Old November 23rd, 2009, 11:57   #31
rallyruss
rallyruss's Avatar
I ordered a 45 deg. silicone hose for mine but it was too short. had to add a pipe and a straight section of hose. Its holding up fine but is leaking a bit. looking for a better fix. I wont use the rubber hose solution as Im sure it would fail at the worst possible time. You know, like when your wife who wants the car replaced is driving it.
Im guessing that we could have some custom made but it would probably cost as much as the dealer.
98 TDI jetta BillyHDs, Softsports, 16"wheels, corrado brakes, running B99. PP520s and chip to match and some other stuff....250k+
(Hers) 05 Passat TDI GLS wagon. Unchained, Koni FSDs, RC2, audi S4 wheels and full tint.
rallyruss is offline   Reply With Quote
Old November 23rd, 2009, 14:23   #32
tdidieselbobny
tdidieselbobny's Avatar
Use the rubber hose-I had mine on for over 2 years,and most of that was with a tune......just check it every oil change.
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 27k miles....'16 Kubota BX1870 MMM/FEL, 160hrs!And now an '03 Jetta TDI 5spd w/ 426k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is online now   Reply With Quote
Old January 23rd, 2010, 09:39   #33
bloc
My concern with the non-OEM rubber hose is the inside layer deteriorating and possibly coming loose, then some part of it going into the intake manifold.
This isn't as simple as saying "it's cheap, replace it when it fails". Not that I like the OE $120 hose either.. just that I'm going to try and find a silicon replacement.
2013 Touareg TDI
bloc is offline   Reply With Quote
Old January 23rd, 2010, 13:52   #34
tdidieselbobny
If you find some silicone hose that fits,please post part#,price and where purchased from.Use the rubber one as a temp. fix if the OEM has a split (like mine did).
Old May 9th, 2011, 18:22   #35
snagster
Default Had the same problem.....
Hose was split on the top. This was the one going into the turbo intake, right on the top right of the motor.
I was unable to get out so... I took it out and cleaned it really good with some carb and intake cleaner to get the grease off. Then I took some electric tape and double wrapped it really tight. Not my first choice, but it worked. No more hissing sound and no more LIMP mode.
Thanks...
snagster is offline   Reply With Quote
Old May 9th, 2011, 19:51   #36
tdidieselbobny
Maybe go over the black electrical tape w/ some black duct tape.......maybe I'll try that-I kept the original one.
Old May 31st, 2011, 13:29   #37
camocarmen
TDI(s): 1998 Jetta
Thanks for the help, guys. I just picked up one of the NAPA 8460 hoses. I wanted to replace the clamps and the clerk suggested & sold me some heavy duty ones especially for diesels. I don't know if they'll make a difference but wanted to post that if any other newbies will benefit from the info.
Camo
camocarmen is offline   Reply With Quote
Old December 5th, 2011, 08:51   #38
redbeard
Default One other option
I came up with another option for this intake hose section. I used to have the radiator hose fix. It blew out after 2 years, so I tried to find a better option this time.
In researching this, I found that McMaster-Carr has 100 psi hydraulic hose with a 6" bend radius - Perfect. The problem is their minimum order is 5' and with shipping it would have been ~ $60.
I ended up finding some 2" ID 150psi hydraulic suction hose locally that works great. In Rapid City we have a place called Industrial Supply Company sells it by the inch (.90/in). I bought 8" ~ $8.00 with tax. They also sell 150psi pressure hose but the suction hose seemed a bit more flexible.
The hardest part was getting a straight cut since there are wire supports molded into the tube. I used a chop saw with an abrasive wheel to get a decent cut - with a LOT of smoke.
It was a bit of a fight trying to get it to fit the bend so I used screw clamps to make sure it doesn't pull itself off.
Hopefully this helps the next TDI in limp mode.
P.S. I've got a pic, but am having trouble getting it to show up in this post. If I get it figured out, I'll add it.
redbeard is offline   Reply With Quote
Old December 5th, 2011, 10:48   #39
redbeard
Sorry, can't figure out the image posting thing. Maybe I don't have the right permissions or something cause I don't see the "Manage Attachments" button that the FAQ says I should have.
Old October 2nd, 2013, 06:43   #40
G60ING
G60ING's Avatar
Originally Posted by tdidieselbobny View Post
And another bump for another member-wish this could get a sticky.......
Just ask or better yet get somebody to make a FAQ thread with links to other threads like this one
G60ING is online now   Reply With Quote
Old October 2nd, 2013, 06:57   #41
compu_85
Gadget Guy
compu_85's Avatar
I can stick this thread
Present:
2018 Tesla Model 3 DM. 2500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old December 1st, 2013, 14:42   #42
Tinman265
Summit racing sells a 2" - 45 silicone hose that is 6" long on each end. You can even get different colors! Got the angled hose out of it and 2 - 2-3" long interconnecting hoses. Win win.
Tinman265 is offline   Reply With Quote
Old December 19th, 2013, 20:48   #43
QuickGLX
TDI(s): 97 Jetta TDI
$8 Shipped.
http://pages.ebay.com/motors/link/?n...d=190862463379
QuickGLX is offline   Reply With Quote
Old December 23rd, 2013, 08:37   #44
16vjohn
This is the one I used on my 98', it has lasted years already, but it does sweat a little oil. I just wipe it off every time I do oil changes. It hasn't gotten soft and has never blown off.
Originally Posted by JETaah View Post
Here is another choice for a replacement hose.
This one nails the molded angle perfectly.
Something like $11.00- makes 2
16' Fusion Energi // 12' Honda Odyssey
Retired: 15' Jetta TDI 45k // 13' Passat 22k, Buyback // 01' Jetta TDI 177k // 98' Jetta TDI 291k // 00' Jetta TDI 240k // 91' 300D 2.5T // 90' Jetta TD
16vjohn is offline   Reply With Quote
Old December 27th, 2013, 09:29   #45
G60ING
G60ING's Avatar
Originally Posted by QuickGLX View Post
I have silicone hoses like this on my TDI and they sweat oil like the rubber ones.
Page generated in 0.14900 seconds with 9 queries
[Output: 127.77 Kb. compressed to 106.87 Kb. by saving 20.89 Kb. (16.35%)]
