Old November 4th, 2003, 20:08   #1
VW Derf
Administrator
Fuel Economy: 5.9L / 100km
Default VAG-COM OBD Scanners references/FAQ
Below are the links to VAG-COM FAQs and references. If you are aware of others that should be here, let me know.
If you have some technical references or FAQ's for other OBD Scanners, let me know and I'll start a "sticky" for that as well.
Here is the current "list":
<ul type="square"> [*] VAG-COM FAQ [*] Common Diagnostic Procedures
* Ross-Tech TDI section
* 1998-2003 VW MkIV Golf/Jetta/New Beetle Information Page[*] TDI Timing Checker (not for PDs)[*] "Aftermarket Radio Problem"
[*] "Butt Dyno" Instructions [/list]
VW Derf is offline   Reply With Quote
Old September 19th, 2004, 13:33   #2
MinnesotaTim
Fuel Economy: 49,44, 38
Thanks for the help with my login issues. I went through Ross-Techs manual and my bentley last night, but didn't stumble into the TDI specific stuff until I saw the link on your post.
Tim
MinnesotaTim is offline   Reply With Quote
Old August 19th, 2006, 23:24   #3
BugBug
Fuel Economy: 44 to 47 MPG
* 1998-2003 VW MkIV Golf/Jetta/New Beetle Information Page[*] TDI Timing Checker (not for PDs)[*] "Aftermarket Radio Problem" [*] "Butt Dyno" Instructions [/list]
I have used the Autoxray EZ-Scan 5000 on a 2001 and a 2006 TDI Beetles. The Autoxray tool will monitor, scan codes, reset the 'Check Engine' light and more.
http://www.autoxray.com/products.aspx?sub=scanners
EDIT:
Update. I have recently purchased the VAG-COM. This is The best engine/car diagnostic tool I have used so far. A must have!
BugBug is offline   Reply With Quote
Old January 4th, 2007, 08:04   #4
Keith_W
Default Where is the OBD2 port?
Somehow I've missed it, I keep poking around the fuse box, console... Where is it? Do I have to remove something? '98 Passat tdi.
k
Keith_W is offline   Reply With Quote
Old January 4th, 2007, 08:31   #5
Airliner
Either:
Above drivers feet. You don't have to remove anything.
or:
Below the parking brake handle (between front seats). You have to remove a little "hood".
Airliner is offline   Reply With Quote
Old January 4th, 2007, 09:41   #6
Keith_W
Default Oops: what year is it again?
My Bad. I have a '96 Passat. I bet it doesn't have OBD2, does it? What was I thinking? Too many vehicles in my brain.
K
Old January 4th, 2007, 19:04   #7
BeartheBruce
BeartheBruce's Avatar
It should be located behind a panel to the right of the steering column as shown here: http://www.ross-tech.com/vag-com/cars/dlc.html#b3
-Bruce-
Ross-Tech, LLC
Bruce@Ross-Tech.com
BeartheBruce is offline   Reply With Quote
Old April 18th, 2007, 11:55   #8
Warthog
TDI(s): see Bio
Fuel Economy: VW:49-53 depends on car, 40-0n the B5
If "hidden", it's behind a little panel somewhere on the dash that has a picture similar to the MIL (Engine malfunction light) pressed into it. The engine block outline with the lightning bolt thru it...otherwise. Pry it out/off gently...the socket is usually pink or purple.
Warthog is offline   Reply With Quote
Old July 19th, 2007, 14:06   #9
DerekA86
Default Vag-com Linux?
So, I haven't needed to use my vag-com in a while...and since last use I wiped my only windows laptop of M$ completely, and I have been a happy suse user since. So, is there any support for Mac or linux out there? I think my only option is running the program under wine, but I was wondering if anyone else has tackled this problem, and how you did it. Thanks folks
2001 Jetta TDI
VAG-COM, KEY-USB interface
DerekA86 is offline   Reply With Quote
Old July 19th, 2007, 15:30   #10
DerekA86
I found my answer. sorry for posting like a newb and not doing enough research. late.
2001 Jetta TDI
Old July 19th, 2007, 21:35   #11
TurboHokie
Fuel Economy: 67 MPG (best), 48 (avg)
Has anyone had any luck with other VAG-COM software suites that are on the market aside from the Ross Tech option? I'm looking for something that will pull accurate VW specific codes and allow me to reset the CEL. 02 Jetta.
TurboHokie is offline   Reply With Quote
Old July 20th, 2007, 18:13   #12
Sebastian
This will definitly do the job...
Sebastian
Sebastian is offline   Reply With Quote
Old September 3rd, 2007, 05:57   #13
Lee_Taylor
Lee_Taylor's Avatar
It's also a bit like a Rolls Royce. If you need to know how much it costs you probably can't afford it.
Lee_Taylor is offline   Reply With Quote
Old September 6th, 2007, 02:59   #14
samekongen
samekongen's Avatar
TDI(s): VW T4 151 hp
Default Vag-com passenger airbag
Can the Vag-com turn of the passenger airbag, (so I safely can fit a baby seat there?
samekongen is offline   Reply With Quote
Old September 6th, 2007, 03:23   #15
Sebastian
Depends on the specific year make and model, basically the airbag control module generation is what decides that.
Sebastian
Page generated in 0.16650 seconds with 9 queries
[Output: 119.79 Kb. compressed to 99.12 Kb. by saving 20.67 Kb. (17.26%)]
