Old June 18th, 2007, 04:39   #31
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
The tools do come with the kit from DG. The 2 I have done I did on a lift. I refuse to hump out a trans on my back anymore.
NJ's best shop performing Quality Repairs on TDI's, Toyota, Lexus, Scion and other European and Asian cars as well as Motorcycles & ATV's. Written warranty, reasonable prices. ASE L-1 & A-9 Master re-certified. NEW LOCATION: Montague NJ. Hunter Wheel Alignment. Snap-on Tire Service.I don't need to have specials, my prices are better already!
www.mmautocycle.com
hevster1 is offline   Reply With Quote
Old July 27th, 2007, 08:13   #32
clintontull
clintontull's Avatar
TDI(s): NONE
wow, not looking forward to the clutch at all. also is the rear seal easy to change at that time too or do you have to pull the oil pan and crank?
KermaTDI is now on Facebook!
clintontull is offline   Reply With Quote
Old July 28th, 2007, 11:51   #33
Chemboy
You are supposed to pull the oil pan when the seal is replaced (a really easy procedure if you've just removed the transmission) so that you can properly apply new sealent between the oil pan and main seal.
If you need a rear seal, send me a PM - I bought one for just in case when I replaced my clutch, but ended up not needing it.
--Andy
Chemboy is offline   Reply With Quote
Old August 10th, 2007, 01:48   #34
Benjamin
Fuel Economy: 47 MPG Jetta, 23 MPG Jeep
Ok, just did a clutch on a 99.5 golf and ran into a tool that was not listed. Needed the 6 mm triple square to get the pressure plate off and thats the bolts that were holding it on. I spent a good portion of the day looking for one as you know when you need it, nobody has one around. I don't know if this is a LUK clutch thing, but just thought that I would pass along the info in case somebody else ran into the same thing.
Benjamin
If you see my car being driven like it was not stolen, call the cops, its stolen!
You want to play big you will pay big!
You know you own a diesel when going up the hill seems more fun then going down....
Benjamin is offline   Reply With Quote
Old September 14th, 2007, 11:57   #35
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
Fuel Economy: 850-1000 Km vented
--Andy
You are not supposed to take the oil pan off. It goes in no problem and you do not have to apply gasket maker on the bottom as it has a rubber gasket built in (the seal that is).
You don't need to take the half shaft out...but with the driver side one out...it is a breaze to get the tranny back up. Well worth the spilled oil and the 3 minutes to take it out.
2010 Grey Audi A4 Avant 2.0 TFSI Quattro
2004 Tornado Red Audi A4 Avant 1.8T Quattro
Sold: 2003 Reflex Silver Golf TDI
RIP: 1999 Green Passat TDI GLX
RIP: 1999.5 Red Golf TDI
Doc_Oc is offline   Reply With Quote
Old September 14th, 2007, 20:33   #36
clintontull
TDI(s): NONE
i didnt have the 17mm allen wrench to get the filler plug out so took some vice grips and one of the old engine mount bolts turned it around and it fit perfectly. yep had to take the drivers side half mount out. I was so determined to get it back in without out taking it out but after an hour i should have just done it. To everyone doing this. Take it off after you are able to drop out the trans. its so much much much much easier going in and safter than destroying a clutch too
Old September 16th, 2007, 07:05   #37
PDJetta
PDJetta's Avatar
The half mount? Is that the drive axle flange that is held into the transaxle by the single 6 MM allen head bolt? I was confused about whether or not to remove these, so I removed the passenger side one because it looked like it may get hung up on the flywheel when removing the transaxle. I was afraid if I removed them, their seals may leak later.
I had no problems getting the transmission out or in with the passenger side one attached (in). If I ever have to remove the transaxle again, I think I'll try without removing either of them.
--Nate
Old September 16th, 2007, 07:52   #38
hevster1
TDI(s): 98 NB
Fuel Economy: 40-42
The easiest way so far I have found is to remove the x-member completely. You gain so much room both on disassembly and reassembly. You do have to replace the control arm to ball joint, steering rack and x-member bolts and realign the car so I recommend if you decide to do it this way replace the ball joints and any other bushing or joint which is questionable this way killing 2 birds with one stone.
www.mmautocycle.com
Old September 16th, 2007, 11:00   #39
Chemboy
Actually, you are supposed to. Review the service manual again.
--Andy
Old September 16th, 2007, 23:36   #40
Benjamin
Um, to get the plug out if in a bind, the wheel bolts have a 17 mm head, put the bolt in the plug, also use a 17 mm open end wrench and just make sure you have a skinny wrench and most of the bolt in the plug. You can strip the plug if not carefull so don't say I didn't warn you. I have used this before, never had a problem yet.
Old September 17th, 2007, 09:00   #41
Doc_Oc
Doc_Oc's Avatar
TDI(s): 03 Golf TDI
--Andy
I look at the service manuals like I look at the speed limits. SUGESTIONS, just sugestions.
I did 3 seals without removing the oil pan and 2 years/100k later they are still sealing.
I can see why they say that and I agree with you that it is the best way of installing it. But the rubber in the mating face is pretty forgiving.
Old October 9th, 2007, 06:13   #42
clintontull
TDI(s): NONE
Welp clutch changed and the clutch was weird at first but after 800-1000 miles its back to normal and has seated it self well. NO SLIP what so ever.
Old December 30th, 2007, 14:27   #43
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
In preparing for a clutch swap, do any of the other fixtures and fittings need to be replaced? I think I heard something about the engine mount bolts are torque-to-yield bolts and need to be replaced?
Rich
Richy_T is offline   Reply With Quote
Old December 30th, 2007, 18:07   #44
mittzlepick
mittzlepick's Avatar
Fuel Economy: 1175 record tank
i held my engine up with a custom cut 4x4 and a winch strap 0 dollars
mittzlepick is offline   Reply With Quote
Old December 30th, 2007, 19:49   #45
2footbraker
2footbraker's Avatar
Flywheel bolts are all you really should replace but yes, there are some stretch bolts it wouldn't hurt to replace. When I did mine, I replaced the tranny mount bolts, dogbone mount bolts, the gear selector bolt and the inner CV bolts. If I was to do it again I probably wouldn't even bother replacing them though.
2006 Jetta TDI - Malone Tuning stage 4, G60/VR6, Vogtland 55mm/Koni Sports, Darkside GTB1749V, EGR delete, Frank's BRM cam, etc.
Several other IDI's and TDI's
2footbraker is offline   Reply With Quote
Page generated in 0.16227 seconds with 9 queries
[Output: 127.32 Kb. compressed to 105.70 Kb. by saving 21.62 Kb. (16.98%)]
