Old December 31st, 2007, 16:38   #46
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Well, when I did the tranny swap on my cabriolet, I propped the engine up on a breezeblock and didn't pull the flanges so I'm going to see if I can get away with that again. I also managed to get the transmission down (and up) on a flat piece of wood on top of a floor jack . Overall, I would have preferred a tranny jack but really, it wasn't that awkward without (I have seen also where someone bolted the flat piece of wood to the jack via some drilled holes. Might try that).
One thing I might do this time is pull the driver's side half-axle. That is one nut, gives a bunch of clearance and was the only thing that really caused any aggro refitting the transmission.
if none of the stretch bolts are too critical, I may skip that at this point and retro that this summer when the weather is better. I really need to sort out a Bentley.
Richy_T is offline   Reply With Quote
Old January 1st, 2008, 21:23   #47
Powder Hound
Powder Hound's Avatar
Originally Posted by hevster1
The easiest way so far I have found is to remove the x-member completely. You gain so much room both on disassembly and reassembly. ...
I second this remark. I had no help and finally gave up after not being able to get the transaxle back up to mate with the engine. Dropped the sub frame after removing the 4 steering rack bolts. There are only 4 large bolts needed to drop the sub frame. Replacing the subframe takes a jack on one side. Line it up and screw in one bolt finger tight. Do one on the other side. Now you can replace the last 2 bolts, and tighten everything together. These large bolts are even much easier to stretch (the last "+ 90 " turn after reaching torque) than the short flywheel bolts were.
I just wish I had dropped the sub frame on disassembly - it would have saved me hours. And you only have to replace the 4 subframe and 4 rack bolts.
Old January 2nd, 2008, 20:56   #48
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Originally Posted by 2footbraker
Flywheel bolts are all you really should replace but yes, there are some stretch bolts it wouldn't hurt to replace. When I did mine, I replaced the tranny mount bolts, dogbone mount bolts, the gear selector bolt and the inner CV bolts. If I was to do it again I probably wouldn't even bother replacing them though.
OK. So the pressure plate bolts are reusable then? Could someone tell me what the torque should be on these? (I won't be able to get a manual before the parts arrive). I'm guessing they might be a bit different from a gasser Cabriolet
Also, has anyone come up with a bodgers alternative to that flywheel lock tool? Or is it something you can free-rent from Autozone? (I can always weld something up in a pinch).
Rich
Old January 2nd, 2008, 21:54   #49
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Nope... Bentley says "always replace"...
On Dual Mass Flywheels, they're tightened to 13 NM [edit: CD version says 22... my book version of the Bentley says 13 NM... Newer update to CD also says 13...]
On Single Mass Flywheels, they're tightened to 20 NM
Then there are the transmission support bolts (just like the engine support bolts that need to be replaced), and probably some of the transmission-to-engine bolts (but I can't locate that part in my Bentley right now...)
Yuri.
PS: for the flywheel lock... Wingnut improvised something from a large hookeye that went on a bolt and got wedged in the teeth of the flywheel...
ymz is offline   Reply With Quote
Old January 3rd, 2008, 06:34   #50
visionlogic
visionlogic's Avatar
Fuel Economy: 47 avg
On Dual Mass Flywheels, they're tightened to 22 NM
For pressure plate bolts my CD Bentley says:
On two-part flywheel: 13 Nm
On single piece flywheel: 20 Nm
For a flywheel holding tool I just used a piece of 1/8th thick angle iron about 4 feet long with a single hole for a pressure plate bolt in one end. Bolt it to the flywheel. As the flywheel turns while you are tightening a flywheel bolt one of the pressure plate alignment pins on the flywheel will swing around and jam against the edge of the angle iron, the other end of which is in contact with the floor. No more rotation & your flywheel bolts can be torqued properly. Works in the opposite direction too, so you can loosen the original bolts.
Living outside the statist quo... "All the disasters that have wrecked your world came from your leaders' attempts to evade the fact that 'A' is 'A' ." -- John Galt | On Google+
visionlogic is offline   Reply With Quote
Old January 3rd, 2008, 08:16   #51
ymz
So does my book version (data closed April 15, 2003)
My more recent CD version (updated last October) gives the 22 and 20 NM figures...
