Old September 5th, 2007, 14:19   #16
biopete
For search engine:
VW Turbo Pressure Hose Part Number "1H0 145 838 F"
1998 Beetle tdi
biopete is offline   Reply With Quote
Old July 19th, 2008, 08:40   #17
CaptainKirk
CaptainKirk's Avatar
Fuel Economy: 65/48/42
Smile Split Intake Hose substitute
I know Stan TDI has probably fixed his hose by now but I just used the Napa replacement hose and it worked just fine. It gives a very snug fit and is flexible enough to do the job. The price is up to $23.xx with a Napa discount card compared to $99 + shipping from Impex or more from the stealer dealers. You also get 2 for the price so I have a spare when one of the hoses on another car splits.
I would have used the CarQuest hose Jetaah refers to with the exact angles on the hose but we don't have any CarQuest stores in our area.
2002 Jetta RC3, PP520, Black, for the wife
1998 Jetta RC2/RC3, Black, for the son
1997 Passat RC3, Black, for the daughter
We have our own Mini TDI club in our driveway.
1998 Jetta RC2/RC3, PP520, Black - who will get this one?? Everyone but me - Daughters use it for school...
1997 Passat Silver RC3, maybe this one's for me, were running out of drivers. - Went to #2 son.
1997 Passat Black RC3 - Went to #2 daughter.
2002 Jetta, Silver, T4's - Ahh Finally.. my own Jetta!!
CaptainKirk is offline   Reply With Quote
Old September 13th, 2009, 16:02   #18
ta79pr
ta79pr's Avatar
TDI(s): 02 TTQ (BEW)
Fuel Economy: avg. 43
how long did these end up lasting?
ta79pr is offline   Reply With Quote
Old September 13th, 2009, 16:28   #19
tdidieselbobny
tdidieselbobny's Avatar
I think I have about 2yrs. on the one I have now(at least 30k miles)-and it is kinda greasy feeling(oil seepage through rubber) now-time to put the 2nd half of original hose on.I did keep the oem hose as a backup also....
97 Passat TDI-420,688 miles,totalled by 86yr.old lady-gone,but not forgotten-'15 Silk Blue Golf Sportwagen w/DSG, 27k miles....'16 Kubota BX1870 MMM/FEL, 160hrs!And now an '03 Jetta TDI 5spd w/ 426k,RC2,Sprint 520's,Dieselgeek short shifter and oil bypass, and a few other goodies....
tdidieselbobny is online now   Reply With Quote
Old September 17th, 2009, 19:38   #20
CaptainKirk
Mine is still going strong with no signs of deterioration or leakage.
captainkirk
Old September 18th, 2009, 03:51   #21
G60ING
G60ING's Avatar
You may want to consider wrapping those rubber hoses with Zip ties. The rubber once it begins to get soaked with oil from the inside gets spongy and deteriorates. They will expand easier then the boost hoses because the hose even when new is weaker then the OEM boost hoses but after being soaked in oil they get progressivly weaker. The Zip ties will help reenforce them.
G60ING is offline   Reply With Quote
Old October 29th, 2009, 18:42   #22
JetBlu
JetBlu's Avatar
TDI(s): 2002 Jetta
Fuel Economy: 46 mpg
Just updating for anyone needing this info.
http://www.amazon.com/Gates-21405-Lo...6866691&sr=1-1
Compatibility Chart
F-250 1983-1987 6.9L V8 Lower w/AIR COND MOLDED COOLANT HOSE
F-250 1988-1993 7.3L V8 Lower w/AIR CONDOLDED COOLANT HOSE
F-250 1994 7.3L V8Lower EXC F ENG CODEw/31" WIDE RAD
F-350 1983-1987 6.9L V8 Lower w/AIR CONDMOLDED COOLANT HOSE
F-350 1988-1993 7.3L V8 Lower w/AIR CONDMOLDED COOLANT HOSE
F-350 1994 7.3L V8 Lower EXC F ENG CODEw/31" WIDE RAD
Originally Posted by JETaah
Here is another choice for a replacement hose.
This one nails the molded angle perfectly.
Something like $11.00- makes 2
2002 Blue Jetta- Ventectomy, 5-speed manual swap, Black Leather swap, VagTacho key programming. Hybrid Oilpan, PP520's, HammerMod IQ=6, DG ShortShifter, Zerostart, ONCCV, Neuspeed LS w/TC sports. Coming Soon- DG Panzer
1984 MB 300sd (diesel)
1970 Olds 442- 6 mpg(not diesel )
2005 Acura TL
-T-
JetBlu is offline   Reply With Quote
Old October 30th, 2009, 15:32   #23
tdidieselbobny
I put the old OEM hose back on for the heck of it- a week or so after I did,I could hear a different noise coming fron under the hood on heavy acceleration-then I noticed the back corner of the valve cover was wet w/ oil-finally looked at it closer and the OEM hose had a split....I put the second piece I got from hose #21405 on and all is well again.
Old November 10th, 2009, 05:18   #24
papadelogan
papadelogan's Avatar
TDI(s): 96 B4 TDI
Fuel Economy: 43mpg average (85% HW)
Out of curiosity, does someone have a picture of the engine showing which hose we're talking about please? I'm still new to my TDI. Thanx!!
papadelogan is offline   Reply With Quote
Old November 10th, 2009, 10:19   #25
paramedick
paramedick's Avatar
It's the hose in the left of the picture. Runs from the lower boost tube to the intake in the A3 Jetta.
Old November 11th, 2009, 07:22   #26
papadelogan
TDI(s): 96 B4 TDI
My B4 doesn't have this hose. All hard plastic tubes with rubber "joins" that are maybe 2" - 3" in length. Is this only for A3's then?
Old November 11th, 2009, 10:39   #27
MTjake
TDI(s): 3
Fuel Economy: very good
It looks identical to the hose that exits the intercooler on the B4's before it joins a hard plastic hose trending upwards (in front of the left front wheel well, underneath). One of these split open on the wagon that uses higher boost. I don't know if it's the same VW part, but the replacements shown here ought to work for either application.
Down to one 1996 B4V.
T4b MV with AHU and 3 pedals. 2015 GSW.
Some tools available for free use, here (but it's an uncovered, unheated, gravel driveway)
MTjake is offline   Reply With Quote
Old November 11th, 2009, 11:09   #28
paramedick
paramedick's Avatar
Correct, A3 only for the intercooler pipe to intake hose.
Old November 12th, 2009, 13:00   #29
a350z4me
TDI(s): 98 Jetta TDI
Man I wish I saw this last week. $117 from the dealer. At least mine is oil resistant.
a350z4me is offline   Reply With Quote
Old November 21st, 2009, 15:44   #30
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Blew mine today......thanks for the info guys! On the bright side, my boost spike is gone temporarily!
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Page generated in 0.15999 seconds with 9 queries
[Output: 127.08 Kb. compressed to 105.56 Kb. by saving 21.53 Kb. (16.94%)]
