Old October 13th, 2008, 18:51   #46
redlinedave
redlinedave's Avatar
Fuel Economy: around 5.9/100
http://forums.tdiclub.com/showthread.php?t=226442
to remove the taillight housing there are three 8mm nuts holding it in.
two on one side and one on the other.If you have a small mirror it helps to see things better.
oh-sree vaggon
redlinedave is offline   Reply With Quote
Old November 14th, 2008, 03:05   #47
DanG144
Originally Posted by fredspock
Is there a discussion somewhere that addresses HOW TO remove air from the fuel line? I've got a 99.5 with a big air bubble.
Whitedog's "Car wont start" thread post 10, is a great place to start.
http://forums.tdiclub.com/showpost.php?p=1972395
Old November 14th, 2008, 06:24   #48
wczorn
wczorn's Avatar
Default How To Get Air Out of Fuel Line
Here is a thread with photo explaining how to bleed air from injector lines:
http://forums.tdiclub.com/showpost.p...5&postcount=10
2004 Jetta GL 5 SPD Alaska Green
Ventectomy, Cat Filter, Asph. Mirrors, Euroswitch
Leave sooner, drive slower, live longer.
wczorn is offline   Reply With Quote
Old November 17th, 2008, 15:53   #49
astonishedboy
astonishedboy's Avatar
Fuel Economy: 44 mpg
Default Manual Transmission Fluid Change
Found this on the board. MTF change - Manual Tranny Fluid Change
http://forums.tdiclub.com/showthread.php?t=115899
2000 Golf TDI - Ventectomy, Koni Reds, phathack, gepanzert, Rieger knob, badgeless, 20th lights, RC Euro 2+/3+, Sprint 520, BoostValve, MF steering wheel, G60/VR6 clutch-flywheel
astonishedboy is offline   Reply With Quote
Old December 21st, 2008, 08:19   #50
Louis_TDI
Louis_TDI's Avatar
Default Gold Cathode trunk Light
Posted a write-up about installing a cold cathode kit in the trunks of my mk4 Golf :
http://forums.tdiclub.com/showthread.php?t=233917
Louis_TDI is offline   Reply With Quote
Old January 2nd, 2009, 20:36   #51
shagin'wagen
shagin'wagen's Avatar
TDI(s): Bora
Fuel Economy: 5L/100KM
Default 'How To' - Oil cooler seal replacement
I recently had the lower oil seals on my oil cooler start leaking due to cold. This is my writeup on how to replace them.
Tools & Materials:
-Whatever tools to remove skid plate or splash pan. (you have to determine what you need)
-32MM shallow socket, 6" extension, Socket wrench.
-Can of spray BrakeClean.
-Oil drip/drain pan.
-Fresh engine oil.
-Shop rags or paper towels.
-New seals. #2 & 4
Reference:
Procedure:
1) Remove skid plate or splash pan if your car is fitted with one.
2) Position drain pan under oil cooler and thoroughly clean the area with BrakeClean. The pan catches the drips.
3) With drain pan still under car, remove oil cooler retainer plate (#1) using 32MM socket. Oil will leak out at this point, but not much, hence the pan.
4) Once the retainer plate is removed, remove seal from retainer plate. (#2) It should still be in a groove in the retainer plate. Gently pull down the oil cooler and remove the other seal from the oil cooler. (#4) It should come out easily.
5) Spray down the cooler again with BrakeClean.
6) Take your new seal #4, and install it on the oil cooler. There should be 2 tabs on the seal with a hole in each. There are also several pins on the oil cooler, match 2 of the pins (doesn't matter which 2) with the holes on the seal, and gently push the seal onto those pins.
7) Spray down the retainer plate with BrakeClean and take your new seal #2 and install it into the groove in the retainer plate.
8) Now carefully insert the retainer plate back through the oil cooler and screwing the retainer plate back into the filter housing, making sure the seals don't dislodge and not to cross thread the retainer plate. Tighten down the retainer plate again with the socket to a reasonable torque. Not eye bulging, nor hand tight. (I have not found the correct torque value, but if you know it, PM me and I will add it here)
9) Start car, and check for leaks, allow to run for 1 minute. Shut off car for a minute or 2. Then add the correct amount of engine oil to bring it up to the appropriate level on dipstick. Starting the car purges the air that was introduced into the system, and letting the car sit for a minute allows most of the oil to drain back to the crankcase. Thus giving accurate quantities of oil.
10) Reinstall the skid plate or splash pan if you have one.
11) Put away tools, dispose of waste oil properly and clean up. Enjoy beverage of choice. I had hot chocolate, it was -25 and snowing when I did mine.
'99.5 Bora TDI - Many mods.
'71 Tin Top Westfalia
'85 Mercedes 300SD - Highway Cruiser
'85 Jetta Coupe
shagin'wagen is offline   Reply With Quote
Old January 12th, 2009, 23:12   #52
DanG144
Default A4 or MarkIV brake or clutch switch installation instructions
This is a pretty old set of instructions. The still can be helpful, depending upon which switch you get. There are several newer versions of the clutch and brake switch.