Interesting...
Yuri.
Old January 3rd, 2008, 08:42   #52
speed185187
speed185187's Avatar
TDI(s): 03 Jetta GL
I can't wait to start my clutch change now. Thank you
02 Jetta GLS TDI
03 Jetta GL TDI (parts)
2018 Subaru Outback Limited (her's)
speed185187 is offline   Reply With Quote
Old January 3rd, 2008, 09:50   #53
ymz
Interesting...
Just downloaded a newer update... now it's back to 13 NM...
Fascinating...
Yuri.
Old January 4th, 2008, 06:41   #54
PDJetta
PDJetta's Avatar
Interesting...
Yuri.
They changed the torque value on the engine mount big bolts as well, at some point, too--no more "plus 90 degrees" turn, but with a higher single torque value.
--Nate
Old January 10th, 2008, 20:26   #55
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Interesting. Since the pressure plate bolts aren't stretch, I'm tempted not to bother replacing them. OTOH, if the manual says to, it's cheap insurance to do it properly. I'll nip along to the stealership tomorrow and see a) if they have them in stock and b) how white my face goes when they tell me the price.
Other than that' I'll just try and get the stretch bolts that hold the transmission in. There's a lot of "always replace" items in there and I'll give good odds that no dealer actually ever replaces them.
Rich
Old January 11th, 2008, 05:11   #56
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
Fuel Economy: 850-1000 Km vented
I'd say change them, because they are very small and even a bit of corrosion can chew them fast. Also, it's not worth 4-5 hours of labour (to take the tranny out) to replace some tiny 50 cent screws
2010 Grey Audi A4 Avant 2.0 TFSI Quattro
2004 Tornado Red Audi A4 Avant 1.8T Quattro
Sold: 2003 Reflex Silver Golf TDI
RIP: 1999 Green Passat TDI GLX
RIP: 1999.5 Red Golf TDI
Doc_Oc is offline   Reply With Quote
Old January 11th, 2008, 05:21   #57
PDJetta
PDJetta's Avatar
Just make sure you have the correct socket for the PP bolts. Mine required a 9 MM 12-point socket, I think.
--Nate
Old January 11th, 2008, 06:07   #58
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
Same here.
Old January 16th, 2008, 19:33   #59
oil_me
oil_me's Avatar
Fuel Economy: 51,38,43
I've used a 7mm or 8mm allen key stuck in one of the engine mounting holes to lock the flywheel on all 15 VW engine swaps.
'91 GlacierBlue Audi 80Q M-TDI 51.8 mpg http://www.motorgeek.com/viewtopic.php?f=6&t=45645 http://forums.tdiclub.com/showthread.php?t=344436
'99.5 Black Jetta TDI, 200k, '02 ALH, 11mm IP, RC3+,Titan/nozzles PDliftpump, Racepipe, OMI, 2.5 SS exh., lower IC , Shine, Panzerplate,52/47
oil_me is offline   Reply With Quote
Old January 26th, 2008, 11:37   #60
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
OK. Everything is out finally. It was a job getting the transmission out. I would recommend removing the inner CV flanges to anyone else doing this. The right one was hard to get past the thin metal plate and the left one prevented the transmission sliding far enough to get past the clutch assembly easy. I lost quite a bit of metal from the bell housing sliding it backwards and forward. I don't think removing the flanges is completely trivial though (it was a pain to get them off on the old Cabriolet transmission) but probably worth it. I'm definitely seriously considering removing them before reinstall.
Unfortunately, I've hit a new snag. I ordered a 220 clutch kit but it looks like the one that's there is a 228 (is that a factory or aftermarket upgrade?) so unless I can scare one up today, it's probably going to be even longer until I'm back on the road
I've decided to just go with replacing the three bolts that hold the transmission mount on. Everything else should stand being reused as far as I can tell. I promise to past back here red-faced if it turns out I'm wrong
Rich
Page generated in 0.18753 seconds with 9 queries
[Output: 132.27 Kb. compressed to 110.10 Kb. by saving 22.17 Kb. (16.76%)]
