Old December 29th, 2013, 09:00   #46
lisab4
lisab4's Avatar
Is it still 3a0145838C for the 1Z?
1996 Passat B4 1.9TDI 1Z
lisab4 is offline   Reply With Quote
Old September 6th, 2014, 06:40   #47
mikerancourt
TDI(s): 1998 Jetta
Fuel Economy: My first veggie oil trip was 558 veggie miles on somewhere between 11 and 12 gallons, so 50 at the most, 46.5 at least I THINK)
Originally Posted by airic View Post
FYI
If you need to know, the hose from napa can be cross referenced to a 1990 &gt;&gt; Chevrolet Truck &gt;&gt; K1500 1/2 Ton 4WD - Pickup &gt;&gt; 6.2 L 379 CID V8 Diesel
Upper radiator hose
Yep a diesel
The Autozone part number for the upper radiator hose for the 1990 k1500 diesel is E71476. I haven't tried it yet, and obviously, I think Napa is a better place to get parts, but I'm posting this for folks who might be in a pinch and need to get it at Autozone.
mikerancourt is offline   Reply With Quote
Old September 13th, 2014, 20:28   #48
GEE-BEE
TDI(s): 1.9 AAZ
Lightbulb Silicone replacement
Somebody send me a old hose with your o.d' you want
I will make a tool and make you tthe 3 or 5 ply silcone with correct s/s clamps included
any color
GB
N77GB@MSN.COM
800-556-3160 PST
I can do anything in silicone...
http://www.thesamba.com/vw/classifie...php?id=1321070
http://www.thesamba.com/vw/classifie...php?id=1630565
GEE-BEE is offline   Reply With Quote
Old March 18th, 2015, 14:14   #49
tdipig
TDI(s): 97 Jetta 94k
Fuel Economy: 46mpg
2" 30 degree el from silicone intakes worked perfect for me
tdipig is offline   Reply With Quote
Old September 29th, 2015, 20:10   #50
Mousey1
TDI(s): MK3 jetta
Default quick questions guyssss
quick question guys i need the hose that runs from the intercooler to the egr its the rubber hose in the front of the bay on the drivers side is this what you guys are talking about or is this for the hose that goes from the egr to the hard piece
Mousey1 is offline   Reply With Quote
Old September 30th, 2015, 18:55   #51
tdidieselbobny
tdidieselbobny's Avatar
From the egr to the hard piece....
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 23k miles....'16 Kubota BX1870 MMM/FEL, 100hrs!And now an '03 Jetta TDI 5spd w/ 420k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is offline   Reply With Quote
Old October 1st, 2015, 06:26   #52
Steve Addy
TDI(s): 97 Mk3
This discussion thread is for a replacement hose from intake manifold (where EGR is located) to first hard plastic intercooler pipe, but only on Mk3 tdi cars. B4 cars use a different hose in that location.
Is the location above what you're talking about?
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is offline   Reply With Quote
Old July 21st, 2016, 13:54   #53
Stromaluski
Stromaluski's Avatar
Originally Posted by JetBlu View Post
Originally Posted by JETaah View Post
Here is another choice for a replacement hose.
This one nails the molded angle perfectly.
Something like $11.00- makes 2
Just updating for anyone needing this info.
http://www.amazon.com/Gates-21405-Lo...6866691&sr=1-1
Compatibility Chart
F-250 1983-1987 6.9L V8 Lower w/AIR COND MOLDED COOLANT HOSE
F-250 1988-1993 7.3L V8 Lower w/AIR CONDOLDED COOLANT HOSE
F-250 1994 7.3L V8Lower EXC F ENG CODEw/31" WIDE RAD
F-350 1983-1987 6.9L V8 Lower w/AIR CONDMOLDED COOLANT HOSE
F-350 1988-1993 7.3L V8 Lower w/AIR CONDMOLDED COOLANT HOSE
F-350 1994 7.3L V8 Lower EXC F ENG CODEw/31" WIDE RAD
Autozone part #C71216. FYI. Just blew this hose on mine.
-Andrew
Stromaluski is offline   Reply With Quote
Old July 27th, 2016, 05:19   #54
Stromaluski
Looks like somebody in Poland is making a reproduction.
http://www.ebay.com/itm/252033628703
-Andrew
Old August 22nd, 2016, 16:45   #55
Sleet
Sleet's Avatar
That's a great find!
Has anyone here tried this hose? and if so how did it fir/work? Does it fit as good as the OEM part?
I used a radiator hose about 6-10 years back (can't remember exactly when it blew out) but it finally has gotten to the point where I think it's leaking and causing my limp mode issue.
I'm curious about this reproduction part from Poland but just figured I'd ask if anyone had tried it yet since it shows 21 people have purchased it on ebay as of today (8-22-2016)
98 Jetta 1.9 tdi
bought @ 127k currently has 223k
RC2/3 & CatII, PP520's
Sleet is offline   Reply With Quote
Old August 23rd, 2016, 06:13   #56
Stromaluski
I bought one, and have been very happy with it so far. I had a radiator hose for about a week. It has a larger wall thickness than the factory hose, which makes the clamps a bit of a bear to take on/off. Reproduction looks almost exactly like factory to me, based off of memory since I got rid of my factory hose before getting the reproduction one. I'd definitely buy another one.
-Andrew
Old August 23rd, 2016, 07:18   #57
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
[QUOTE=Sleet;5130026
[/QUOTE]
I have no idea how you got that long out of a generic radiator hose... i replace mine every year as it gets soft from oil. if that ebay hose holds up for even 2-3 years.. id say its worth its price, and i suspect it will last much longer if it really is made to be oil resistant as the ad says.
2003 Jetta TDI - 11mm IP, “stage 1ish” DIY tune.
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old September 13th, 2016, 18:05   #58
GEE-BEE
TDI(s): 1.9 AAZ
VW Turbo Pressure Hose Part Number "1H0 145 838 F"
BORA PRTS HAS ONE IN STOCK ( FIRST ARTICLE )
WE HAVE 12 IN PRODUCTION FOR THEM RIGHT NOW...
GEE-BEE
Old September 19th, 2016, 13:51   #59
otm646
Fuel Economy: 54/48.5/43
I bought 2 of the reproductions from Poland. They were a bit thicker (wall diameter) than the original hose but they held up well for 2+ years before I sold the car.
It's a solid buy.
76 300d 475k
97 750IL V12 working SLS 187k!
98 Jetta AHU 330k! PD150 intake 2.5 SS straight pipe- Sold to Papa Validius
05 WRX 5 speed wagon 220k + flow mods ~270 HP
81 Lancia Beta Zagato
otm646 is offline   Reply With Quote
Page generated in 0.15997 seconds with 9 queries
[Output: 121.82 Kb. compressed to 101.90 Kb. by saving 19.92 Kb. (16.35%)]
