| TDI 101 Got a simple/basic TDI question? Are you a newbie (new to the forums). Feel free to post your question here. |
November 18th, 2006, 18:51
#16
Fuel Economy: 59.9/50.3/35.7 (3.93/4.68/6.59)
Leaky Fuel Injection Pump Repair
I took the posts from the thread Audi5000TDI mentioned and turned into an ugly little bulleted numbered list of steps w/ pictures.
Replacing Top and Middle Seal on the VE/Rotary Fuel Injection Pumps - http://anglo-hexon.net:88/tdi/ip_seals
dieselgeek's how to for changing the seal between the pump body and cast iron distributor head - http://www.dieselgeek.com/TDI_Inject...eplacement.htm
November 30th, 2006, 10:26
#18
Headlight retaining ring, model 2002 Jetta
This is a picture of my passenger side headlight bulb. There is a plastic retaining ring, rather than the spring clips noted in the Bentley for ealier models. It is removed by turning just a 1/4 turn.
http://pics.tdiclub.com/showphoto.ph...ze=big&cat=516
2002 Jetta GLS TDI, 5 speed
December 24th, 2006, 19:53
#19
Silicone hose and viton tubing
Guys, I know this is not a how-to. Just stashing it here so it is easy to find.
Silicone hose sizes/lengths for the A3/A4/B4 cars. Viton tubing for the fuel return lines.
mcmaster .com
Ft. 5041K22 Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Red (Same as 5041K52)
Ft. 5041K522 Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Blue (Same as 5041K52)
Ft. 5041K521 Metric Silicone Rubber Tubing Firm, 3 mm Id, 8 mm Od, 2.5 mm Wall, Black (Same as 5041K52)
Ft. 5054K531 Metric Silicone Rubber Tubing Soft, 4 mm Id, 8 mm Od, 2 mm Wall, Black (Same as 5054K53)
Ft. 5119K41 High Temperature Viton Rubber Tubing Firm, 1/8" Id, 1/4" Od, 1/16" Wall, Black
A3 Jetta: 3 foot of blue/red. 12 foot black 3mm. 5 foot black 4mm
B4 Passat: 6 foot red/blue. 15 foot black 3mm. 5 foot black 4mm
A4 B/G/J: 10 foot of black 3 mm. 5 foot black 4mm.
With all these numbers, you will have some left over. Not a bad thing to have a little vacuum tube around.
Viton hose: 3 foot is more than you need. You will have some left over after replacing the interinjector lines and return line to the injection pump.
An all TDI Family!!
January 31st, 2007, 07:23
#20
Good Ol' Boy
February 25th, 2007, 09:11
#21
Here is a PDF for the LCA replacement
Do work on cars like intake cleanings, nozzle swaps, brakes etc.... Hex usb + can now
2009 Jetta TDI Comfortline with ESP and beige leather interior. Evolution Imports Osiris Skidplate.
So far just over 10,200 kms on it
February 27th, 2007, 07:11
#22
How to change out your crank seal on your A4 by MOgolf:
http://forums.tdiclub.com/showthread.php?t=66145
99.5 Jetta, 5-spd, 490k, T4's, VNT17, tuned. 03 Golf, 5-spd, 206k, tuned
Trusted TDI Mechanic serving MO & surrounding states
Mobile Timing Belt Replacement, I travel to you
Malone Tuning Dealer www.vwtdisales.com
March 6th, 2007, 12:52
#23
B4 Ventectomy
Ventectomy for the A3/B4
1) Remove the cap on the filler neck, and put a rag in the filler neck.
2) There is a metal ring in the edge of the rubber boot around the filler neck. Remove this.
3) Pull up on the rubber boot to remove from around the filler neck. Now you know why there is a rag stuffed in your filler neck. Massive quantities of caked mud/dirt. Clean out what you can by hand. There is a rubber hose connected to the boot that drains spilled fuel. Disconnect it from the appropriate place. You'll see what I mean. While you have the boot out, clean the drain tube. Chances are that it's partially plugged with gunk.
4) Put the filler cap back on. Use a hose to clean out what you can of the dirt. This will take a bit of time.
5) When clean, remove the filler cap.
6) Reach rearward of the filler neck. About 2-3 inches back, you will feel a knurled knob. Unscrew this, and remove it.
7) Take an object, and push against the vent button inside the filler neck. I have found that the rubber covered handles of a pair of large pliers work perfectly.
8) You will notice that there is an object emerging from the area where you removed the knurled knob. Grasp it, pull it rearward, and remove from car.
9) You will see the vent button, a spring, and a plastic retainer ring inside of the housing that was removed. Remove the plastic retainer ring, the spring, and the vent button.
10) Put the spring back in the assembly, and replace the plastic retainer ring. Why? No particular reason. I just leave them in place as they cause no future problem. Put the vent button wherever you prefer (garbage, trunk, shelf, etc.).
11) Slide the assembly back in place. Note the shape, and match it to the orifice shape before you push it back in place.
12) Screw on the knurled knob
13) Replace the rubber surround for the filler neck after you have cleaned it of mud/dirt. Don't forget to hook up the hose.
14) Replace the metal retaining ring in the rubber boot
15) Replace the fuel cap. You're done
15) Go the your favorite fueling place. Place the nozzle on low or medium setting. When it kicks off, slowly top off the tank. You will be amazed at the additional fuel that will go in there.
Note: A3 Jetta is the same, except that there is a tab in a slot on the underside of the housing for the vent assembly. No knurled knob. Press the tab upward with the screwdriver, and follow all the other directions.
