Old January 15th, 2007, 21:05   #31
rdkern
Fuel Economy: A4 = wife drives it, don't know
Hissing probably isn't good. Are you getting any codes? Is it warm enough for you to recognize any codes?
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old January 25th, 2007, 12:11   #32
tornadored7
TDI(s): Golf MK3
Firstly many thanks for an excellent and well written diagnostic guide.
I have been experiencing low power at higher revs. Having just replaced the MAF I knew it probably wasn't that.
A local mechanic performed a VAG-COM fault code scan revealing one error:
00575 Intake Manifold Pressure, 17-10 Control Difference - Intermittent. The symptoms seem to match closely.
I was snooping around the engine, aquanting myself with the various hoses (required in step 2 of the diagnostic procedure), red, blue, black and Air intake (Intercooler-engine) to ECU hose.
Two main things alarmed me;
1) There seems to be engine oil leaking from a few places, but mainly from around the a) Crankcase breather regulator valve, b) the Camshaft cover and also from c) the Air intake pipe (Intercooler to engine) to ECU sensor hose.
2) Removing the Air intake (to ECU) hose, revealed engine oil leaking out.
Issue 2 is the most suprising. At low engine revs, air pressure can be felt, but at about 1600 RPM oil starts leaking out in addition to air.
Since this is hose is coming from an air intake pipe, I think something is clearly very wrong somewhere.
Would appreciate some advice on what is likely to be wrong, and also how to proceed.
Thanks.
tornadored7 is offline   Reply With Quote
Old January 25th, 2007, 12:13   #33
tornadored7
TDI(s): Golf MK3
Sorry in addition to the above forgot to mention:
Car: Golf MK3 TDi
Engine: 1Z (90 BHP)
Old January 28th, 2007, 15:10   #34
tornadored7
TDI(s): Golf MK3
The code is mentioned (but slightly hidden in the text);
Mechanic read VAG-COM fault codes as 00575:Intake Manifold Pressure -> 17-10:Control Difference Intermittent.
Old January 28th, 2007, 21:04   #35
Donny O.
Originally Posted by GoFaster
Step 2: Troubleshooting the "00575 Intake manifold pressure control difference" code
Usual symptoms: car temporarily runs OK after being started, but particularly in the higher gears, it loses power abruptly after a period of running under load. Power may or may not return temporarily by taking load off the engine and then resuming, and generally returns temporarily after switching off the ignition until the same load conditions occur again.
now this is exactly what my car started doing today....i've had it for 2 weeks. anyway should the check engine light be comming on if it's throwing the 00575 code? this happens at about 3000rpm in 4th gear but resets by turning off and on, but I get no check engine light. I have no way myself of checking the codes i would have to take it somewhere, but as i said i get no CE light when it happens. however I do ocasionaly get one on startup which I was told by the previous owner was jsut a common problem with the glow plug check, but they were jsut replaced.....no ill running when this happens.
Donny O.
96 VW Passat TDi "00"
Bought 1-11-07 w/287K
334K as of 1-11-08
yup 46K in one year then the mods begin
Current: 386K miles
MODS...Muffler, Catectomy, RC3, Sprint 520's, B4 wagon springs, bilsten TC's
pictures of my vehicles
community.webshots.com/user/hondarrman
Donny O. is offline   Reply With Quote
Old January 29th, 2007, 21:00   #36
rdkern
Donny - check the "diagosing power loss" sticky. Really good read.
Read all about it!
Old January 29th, 2007, 22:16   #37
Donny O.
that is what this thread is.....but it says you get a code, but I'm not getting a check engine light..
Donny O.
334K as of 1-11-08
Current: 386K miles
Old January 30th, 2007, 08:14   #38
rdkern
A code will not always throw a CEL. Scan it to see if one's there.
Read all about it!
Old January 31st, 2007, 00:15   #39
Donny O.
good info...jsut what I needed. thanks!!
Donny O.
334K as of 1-11-08
Current: 386K miles
Old February 10th, 2007, 16:15   #40
khb137
I am have the same problem that you disscrib
did you find a fix
ken
khb137@msn.com
khb137 is offline   Reply With Quote
Old February 14th, 2007, 01:20   #41
Donny O.
did you find a fix
ken
khb137@msn.com
if you are refering to me then no. it has been a cold spell here the past few weeks(maybe part of the issue??) and didn't dare stand outside and work on the car. just don't get on it where it cuts off at and it has been fine!!
Donny O.
334K as of 1-11-08
Current: 386K miles
Old February 22nd, 2007, 18:57   #42
jim_arndt
Angry A code will not always throw a CEL
I confirmed this. I just bought a 97 Passat B4, the CEL light was on when I looked at it. I had the owner have the codes pulled, it came back with 00575. His mechanic cleared the codes and advised him to watch it.
I bought the car two weeks later, the CEL was not lit and the owner said he did not experience any loss of power.
Unfortunatly on my 60 mile drive home, I noticed a loss of power. Not being familiar with the car I wasn't exactly sure if this was normal or not. After a weeks worth of driving, it's clear it's entering limp mode.
My Vag-Com arrived today, this is what I got:
2 Faults Found:
00575 - Intake Manifold Pressure
17-00 - Control Difference
Time to start checking vacuum lines, and send Bruno to go collect from the previous owner.....
jim_arndt is offline   Reply With Quote
Old February 23rd, 2007, 14:47   #43
rdkern
Congratulations on the B4. And on knowing what's probably wrong with it.
Take apart the ecu - (which chip do you have?) and replace that little chunk of hose in there. You're going to love it when it's "right".
Read all about it!
Old April 18th, 2007, 22:32   #44
Steve777
Looking for a bit of help with the vag-com readings here...
Which measuring blocks are they speaking of when checking the injection quantity etc? When I go to the engine and measuring blocks they are empty. Do I enter in the number for the block I want?
TIA
Steve777 is offline   Reply With Quote
Old August 26th, 2007, 08:39   #45
caddy shack
Fuel Economy: 35 constant
Cool good article
This sounds like the problem I am haveing except I have a p-box and .216 injectors and was wondering if thy could be senting me into limp mode. When I get on it it will boost up to 20-22 psi when it is cold after it warms up If I go over 15 it will go into limp mode and won,t go above 12.
caddy shack is offline   Reply With Quote
Page generated in 0.15265 seconds with 9 queries
[Output: 123.07 Kb. compressed to 102.27 Kb. by saving 20.79 Kb. (16.90%)]
