Old October 7th, 2003, 19:55   #1
phxvalkry
Fuel Economy: 46
Default Crankcase Ventilation
I am newe to this forum, I recently purchased a 2002 Jetta TDI. Have a 2002 Ford SuperDuty with the Powerstroke, thats a major reason I invested in a TDI..Diesels ya gotta luv em !! Anyway have read numereous posts about intake build up, my Jetta has 7800 miles on it, I use Rottela synthetic. Has anyone had any experience with the Racor crankase ventilation filters ?
phxvalkry is offline   Reply With Quote
Old October 7th, 2003, 20:58   #2
tadc
Fuel Economy: 45/42/37
Lots of threads about CCV filters around here. A couple guys are even selling their own designs in the for-sale section.
I think the general consensus is that the Racor units are too large to mount easily on the TDI.
tadc is offline   Reply With Quote
Old October 8th, 2003, 06:29   #3
Bookerdog
Fuel Economy: Not known yet
There was much talk a while back that Racor was going to make a smaller filter that would work on our motor. Unfortunately, it looks like nothing ever came of it. I know that one member had the 3500 installed on his car and he did like it, but it was definitely overkill. The current production models really simply are too large for our cars, we don't flow enough air for the 3500 to be as effective as it is on the bigger truck diesels.
I personally always wanted one, because it would be the best design for the A3, due to the fact that it has a drainback to the sump like our CCV design.
Bookerdog is offline   Reply With Quote
Old October 8th, 2003, 06:47   #4
PackRat
[ QUOTE ]
[/ QUOTE ]
I had a CCV filter on my TDI for a while and a great majority of the condensate was water mixed with oil. Not sure if I would want that draining back into the crankcase.
PackRat is offline   Reply With Quote
Old October 8th, 2003, 12:15   #5
Bookerdog
Well, with the stock CCV that's what's happening anyway, at least on the A3/B4. The Racor has a pretty stout filtration media that supposedly allows the heavy liquids like oil (and probably some water) drain back, while the gasses are filtered and returned to the standard intake tract.
Old October 8th, 2003, 17:27   #6
PackRat
Mine had a filter medium that trapped the oil/water and let it collect while the gases kept moving. I had to remove it when it completely iced up during extreme below zero temps and blocked the CCV.
Old October 8th, 2003, 17:55   #7
Curious Chris
Fuel Economy: 47/42/38
I am tester #19 of Old Navy's CCV mod and it is the ticket if you want your CCV to never freeze and significantly reduce oil in the intake.
Check out this in the classified where a group buy of the thoroughly tested OldNavy CCV mod is underway: http://forums.tdiclub.com/showflat.php?C...part=5&amp;vc=1
Curious Chris is offline   Reply With Quote
Old October 8th, 2003, 18:03   #8
MOGolf
MOGolf's Avatar
However, Old Navy's CCV filter is not designed for A3/B4 engines.
Note: This thread is currenly in an A3/B4 forum. The original poster has a A4 engine.
MOGolf is offline   Reply With Quote
Old October 8th, 2003, 18:41   #9
Old Navy
Old Navy's Avatar
Fuel Economy: 28 mpg on PU, 33 on Car
So MOGolf what would need to be done to make mine work with A3/b4 models? Maybe we can alter the A4 CCV to work in A3/B4's???
Old Navy is offline   Reply With Quote
Old October 8th, 2003, 19:04   #10
MOGolf
MOGolf's Avatar
See the pressure regulator in the upper right of this picture posted by ALCO? It has an additional hose connection.
Old October 9th, 2003, 18:34   #11
Weasle543
Fuel Economy: 49/45/36
What's that extra hose for? Is that the "elephant" hose?
Weasle543 is offline   Reply With Quote
Old October 9th, 2003, 19:26   #12
Old Navy
Old Navy's Avatar
Wish I had an actual A3 CCV. Anyone have a spare or can take some good pictures?
Old October 10th, 2003, 06:18   #13
Bookerdog
[ QUOTE ]
[/ QUOTE ]
I think you're talking about the big hose coming out on the left of the puck and headed toward the front of the engine? That indeed is an elephant hose mod. The picture is actually a little confusing, because there appears to be a third hose coming into the puck, but there is not. That's just where the original hose was removed and probably has an airfilter stuck on it.
The "extra" hose that the A3 has compared to the A4 is actually the hose on the right hand side, which is an oil drainback/lower crankcase pressure relief hose. It goes down to an opening on the block that opens into the oil pan. Nobody really seems to know what the heck the thing really does. But nobody wants to block it off because the lower crankcase pressure issues.
As far as the puck itself, there's absolutely nothing to it that I can tell. Just a plastic opening with an opening on the bottom and to openings on the side.
Old Navy, be sure to take a look at Oilhammer's CCV at the GTG next weekend. It would be great if we poor forgotten A3 folks could have the opportunity to purchase one of your fine filters for our cars.
Old October 10th, 2003, 09:01   #14
Chris Bell
[ QUOTE ]
[/ QUOTE ]
Nope. It is a crankcase pressure regulator valve. It contains a spring-loaded diaphram that closes the valve under conditions of high crankcase gas flow.
Chris Bell is offline   Reply With Quote
Old October 10th, 2003, 09:53   #15
dieseltwo
To phxvalkry member. CCV; I would use a Condensator for ccv. I believe you can not get anything better.TDI's. The Racor has a filter in it that will need replacing, at a cost. The Condensator you just take apart, wash it and put back together, real simple. Condensator does have a web page. Price wise it is costs less then a Racor and in the long run. You could make one like most do here, but would not work as good as the Condensator. You want the best, pay a little now or lot later. When I have a little extra cash, I will get one. Each their own, I guess. Good luck on your search. [Dieseltwo-Bradford-Ont.Can.]
dieseltwo is offline   Reply With Quote
Page generated in 0.13849 seconds with 9 queries
[Output: 117.74 Kb. compressed to 97.73 Kb. by saving 20.01 Kb. (16.99%)]
