Old January 12th, 2004, 12:41   #1
btc231
Default Turn signal problem
2001 Golf GL TDI - 5 speed
This just started yesterday and is very annoying.
Every time I use my turn signals the relay/stwitch keeps clicking about 10-15 times after the turn signal is off. It seems to click more times when I use the left signal, I can also hear it clicking when I first start the car.
Checked all lights - they look OK, couple months ago I replaced the glove box cover my self - I wonder if that may be the problem.
I will hate to bring the car to the dealer and spend 150+ for something that may be as simple as light bulb or relay.
btc231 is offline   Reply With Quote
Old January 12th, 2004, 12:44   #2
GeWilli
GeWilli's Avatar
Fuel Economy: you keep track?
are the turnsignals going on and off with the clicking? or is it just clicking with no lights?
GeWilli is offline   Reply With Quote
Old January 12th, 2004, 12:44   #3
weedeater
Fuel Economy: 54/43/38
Probably the switch. You might find a used one around here if you ask around.
The relay is behind the hazard switch and is user-replacable.
weedeater is offline   Reply With Quote
Old January 12th, 2004, 12:48   #4
btc231
Just clicking - no lights
Old January 12th, 2004, 12:57   #5
jaydhall
Oooohm oooooh! FINALLY! Someone ELSE has this problem! [img]/images/graemlins/smile.gif[/img]
Ok, I THINK I know how it happens. Have you ever used armor all or similar product on your instrument panel clear cover? (Bezel?)
If so, that is what I believe happened to mine. I also have some ideas on a fix. It DOES go away after a while. Then I went to a carwash where they did the armor all on the instrument panel. Yep, after about 3 weeks or so it started happening. We need to talk about this! [img]/images/graemlins/smile.gif[/img]
jaydhall is offline   Reply With Quote
Old January 12th, 2004, 13:48   #6
btc231
I had the car washed couple of days ago at full service car wash. But I asked for the basic wash - vacuum the inside and dry out side. I noticed the guys made an attempt to wipe the dash - pretty sorry job as I can see large spots of dust. So it is possible for them to have sprayed something on the instrument panel, I couldn't smell
anything and the interior is pretty dusty I doubt they used armor all.
I take it you are suggesting I do nothing for couple of weeks and see if the clicking goes away.
Old January 12th, 2004, 16:09   #7
jaydhall
The first time mine clicked for MONTHS! So far this time it has been clicking for weeks... [img]/images/graemlins/frown.gif[/img]
Old January 12th, 2004, 19:34   #8
Pawel23
I have a 2001 Jetta TDI, I have the same problem with the turn signals. It goes on anf off it's been like this for about 2 months!! Gets annoying. I did use armo all while cleaning the car could that be the problem?
Pawel23 is offline   Reply With Quote
Old January 12th, 2004, 19:57   #9
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
[ QUOTE ]
[/ QUOTE ]
Could be, or could just be a coincidence? The hazard switch is a known problem. I bet if you change it, all will be good.
Edit: I was wrong! Mine is now doing the same thing. I tried changing the relay with 2 new ones and it still makes the noise.
Wingnut is offline   Reply With Quote
Old January 12th, 2004, 20:51   #10
jaydhall
I can only go with what happened with me. I changed hazard switch/ turn signal relay because it died. About a year later I armor alled my dash glass. The funny noises started soon after. A LONG time later they stopped. Fine for over six months. (I have a bad memory but this is what I remember!) Then armor all again and funny noise again. Too much of a coincidence. My vote is the armor all causing the problem. The cure is patience.
Old January 13th, 2004, 02:05   #11
FlyTDI Guy
FlyTDI Guy's Avatar
Fuel Economy: 56.5/44/41
You should have used dielectric Armorall... [img]/images/graemlins/crazy.gif[/img]
FlyTDI Guy is offline   Reply With Quote
Old January 13th, 2004, 06:49   #12
btc231
Can you post instructions on how to replace the switch?
Is this the same as the turn signal relay?
Old March 17th, 2004, 12:13   #13
l_c
Fuel Economy: 50/45/42
I have this annoying problem in my 2002 Jetta TDI Wagon.
I'm a bit confused -- should I go after the switch itself, or the relay first? Larry.
l_c is offline   Reply With Quote
Old March 17th, 2004, 14:24   #14
l_c
I'm guessing it's the relay contacts (mechanism) ... I just went
and bought a new relay for 31 USD from VW. (Will append here
in case that doesn't resolve the problem); Larry.
Old March 17th, 2004, 14:59   #15
jaydhall
I hope it does fix it but I will be real surprised if it does. Let us know.
Page generated in 0.17527 seconds with 9 queries
[Output: 114.24 Kb. compressed to 94.34 Kb. by saving 19.90 Kb. (17.42%)]
