Old April 12th, 2004, 17:40   #1
NewToTDI
Default Jetta Front License Plate Bracket Installation
I've been searching the archives for the instructions for installing the front license plate holder on a Jetta TDI without much luck. Could someone please post the link.
Thank you.
NewToTDI is offline   Reply With Quote
Old April 12th, 2004, 18:12   #2
RichC
RichC's Avatar
Fuel Economy: 26MPG across the board
I don't have link for you but have a question that might get answered while others view this thread. I have the black plastic plate that fits US plates on the front bumper. I have 4 screws holding my license plate in place, YET when going through a car wash the whirling brushes bend my license plate 90 degrees everytime. Any stiffer or cover that other have found to attach around the plate that works???
RichC is offline   Reply With Quote
Old April 12th, 2004, 19:27   #3
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
The plate holder just screws through the bumper cover. That's all. Make sure you get it good and square first though.
jasonTDI is offline   Reply With Quote
Old April 12th, 2004, 19:41   #4
nolongerhonda
Fuel Economy: so far 1170kms on 59.901 litres
The Canadian model has a black plactic frame that the plate mounts to. This frame is form fitting to the bumper cover and actually sits quite flush. I would check with the dealer they should have a part listed I would imagine.
nolongerhonda is offline   Reply With Quote
Old April 12th, 2004, 20:37   #5
MOGolf
MOGolf's Avatar
A link.
MOGolf is offline   Reply With Quote
Old April 13th, 2004, 08:14   #6
NewToTDI
Thank you for the link!
Old April 13th, 2004, 20:03   #7
nolongerhonda
yeah that's the one. in New Brunswick it is the law that we run front plates so they are all equipped from the dealer. I received two tickets in the past for not having a front plate...friggin police..
Old April 15th, 2004, 19:54   #8
paramedick
paramedick's Avatar
Rich, I have metal one for the A3 Jetta sitting here. Just walked outside and test-fitted it to the 03 Golf. Fits decently.
Differences are the screws go in the bumper just below the rub strip, and has two legs that go under the bumper and are fastened from underneath. Has a lip that completely surrounds the license plate to prevent bending. Substantial metal, painted black.
Part # 1HM807997. Around $10 at IMPEX.
Old April 16th, 2004, 06:00   #9
RichC
RichC's Avatar
Thanks Bruce ... that is what I've been thinking too. I've own a couple of those "I'd rather be..." type plate surrounds in the past and was wondering if they would add enough stiffness to prevent bending? What I do dislike about most of them is that they get rather pitted easily and tend to make cleaning the bugs off one step harder.
I've been contemplating a backing plate to my front plate that would crimp the outside edges to keep from 'flipping 90 degrees' when a brush whirls at it. Either that or never use that $4.00 'desalting' car wash again! [img]/images/graemlins/grin.gif[/img]
Old January 21st, 2011, 20:51   #10
Lost680
Fuel Economy: 40 HWY
I know this is a old thread, but i need to mount a front plate on a 2006 jetta
I just want to learn how.
Lost680 is offline   Reply With Quote
Old January 22nd, 2011, 05:10   #11
T_D_I_POWER
T_D_I_POWER's Avatar
Here's mine, no bumper drilling req'd. on a B5.5. S/B the same for others
I used all stainless steel hardware.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old February 1st, 2011, 18:13   #12
J H Musser
TDI Power,
Could you provide some more info on your license plate set up? Did you make it, did you buy it, if so where. Thanks in advance.
J H Musser is offline   Reply With Quote
Old May 27th, 2013, 11:30   #13
aggieengnr
aggieengnr's Avatar
Fuel Economy: avg 38 mpg
^^^what he said.^^^
2004 Jetta GLS PD-TDI, 09A auto
2004 Dodge Ram 2500 4x4 w/ NV5600 6-speed; "60 HP" injectors, 5" TB exhaust, Valair dual-disc clutch, Smarty tuner
'84 Ford Ranger 2WD w/ STOCK 2.2l 4.135 Mazda-built Perkins NA diesel
aggieengnr is offline   Reply With Quote
Old May 27th, 2013, 15:40   #14
T_D_I_POWER
Thx for asking
The plate is B5 license plate bracket. I bought it from a vw vortex member for $20.00. Search the web, VW/Audi forums as they are cheaper.
The license plate clear cover I got it from wallyworld. To install clear cover to license plate bracket, I used 4-2" L no.8 or 10 stainless pan head Philip machine screws, 4-no.8 or 10 stainless nuts, and 4-2" no.8 or 10 stainless oversized fender washers.
I placed the fender washers behind the two horizontal slats as you can see from the picture no.2 above.
//TDI POWER
2004 B5.5S
Old May 27th, 2013, 16:05   #15
JSWTDI09
JSWTDI09's Avatar
There are a number of other front plate mounting options that do not require drilling or punching holes into your bumper. You can wire-tie it to a grill or several companies make front license plate brackets that screw into the tow hook holes already in the bumpers of most cars. A search for front license plate will discover several threads about the various options you have.
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Page generated in 0.13783 seconds with 9 queries
[Output: 120.14 Kb. compressed to 99.28 Kb. by saving 20.87 Kb. (17.37%)]
