Old March 8th, 2004, 20:43   #1
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Default A3/B4 split intake hose substitute.
$17 at NAPA. I was able to cut it in two places, and get two replacements from one hose. It fits a bit tighter due to a slightly smaller inside diameter, but I'd rather it be tight than loose. and as far as material goes, I don't really care how long it lasts, they cost me less than $10 a piece and it takes about 5min. to install so if it blows out within 10K miles, so what...
Sure beats the $75 that VW wants for it
Hope that helps someone.
runonbeer is offline   Reply With Quote
Old March 9th, 2004, 09:30   #2
Locosmotion
Fuel Economy: LOTS
Excatly my thoughts. 10-20 bux for a radiator hose can be replaced 3 times for what vw wants. BTW my autozone #175 replacement is still holding, I havent driven the car much but it shows no signs of swelling from the oil.
Locosmotion is offline   Reply With Quote
Old March 9th, 2004, 16:41   #3
runonbeer
Not only that, but I got two replacements out of the one $17 hose. Its a no brainer.
Old March 12th, 2004, 08:04   #4
Bookerdog
Fuel Economy: Not known yet
Good find runonbeer. And the picture has the part number clearly visible. For the search engine I will put, you can replace the intake manifold boost hose with part number pn # 8460 from NAPA or Autozone 175
Bookerdog is offline   Reply With Quote
Old March 12th, 2004, 18:41   #5
runonbeer
radiator hose, low boost, NAPA, leaking boost, split hose, replace, price, low cost....
Old March 17th, 2004, 15:19   #6
braunfels_tx_tdi
TDI(s): A3,98,white
Fuel Economy: 45
hey that looks better than the way I jimmy'd mine!
Hey I also need to come clear this code when you have a chance.
braunfels_tx_tdi is offline   Reply With Quote
Old June 7th, 2005, 19:37   #7
geez
Default Re: A3/B4 split intake hose substitute.
Thanks for the part number on the hose!!! Easier than trying to look 12 feet in the air and guess at each hose and make the guy bring another hose down...
geez is offline   Reply With Quote
Old June 13th, 2005, 20:52   #8
Oo-v-oO
Oo-v-oO's Avatar
I tried two different Autozones and they both said #175 was an incomplete number, there was supposed to be a letter in front of it. Either one of the pimply-faced kids behind the counter could figure out what that letter might be. There's only 26 possibilities....
I picked up the NAPA hose, just a shade under $20. Fits pretty well, thanks! My original hose almost made it to 200K, I think it began splitting at 199,850 miles. I have the leftover piece in the trunk as a spare.
Oo-v-oO is offline   Reply With Quote
Old July 11th, 2005, 18:53   #9
airic
FYI
If you need to know, the hose from napa can be cross referenced to a 1990 &gt;&gt; Chevrolet Truck &gt;&gt; K1500 1/2 Ton 4WD - Pickup &gt;&gt; 6.2 L 379 CID V8 Diesel
Upper radiator hose
Yep a diesel
airic is offline   Reply With Quote
Old July 13th, 2005, 15:11   #10
braunfels_tx_tdi
TDI(s): A3,98,white
Fuel Economy: 45
I used a straight piece and forced the bend and it's still working, Robby's is cleaner looking though.
Old August 20th, 2005, 09:43   #11
JETaah
Fuel Economy: 53 max, 42 min, average 46
Here is another choice for a replacement hose.
This one nails the molded angle perfectly.
Something like $11.00- makes 2
JETaah is online now   Reply With Quote
Old May 15th, 2007, 18:55   #12
Stan TDI
Default A question about the hose
I went to NAPA to pick up this hose and the one that matches this part number is almost an S shape. I want to make sure it is the right one. The part was for a slightly different vehicle also. Comments please?
2002 Jetta GLS - auto to manual, VR6 clutch, sprint 205s, panzer full metal jacket, DG short shifter
2002 Jetta GLS - stock for now
Stan TDI is offline   Reply With Quote
Old May 16th, 2007, 11:09   #13
darkscout
Grammar Scout
darkscout's Avatar
TDI(s): 2003 Golf
He cut in in 2 and got 2 parts. That looks like 1/2 of an 'S' to me.
[Review]: ECS Mk4 Rear Hatch Pop Kit. 0/5 stars for Rear Hatch Popping. 5/5 stars for inflicting head trauma.
It's all just cheap chinese **** with a fancy vortex bling bling spin that attracts people
darkscout is offline   Reply With Quote
Old May 16th, 2007, 18:07   #14
Stan TDI
Thank you for your response darkscout. However, it does not really answer my question. I would appreciate a response from anyone who actually used this part. The way I see using this part is to cut off the first part of the S since this is basically a half oval. The second part of the S is more like the Carqwest part above. There is also a slight twist in the second part. Comments from anyone who has actually used this please?
Old May 19th, 2007, 06:40   #15
Stan TDI
No takers?
Page generated in 0.17854 seconds with 9 queries
[Output: 119.54 Kb. compressed to 99.24 Kb. by saving 20.30 Kb. (16.98%)]