It is worth reading, because if you have a switch that needs length setting, and has turning components on it, you will break it if you do not know what you are doing.
http://pics.tdiclub.com/showphoto.ph...0&ppuser=65753
Old January 14th, 2009, 11:44   #53
shmcquilkin
shmcquilkin's Avatar
Default Mk4 new key fob matching/reprogramming info
Too much of a PIA and expense to go through a dealer, so here's pretty much all that is required to re-key your Mk4:
http://mark1vws.com/_wsn/page3.html
Mark's a GREAT guy, knows almost everything about re-keying your Mk4 VW. Tons of info here, towards the bottom. Hey supplies OEM fobs (even with the panic button), recuts them for you, and provides you with the info to reprogram and recode them.
http://www.sidewinderkeys.com/index.htm
Canadian source, also nice folks
http://www.ross-tech.com/vag-com/cars/immobilizer.html
http://www.knology.net/~TDIGuy/VW%20Key%20FOB%20Instructions.htm
http://www.myturbodiesel.com/1000q_h...vw_key_faq.htm
http://www.vwdiesel.com/Program_Keys.html
http://forums.vwvortex.com/zerothread?id=1216091
Wingnut's 'How To' thread (thank you!)
VWVortex DIY page
MyTurboDiesel Mk4 DIY page
-Felix qui potuit rerum cognoscere causas-
shmcquilkin is offline   Reply With Quote
Old January 27th, 2009, 11:45   #54
FreewayFritz
TDI(s): 2003 Jetta
Default Updated Link
Originally Posted by compu_85
Penclnck's 4130 Products 'Step By Step' Many great tips!
Replaceing the headlight bulbs on a Jetta (bt EECSentric) (Link is now dead anyone have a better one? )
I found that site here - there's no photos anymore, but the directions are still good:
http://web.archive.org/web/200308050.../headlight.htm
FreewayFritz is offline   Reply With Quote
Old March 20th, 2009, 19:29   #55
Louis_TDI
Louis_TDI's Avatar
Here is one more of my How to's
Changing the color of the LEDs in your heated seat switches
http://forums.tdiclub.com/showthread...36#post2497036
Old April 23rd, 2009, 05:09   #56
rocketeer928
rocketeer928's Avatar
Default A Better ALH Turbo / Exhaust Manifold Removal Guide
I was trying to find a decent "how-to" for removal of my stock turbo on my ALH to replace it and its exhaust manifold with a 17/22 hybrid turbo in the future. Though a good write-up for its purpose, I wasn't really satisfied with Speedster's removal "how-to" because it was more about removing the turbo without the exhaust manifold for cleaning purposes.
I did an internet search and stumbled surprisingly across this link:
http://www.tdiinnovations.com/k45/Tu...e%202.2.08.pdf
If for some reason the link does not work then search "ALH Turbo Removal" in Google.
I have no idea who wrote it, though it looks like it came from a company called TDI Innovations in TX. It seems like something that should be in the Engine section of Wingnut's "How-to" sticky posting.
This single document covers the following:
1. Turbo Intake Tube Removal
2. EGR Removal
3. EGR Cooler Removal
4. Intake Manifold Remove
5. Turbo Oil Line Removal
6. Turbo and Exhaust Manifold Removal
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
rocketeer928 is offline   Reply With Quote
Old May 31st, 2009, 12:50   #57
Mike96ZJ
Mike96ZJ's Avatar
TDI(s): 2002 Jetta
http://forums.tdiclub.com/showthread.php?t=248640
http://forums.tdiclub.com/showthread.php?t=248635
2002 Jetta - 17/22, PP764 Stage 2, 3 Bar map, Alligator tuned, Custom mounted X-Monitor, DG Racepipe, Southbend Stage 3, DG Panzer Plate, TDI Parts OMI, Ventectomy, and mufflerectomy. - RIP
2002 Jetta - 17/22, PP764 Stage 2, 3 Bar MAP, Malone Tuned, New South Boost/EGT Gauges, DG Racepipe, PD150 TIP, DG Panzer Plate.
Mike96ZJ is offline   Reply With Quote
Old June 19th, 2009, 13:35   #58
zanzabar
zanzabar's Avatar
http://forums.tdiclub.com/showthread.php?t=243478
BEW cam, lifter, bearing R&R.
http://pics.tdiclub.com/data/500/BEW..._procedure.pdf
His: 2007 Volvo V70 2.5T
Hers: 2014 Ford Focus
Former almost kinda guru for hire
zanzabar is offline   Reply With Quote
Old September 22nd, 2009, 22:12   #59
drakeo0
TDI(s): golf 99.5
I added a "HOW TO Fix your MK4 small radiator fan".
http://forums.tdiclub.com/showthread...39#post2699439
drakeo0 is offline   Reply With Quote
Old September 24th, 2009, 22:49   #60
Franko6
How to Seat Injector Seals for the ALH and AHU engines.
http://forums.tdiclub.com/showpost.p...46&postcount=1
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
Where's all the threads LMJ Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 24th, 2013 19:59
Got some new threads... velociT General VW Discussion 5 August 8th, 2008 23:15
Want to get really old threads... BeetleGo TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 October 5th, 2006 06:02
All of the Epsilonian threads are gone! valois TDI Power Enhancements 1 November 3rd, 2000 00:15
Page generated in 0.14674 seconds with 10 queries
[Output: 134.88 Kb. compressed to 113.09 Kb. by saving 21.79 Kb. (16.15%)]
