Old September 26th, 2009, 16:29   #61
spleecho
I don't kill trees Vendor
spleecho's Avatar
Fuel Economy: Lowest 36.1, Highest 53.7, AVG 44.4
I made a video on how to install a boostvalve step to step. Can this be posted on this 'How to' or where should I post?
'99.5 Golf, 4 door, mufflerectomy, ventectomy, Inmotion Tuning Stage 2, chip and nozzles, VDO Boost Gauge, Boostvalve, Dieselgeek oil bypass kit, Scangauge II
AMSOIL Dealer
My VIDEO on how to install the Boostvalve
spleecho is offline   Reply With Quote
Old October 2nd, 2009, 18:37   #62
frugality
frugality's Avatar
Fuel Economy: 33mpg
Someone just posted a link to a Mk4 steering wheel removal how-to here:
http://forums.tdiclub.com/showthread.php?t=260004
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline   Reply With Quote
Old October 13th, 2009, 07:02   #63
delvi__acevedo
Mod'aholic
delvi__acevedo's Avatar
Default How to switch from multi-funtion steering wheel to 3 spoke
This is the wiring diagram of how to switch from multi-funtion steering wheel to sport/3 spoke and still maintain funtional cruise control/horn
there is no too much detail on it but if you have questions you can always contact me.
Btw I should of posted this a year ago
http://www.delviacevedo.com/Delvis_W...re-wiring.html
2015 BMW X5 35d Msport
2015 BMW 535dx Msport
delvi__acevedo is offline   Reply With Quote
Old October 18th, 2009, 10:31   #64
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Originally Posted by DoubleNickel
How about this way to replace the upper strut bumpers: It worked for me great.
http://forums.vwvortex.com/zerothread?id=1381025
Very simple
This is super simple. No need for spring compressors to do this job!
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old October 25th, 2009, 17:32   #65
BolaB4V
BolaB4V's Avatar
Fuel Economy: mid 40's to over 50 hwy..
This is how I changed out my inner tie rod on passenger side ..havent done the drivers side yet but appears to be the same procedure:
Bought this narrow crescent wrench at Wally World. It just fits flats on the tie rod. Accessable between H frame and lower control arm. You need to turn steering wheel till you can reach the flats on t/rod in the sweet spot seen in second photo. The hardest part is getting the boot/rack bellow off and back on. I recommend wearing mechanics gloves when working the boot around , its a bugger. Also, make sure to line the bellow air hole up again when installing the boot.
BolaB4V is offline   Reply With Quote
Old November 7th, 2009, 18:14   #66
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
This should be added to the list...
Canadian Grizzly's A4 low power trouble shooting
http://forums.tdiclub.com/showthread...light=actuator
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old November 15th, 2009, 16:10   #67
chaloux
Here's my HOW-TO for adding a manual glow plug button in an earlier ALH with 2 glow plug wires:
http://forums.tdiclub.com/showthread.php?p=2761176
Current: 04 Jetta Wagon TDI - DC stage I clutch/14lb fw - 01 Audi Allroad 6MT
- RIP 96 Audi A6 TDI Quattro - RocketChip tuned
- RIP 1996 Audi S6 mit ALH
- RIP 98 Beetle (LDL BGR)
EGR delete - Manual glow-plug button
chaloux is offline   Reply With Quote
Old November 18th, 2009, 16:14   #68
frugality
frugality's Avatar
Fuel Economy: 33mpg
I just put together an A4 thermostat change how-to:
http://forums.tdiclub.com/showthread.php?p=2765064
Old November 22nd, 2009, 06:29   #69
Growler
Got Soot Vendor
Growler's Avatar
Default BRM mk5 PD Timing belt procedure checklist.
I Put this together using the writeup at www.myturbodiesel.com
this BRM timing belt checklist prints on one page.
http://forums.tdiclub.com/showthread.php?t=264887
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old December 11th, 2009, 14:58   #70
Wallace
Wallace's Avatar
Fuel Economy: 45ish
Default How-to Timing belts-hydraulic tensioners.
