Old January 8th, 2004, 22:12   #1
gern_blanston
Fuel Economy: 51/47/40 (Same as the CBR)
Default Fuel gel temperature?
Here's a question for all you dieseloids: At what temperature does fuel gelling actually become a problem?
There are an awful lot of people claiming gelling problems at temps well above 0 degrees Fahrenheit. My job entails turning diesel fuel into happy trails at 41,000 feet, and we're only required to keep our 'diesel' (they call it 'Jet-A') warmer than -40. We don't run Jet-B or additives. Now I realize that jet fuel's not precisely the same as diesel (I do know of one operator that ran diesel in their King Air for years with no apparent problems), but I can't see a 50 degree F difference in the freezing point.
Is it just water freezing in the lines or filter? Or is the stuff we run in our cars so crappy that it gets gunky at 15 degrees? Any wisdom would be appreciated.
gern_blanston is offline   Reply With Quote
Old January 9th, 2004, 00:40   #2
Grady
Grady's Avatar
TDI(s): '01 Jetta
Its the wax in the diesel fuel.
http://www.chevron.com/prodserv/fuel.../L2_2_6_fs.htm
PARAFFIN WAX
All middle distillate fuels will precipitate paraffin wax when they are cooled to a low enough temperature. Paraffin wax is a solid mixture of crystalline hydrocarbons, primarily straight chain hydrocarbons, plus some branched chain and cyclic hydrocarbons (see Chapter 4). When it is oil-free, this wax melts in the range 100F to 180F (40C to 80C). Paraffin wax occurs naturally in all crude oils; the amount depends on the specific crude oil(s) from which it was produced and on the processing used.
As fuel is cooled, it reaches a temperature at which it no longer is able to dissolve the waxy components, which then begin to precipitate out of solution. The temperature at which wax just begins to precipitate and the fuel becomes cloudy is the cloud point as measured by ASTM D 2500.
If the fuel is cooled below the cloud point, more wax precipitates. At approximately 6 to 10F (3 to 5C) below the cloud point (for fuels that do not contain a pour point depressant additive) the fuel becomes so thick it will no longer flow. This temperature is called the pour point or gel point as measured by ASTM D 97.
Jet-A fuel info:
http://www.chevron.com/prodserv/fuel...l%5Fintro.shtm
When the commercial jet industry was developing in the 1950s, kerosene-type fuel was chosen as having the best combinations of properties. Wide-cut jet fuel (Jet B) still is used in some parts of Canada and Alaska because it is suited to cold climates. But kerosene-type fuels Jet A and Jet A-1 predominate in the rest of the world.1
Jet A is used in the United States while most of the rest of the world uses Jet A-1. The important difference between the two fuels is that Jet A-1 has a lower maximum freezing point than Jet A (Jet A: 40C, Jet A-1: 47C). The lower freezing point makes Jet A-1 more suitable for long international flights, especially on polar routes during the winter.
However, the lower freezing point comes at a price. Other variables being constant, a refinery can produce a few percent more Jet A than Jet A-1 because the higher freezing point allows the incorporation of more higher boiling components, which in turn, permits the use of a broader distillation cut. The choice of Jet A for use in the United States is driven by concerns about fuel price and availability. Many years of experience have shown that Jet A is suitable for use in the United States, especially for domestic flights.
Grady is offline   Reply With Quote
Old January 9th, 2004, 03:19   #3
gern_blanston
Well that answers that. Thanks. I guess I owe you a root beer.
Page generated in 0.12749 seconds with 9 queries
[Output: 55.57 Kb. compressed to 50.47 Kb. by saving 5.10 Kb. (9.17%)]
