GoFaster
Moderator at Large
A few weeks ago, while driving in traffic, my clutch pedal dropped right to the floor and would not come up, while I continued driving!
The problem involved the plastic clip that connects the clutch pedal to the push-rod that goes into the clutch master cylinder. A local VW dealer did a "get-you-home" fix while the plastic clip ($1.70) was on order. A week later, they put the new clip in, but it still wasn't right, and then they were telling me that the clutch pedal was worn out ...
Fast forward to today, I didn't have time to fiddle with this so I took the car to my local independent mechanic, who determined that the REAL problem is that the dealer did not snap the clip in place over the ball-end of the push-rod properly. Clutch pedal is fine. To do it right, you HAVE to unbolt the clutch master cylinder from within the engine compartment, and then he said it was an absolute bear to get that clip onto the end of the push-rod (which probably means it's not gonna come off again for a long time). After that - no more linkage problem.
But ... and here's the kicker. The clutch now engages almost at the top of its travel and I can slip it under load. I knew it was on the way out anyway, but the worn-out clip had masked the real point where the clutch engagement was occurring. I know by the way the clutch pedal feels now that my clutch is SHOT. Been down that road before (but not with this car).
So, if your clutch pedal drops to the floor, have a look at that clip, and make sure the new one gets put on there properly, and SOON. Too much limping around trying not to shift gears finished off my clutch!
This failure occurred at 364,000 km, for reference - other hi-milers take note.
