: 30 Nm
Water pump bolts: 11 ft-lbs
Engine mount to engine bolts: 33 ft-lbs
Old April 26th, 2004, 18:52   #12
runonbeer
and there we have it: an all in one, fully searchable, useful thread.
Hmm perhaps they should be alphabetical...nope.
Old April 26th, 2004, 22:31   #13
PlatinumGLS
How much do you guys torque down your wheels?
PlatinumGLS is offline   Reply With Quote
Old April 27th, 2004, 08:31   #14
runonbeer
I've always gone w/ 85-88 ft-lbs.
Old April 27th, 2004, 10:25   #15
runonbeer
2 more:
Injector hold down brackets: ?
Glow plugs: ?
Page generated in 0.11829 seconds with 9 queries
[Output: 123.23 Kb. compressed to 103.08 Kb. by saving 20.15 Kb. (16.35%)]
