Old September 24th, 2003, 11:26   #1
VWMark
Default Cost or TDI oil change?
For those of you that do not do your own service, what is the going rate of an oil change at the dealer? I am approaching 5000 miles and want to know what to expect. Please don't tell me to do it myself! [img]/images/graemlins/wink.gif[/img]
VWMark is offline   Reply With Quote
Old September 24th, 2003, 11:29   #2
20IndigoBlue02
20IndigoBlue02's Avatar
About $60 using the Castrol Syntec 5w40.
The $30 oil change is using Castrol GTX 5w30. YOu want the $60 one.
This should make it slightly more affordable
20IndigoBlue02 is offline   Reply With Quote
Old September 24th, 2003, 14:17   #3
BawlsyTDI
Fuel Economy: 54.5/49/42
Do it yourself [img]/images/graemlins/grin.gif[/img]
Any real reason you can't/won't do it yourself? Can you find a forum member in the area who can help you out?
BawlsyTDI is offline   Reply With Quote
Old September 24th, 2003, 14:21   #4
ruking
Fuel Economy: 62/50/44mpg, normal commute range 48-52 mpg:09 Jetta TDI, 47/43/39, normal commute range 39 -43 mpg: 12 Touareg TDI, 39/31/29 mpg:
[ QUOTE ]
[/ QUOTE ]
Don't do it yourself! [img]/images/graemlins/grin.gif[/img] But whatever you do at the dealer, be ABSOLUTELY sure that they put in the correct synthetic diesel oil (CI-4) and unless you have it well thought out on deviations, the 5W-40. Depending on a lot of factors, the prices I were quoted ranged from 62-72 dollars.
If you have a so inclined dealer you can buy the oil and see if he will charge you shop time and or disposal fees (10-20 dollars) If you provide say a premium oil like Delvac One @ 5 dollars per qt x 4= 20 and an oil filter @ 6.-6.50. I hope this helps [img]/images/graemlins/eek.gif[/img]
ruking is offline   Reply With Quote
Old September 24th, 2003, 15:13   #5
POWERSTROKE
POWERSTROKE's Avatar
TDI(s): 2002 Golf
Do it yourself is right. If not, make sure they don't torque your oil drain plug to 75 ft/lbs. No joke.
POWERSTROKE is offline   Reply With Quote
Old September 24th, 2003, 17:12   #6
MilenP
MilenP's Avatar
Buy 1 galon of Delvac 1 (you could get it for about $20 + taxes), get a cupon from vw.com for $24.99 for oil change. Same cupons, I keep getting from a couple of the dealers here in the area. Than ask the dealer to put your own oil and give you the oil the would've put in the car. If you have another car, use the dealer oil in it. I had done it at least 3 times, when I did not have a garage and I had to change the oil in the winter. Most of the times, the oil is pretty good for a gaser.
Hope this helps,
Milen
MilenP is offline   Reply With Quote
Old September 25th, 2003, 11:22   #7
Blackknight
Blackknight's Avatar
TDI(s): None
Fuel Economy: 42/41/40
Man, I would never trust a dealer to work on my baby.
You can do the job yourself for 30 bucks. Get a gallon of oil and an oil filter. It should take you about 30 minutes, maybe, to change it.
Blackknight is offline   Reply With Quote
Page generated in 0.13199 seconds with 9 queries
[Output: 74.47 Kb. compressed to 64.27 Kb. by saving 10.19 Kb. (13.69%)]