An all TDI Family!!
March 28th, 2007, 14:56
#24
An all TDI Family!!
April 7th, 2007, 09:09
#25
Compression testing
Haven't located this within the thread, so here's a basic run down from multiple posts I've gleaned recently.
Theory (per Turbo Steve):
Compression is the Foundation of a TDI Engine
Just as in any other engine, a compression test can be used to find out how the rings, valves, and head gasket are holding up. The readings are taken at the injection nozzle holes or glow plug holes, depending on the manufacturer's recommendations. Remove all the nozzles or glow plugs before cranking so that the engine can spin as fast as possible, and disconnect the fuel shut-off solenoid wire to stop flow to the nozzles. Of course, the gauge must be capable of withstanding much higher pressures than those of gasoline powerplants.
Typical specifications are 400 to 500 psi, and if a specimen isn't up to these readings, it may be difficult or impossible to start (after all, compression is what ignites the fuel in a diesel). If one cylinder is 75 psi or more lower than its neighbors, it'll be apt to misfire, causing roughness and a loss of power and efficiency.
Once you've zeroed in on a "weak cylinder," squirt a small quantity of engine oil into the combustion chamber and do the test again. If your reading goes up dramatically, the rings are probably at fault. If the rise is small, bad valves are probably indicated.
Another distinctly possible failure is a blown head gasket, since a diesel's high compression (pressures) put terrific demands on whatever seals the joint between the block and head. A good indication that this seal has failed are very low readings on two adjacent cylinders. By the way, don't forget to check the condition of the timing belt!
Compression testing tells you the condition of an engine's foundation, and should be done when you suspect internal parts of causing a problem. But there's a lot more to diesel diagnosis, and I'll break it down into the proper procedures for specific complaints.
Procedure (per Drivbiwire):
TDI uses the *glow plug holes* to test compression.
-Get engine to operating temp
-DISCONECT THE HARNESS GOING TO THE INJECTION PUMP AND THE FUEL SHUT-OFF SELENOID failure to do this WILL cause the pressure gage to explode!!!!!! (note: you will need to clear the codes when your done)
-remove all four glow plugs
-Hook up a battery charger to keep a uniform charge between cylinders
-Crank until the compression gage stops climbing
Tools:
S&G Tol Aid diesel compression tester kit 34900, includes VW adapter 34740
http://www.toolaid.com/products.htm
Fair prices:
http://www.sjdiscounttools.com/sgt34900.html
http://www.toolsource.com/ost/produc...QL0FX7BLDJ4NU7
Harbor Freight:
http://www.harborfreight.com/cpi/cta...emnumber=93644
Uber pricing (Snap-on):
MT33c compression gage (800 psi max) approx. $189
EEPV315A TDI Glow Plug adapter approx. $70
Hope that this helps, and thanks Wingnut!
May 9th, 2007, 13:13
#28
Fuel Economy: 35 in city floored, 48 on highway @75mph
I think I have a decent howto on changing an automatic to a manual transmission... plenty of photos, and three other people have swapped based on this howto...
http://forums.tdiclub.com/showthread.php?t=151516
July 12th, 2007, 07:14
#29
August 27th, 2007, 14:55
#30
B4 Passat ECU removal for tubing replacement
Passat ECU
1)lift off the rubber hood sealer strip about halfway. Move the temp sensor out of the way by lifting up on it,
2)rotate the three quarter turn clips that secures the plastic tray at the base of the windshield. Make sure they pull away from the square holes they lock into. Lift off that tray.
3)Remove cabin filter and set out of the way.
4)Remove the two sliding clips that secure the cabin filter base to the car. Lift the base up and remove. Careful, the base gasket may want to stick. Gently loosen it from the body.
5)Remove 10mm nut that secures the ECU frame to the body. Clean the stud/area well, as it's a grounding point for the ECU.
6)Remove vacuum tubing from ECU nipple and move out of the way
7)If you feel by the ECU nipple, you will note that the harness connector has "T" piece on the end of it. Push the T connector toward the nipple. It may take some effort. When it moves toward the end of it's travel, the harness will pull away from the ECU. Move the harness/connector out of the way.
8)Lift the end of the ECU frame away from the mounting stud. Wiggle the ECU/frame until the backside pulls away from the two T studs in the back.
9) Pull ECU toward the cabin filter area, and wiggle it out of the car.
10)On the end of the ECU that has the 4 small torx screws, remove the two phillips screws that secures the ECU to the mounting plate.
11)remove the 4 torx screws that secures the ECU tray to the ECU outer case.
12)Wiggle the ECU tray until it slides out from the ECU outer case. You may have to rap the tray portion a few times with a screwdriver handle to loosen any corrosion that may have formed.
13) Slide back the two tiny little spring clamps with a pair of needle nose pliers.
14)Take a sharp knife and slice the hose lengthwise off the black plastic nipple (MAP sensor). Careful, the nipple is pretty fragile to rough handling. Peel the hose off by splitting the hose. You can pull the hose off the metal nipple to the outside of the case.
15)Replace that piece of hose with a piece of 1/8th inch vacuum tubing. Silicone is best, but rubber works. No need to replace the spring clamps if they won't fit over the hose.
Assembly is reverse of removal. When you put the connector back on the ECU, make sure that the T is fully closed to secure the connector.
Replace the hose from the upper intercooler pipe to the ECU at the same time. It's probably toast anyway.
An all TDI Family!!