Hi, I did my belt a while back using MoGolf's procedure on here which I found excellent. My Car's a UK AJM engine code rather than a US BEW though and so has a Hydraulic Tensioner, so I got stuck at this point and Mo sent me a file for the tensioner and suggested I did pictures as this would be something unusual and not on this site.
So I have finally done this and put it all files on my Home club site in Scotland (ScottishVAG ,Net) in a post with attached files and links to everything inculding the things on this site. I have done some info on tools and parts required (UK style) and the pictures include everything I thought maybe teh diagrams etc didn't explain that well eg how do you fit the tensioner locking tool, what does it lock against, what way up does it go? You kind of don't know this stuff until you do it but the pics should help.
Hope it is of use to you guys too;http://www.scottishvag.net/phpBB3/vi...?f=101&t=54820
All the best.
Wallace (AKA Rubberdubber)
Everything seems easy, until you try to do it!
Wallace is offline   Reply With Quote
Old March 6th, 2010, 19:56   #71
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
Sir B-90 wheel bearing change kit-front wheel bearing change without slide hammer.
http://forums.tdiclub.com/showthread...&highlight=sir
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old March 12th, 2010, 16:18   #72
Gordon Peterson
Gordon Peterson's Avatar
Fuel Economy: 40mpg
N75 broken barb fitting fix
http://forums.tdiclub.com/showthread.php?t=275980
03 Jetta TDI wagon "SMOKE" (mine)
trusted guru's: r90sKirk, JETaah, Franko6
Heads nozzles,TB kits, etc.: Franko6
Gordon Peterson is offline   Reply With Quote
Old June 2nd, 2010, 06:10   #73
dogdome
dogdome's Avatar
Default Replacing headlights on the New Beetle ('06+)
I looked and looked - couldn't seem to find a link on this WITH pictures (that stupid unlock bolt is a booger to find).
Just used this today to refresh myself on what Tom in Stafford taught me when changing them out last year. The dealer should be paying ME $45 per light, this is a cinch. 10-15 minutes max if not faster once you have the hang of it.
Also - the drivers side is the pain in the butt side, but you do NOT have to remove the battery. You can work around it - might take a little more work and manuvering, but it is doable.
http://newbeetle.org/forums/technica...t-removal.html
2014 Golf TDI DSG w/Sun & Nav - United Grey
2006 New Beetle TDI GLS (1.9)- Shadow Blue
- Retired
Dogdome "My car. Mine." <hugs car>
Husband. "Yes dear."
dogdome is offline   Reply With Quote
Old June 8th, 2010, 08:31   #74
paramedick
paramedick's Avatar
Default VW repair wires and connectors
http://pics.tdiclub.com/data/4885/VW_repair_wires.doc
Old June 15th, 2010, 07:58   #75
pa_elgin
Fuel Economy: 32-51 mpg
Originally Posted by paramedick
Compliments of the folks from CinciTDI club and Dieselgeek. Starring yours truly! You need Apple quicktime 7 or newer to run this. Kudos to RichC for the excellent video work and editing.
http://cincitdi.com/richc/panzerplate.html
Apple quicktime installer link
http://www.apple.com/quicktime/player/win.html
The link for the panzerplate video has changed: http://cincitdi.com/videos/panzerplate.html.
Thanks for the great info!
Phil
(And Sue, and Buffett her Golden Retriever)
2001 Jetta TDI
pa_elgin is offline   Reply With Quote
Where's all the threads LMJ Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 24th, 2013 18:59
Got some new threads... velociT General VW Discussion 5 August 8th, 2008 22:15
Want to get really old threads... BeetleGo TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 October 5th, 2006 05:02
All of the Epsilonian threads are gone! valois TDI Power Enhancements 1 November 2nd, 2000 23:15
Page generated in 0.18960 seconds with 10 queries
[Output: 137.73 Kb. compressed to 115.30 Kb. by saving 22.43 Kb. (16.28%)]
