Old February 4th, 2004, 21:19   #1
Heston
Heston's Avatar
Fuel Economy: 6.9/5.5/4.6 (L/100km)
Default Suitable cleaning solution for Clogged EGR System
What brand or type of solutions can i (or should) use to assist with clean out all the GUNK I suspect is clogging my EGR Intake Manifold System?
I couldn't find anything specific in the FAQ, Forums, or published Procedure PDFs here.
Thx, Heston
Heston is offline   Reply With Quote
Old February 4th, 2004, 22:04   #2
Keli_OR
Keli_OR's Avatar
My understanding is that it's a remove and scrape out process.
I have yet to hear of any type of additive that can be used to clean it out.
K
Keli_OR is offline   Reply With Quote
Old February 5th, 2004, 00:48   #3
zinkengruven
Fuel Economy: 52.2/48/43
Hey Heston,
This is the procedure:
http://www.cst.cmich.edu/users/willi...AKEMAN101b.htm
Either that, or pay a shop $$$ to do it. Depends if you have more time or money. [img]/images/graemlins/smile.gif[/img]
zinkengruven is offline   Reply With Quote
Old February 5th, 2004, 06:19   #4
Nutsnbolts
Nutsnbolts's Avatar
Fuel Economy: Average is about 46 now (2016)
I have found that once the manifold and EGR are removed, use Castrol Supe Clean (purple stuff, purple bottle), let it soak, then hit it with a high pressure hose such as a self service car wash. Rinse and repeat. The results are astounding!
-Rich
Nutsnbolts is offline   Reply With Quote
Old February 5th, 2004, 06:34   #5
wrenching40plus
I thought about a couple of solvents, like printers' roller wash, acetone, etc... but your idea sounds definitely worth trying, because it poses no real risk to plastics in the EGR valve. Two questions: (1) did you clean out the ports into the head, and (2) how much time over-all did you spend on the job?? Obviously I've gotta face the same issues [img]/images/graemlins/frown.gif[/img] Thanx!
wrenching40plus is offline   Reply With Quote
Old February 5th, 2004, 07:46   #6
Heston
Heston's Avatar
Thanks for the info.. After reading the Intercooler Cleaning Article I was starting to think that a solvent was required for the EGR Intake Manifold.
Old February 5th, 2004, 07:51   #7
Heston
Heston's Avatar
Thanks Rich.. Since I have access to a second vehicle, I will consider the Castrol Super Clean soak and rinse idea.... unless someone has a negative comment about this specific solution of course.
Old February 5th, 2004, 09:53   #8
samiam
I just used a gallon of paint thinner for $2. You can put a skim coat of RTV on a piece of cardboard, mount accross on end of the intake(head side or inlet), then fill that puppy up and let it sit. Drain, and powerwash- it will come perfectly clean.
Michael
samiam is offline   Reply With Quote
Old February 5th, 2004, 09:59   #9
Paul_L_Fisher
I haven't used it on a TDI but when I cleaned my SHO intake I used Berryman's B-12 CHEMTOOL® CARBURETOR AND CHOKE CLEANER
Paul_L_Fisher is offline   Reply With Quote
Old February 5th, 2004, 14:06   #10
eicke
[ QUOTE ]
-Rich
[/ QUOTE ]
Ditto! .......takes a couple of times to get all it out. With a bottle brush and the hottest water that comes out of your tap, Super Clean does work! Wear latex gloves as the Castrol make your hands look like Grandma's!! [img]/images/graemlins/eek.gif[/img] [img]/images/graemlins/eek.gif[/img]
eicke is offline   Reply With Quote
Old February 5th, 2004, 15:16   #11
mgwerks
Fuel Economy: 51/47/42
You can take them off and take them to a machine shop. A guy near here cleans and then bead-blasts them like new - $15.00. Such a deal.
Make SURE that they don't get sandblasted!
mgwerks is offline   Reply With Quote
Page generated in 0.15568 seconds with 9 queries
[Output: 94.62 Kb. compressed to 79.53 Kb. by saving 15.09 Kb. (15.95%)]
