Old September 10th, 2007, 07:50   #16
rodejetta
TDI(s): Jetta2001
What did you find, in short? I am a newbie and must say that all these threads are somewhat overwhelming. I want to get a vag-com, but want it working with Linux (suse, like you have works great for me!) Thanks, Hans
Originally Posted by DerekA86
I found my answer. sorry for posting like a newb and not doing enough research. late.
rodejetta is offline   Reply With Quote
Old October 10th, 2007, 19:55   #17
mlconnell
mlconnell's Avatar
TDI(s): 2004 GLS TDI
Fuel Economy: 40 Mpg City.
Default OBD Cable
Originally Posted by BeartheBruce
It should be located behind a panel to the right of the steering column as shown here: http://www.ross-tech.com/vag-com/cars/dlc.html#b3
Hey guys does that connector behind the steering column in that picture on this link take an OBD II cable? This is exactly like my connector in my 2004 Golf TDI but I'm not sure which kind of cable I need to buy? Any help would be appreciated. Thanks
Michael C. --
--> 2004 Reflex Silver Golf TDI GLS - 43k Miles
--> 2001 Reflex Silver Jetta GLS VR6 - 67k (SOLD)
-->1998 Green Jetta GLS - 118k (SOLD)
mlconnell is offline   Reply With Quote
Old October 15th, 2007, 15:11   #18
miguelandrade100
TDI(s): Golf TDI
I have a Golf TDI 199.5 and same times the engine lights is on.What is the problem?
Miguel
miguelandrade100 is offline   Reply With Quote
Old October 15th, 2007, 15:25   #19
mlconnell
mlconnell's Avatar
Default 1995.5
Miguel
Miquel what other lights are on when the engine light is on? It would be hard to tell the error without a VAG-COM to read the error.
Michael C. --
Old March 22nd, 2008, 10:27   #20
Pilhoney10
Please Help: I have 5 fault codes P1144,P1549,P1441,P1252,P0380 Can someone help me with this?? What do i need to do??
Philip
Pilhoney10 is offline   Reply With Quote
Old June 23rd, 2008, 20:19   #21
CharlesH
TDI(s): 2006Jetta
after reading the faq this product is junk to me.
'73 yellow beetle, 127k, (2 miles since '83) needs TLC
"You would not do that if I was driving my truck!"
yelled at anyone driving crazy around me
CharlesH is offline   Reply With Quote
Old June 24th, 2008, 04:58   #22
owr084
That's a pretty bold statement from someone who does not own one. Just what is it you think is junk about VAG-COM?
RBB
2005 VW Passat GLS TDI (Chipped, BSM delete, and Manual ), 2007 VW Eos 2.0T, 2015 Toyota Sienna XLE, 2017 VW Jetta SEL 1.8T
owr084 is offline   Reply With Quote
Old September 10th, 2008, 19:08   #23
vflflyer
vflflyer's Avatar
Fuel Economy: 45-48
I am thinking about buying a vag-com cable but do not know wich one I need and if it is worth buying, since I will only be using this for personal use (Will it benifit me?) and will also let people use it that are local.
I have a 2003 jetta tdi 1.9l non pd (not sure what pd means but the engine does not look the same as mine as I have seen this in the Bently manual). Manual 5sp trans., power windows/locks. I am located in the an Diego area.
Also will version 409 do everything I need, as I was thinking of buying a cable from ebay or do you guys really think it is worth it to spend alot more money and get the one from Ross
vflflyer is offline   Reply With Quote
Old September 10th, 2008, 20:46   #24
Lee_Taylor
Lee_Taylor's Avatar
PD refers to the type of injection system. Yours is an older engine with a seperate injection pump. The PD's have individual injector pumps in the cylinder head.
As to whether or not it is worth it, only you can answer that question. A lot of people here did as I did and bought a cheap cable on Ebay and used version 409 but ended up getting the real McCoy. Once you register it the program is very useful. If you plan on owning more than one VW to my mind it's worth buying the real thing. Not least because it uses the latest version of the software. Version 409 is ok, but only if you have the licensed version and if you switch laptops you have to bugger about and de-register it. If you plan on doing a timing belt change on your car you can use VCDS to check the timing.
There are lots of things you can do with the cable which the Ross Tech site explains. Like any good tool it costs money but you can tell a lot about the kind of mechanic by the quality of their tools.
you can't make a machine idiot proof, the idiots are just too powerful......Oilhammer
Lee_Taylor is offline   Reply With Quote
Old September 16th, 2008, 08:38   #25
GoGolfing
Fuel Economy: 44mpg
Default Anyone load and work with latest Ross Tech Vagcom ver 8?
I downloaded this and went to measuring blocks and cannot seem to find any address 0-255 that will display TURBO Info like boost...
Is anyone aware of any documentation that spells out meas blocks for A4 cars?
Thanks in advance.
GoGolfing is offline   Reply With Quote
Old October 3rd, 2008, 17:52   #26
Northof60
Northof60's Avatar
Location: Whitehorse, YT <--Just South of the middle of nowhere.
TDI(s): 2002 Jetta
Just a note for anyone in the Yukon. I have a Vag-Com Unit. Drop me a PM if any help is needed.
2002 Jetta TDI 270,000+km
2001 Jeep TJ (wish it was a Diesel)
2009 Ski-Doo Skandic WT 600
1993 Ski-Doo Formula-MX 470
Yukon Territory: A wonder of nature. The only place in the world with two seasons. Winter and Not Winter
Northof60 is offline   Reply With Quote
Old October 4th, 2008, 10:09   #27
DanG144
Thanks in advance.
There is plenty of boost information, it is called MAP (manifold absolute pressure) and measured in millibars.
You are used to seeing boost in psi, probably. You can find conversion data online. Remember to subtract atmospheric pressure.
If you print out the label files with a text reader, such as notepad, you can read through the groups and find what you need. It is best to log RPM, specified MAP and actual MAP, and N75 duty cycle.
Old January 3rd, 2009, 12:33   #28
dentchristian
TDI(s): 98 Jetta
Default 16 pin female VAG-COM plug location for a 98 Jetta TDI
Hey People:
Does anyone know the location of the VAG-COM 16 pin female plug for a 98 VW jetta tdi?
dentchristian is offline   Reply With Quote
Old January 3rd, 2009, 12:48   #29
DanG144
I think it is in the center console, behind/above the ashtray? Whiterock? SC?
Dan
Old January 3rd, 2009, 18:37   #30
P2B
P2B's Avatar
Beside the ashtray, behind a plastic panel with an engine icon on it. Remove ashtray and slide cover panel towards steering column.
Simon
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Page generated in 0.17333 seconds with 9 queries
[Output: 123.19 Kb. compressed to 102.08 Kb. by saving 21.11 Kb. (17.13%)]
