Old August 17th, 2017, 05:36   #271
Marius Titulescu
TDI(s): None yet
Thanks for sharing. I won't be able to look into all the resources anytime soon, though.
_____________________________
Marius from True North Plans
Marius Titulescu is offline   Reply With Quote
Old August 25th, 2017, 16:38   #272
Tfreelon
TDI(s): 2002
Finally, instruction on how to ask a question.
Thank you.
Tfreelon is offline   Reply With Quote
Old January 16th, 2018, 04:38   #273
Codymuddinlong
TDI(s): 2000 jetta
Default White smoke no power
Hey guys new here. I just bought a tdi so bare with me I no diesels from my 7.3s and cuminnis. But I was driving home and I lost my turbo seals I put the new one on and drained the intercooler. But I'm still getting this white smoke with no power. But if I lug it out long enough the rmps will start to go up but won't go over 2700. And the doctors so really bad anyone out there know a tip. Oh the smoke smells like diesel I'm thinking injection pump over Pressureing
Codymuddinlong is offline   Reply With Quote
Old January 16th, 2018, 09:18   #274
Lightflyer1
Lightflyer1's Avatar
Wrong way to post. Start your own thread here:
http://forums.tdiclub.com/forumdisplay.php?f=12
Also be as clear and informative as you can. Proof read your post before posting. Welcome to tdiclub! When you start your own post over there someone can help.
Old February 28th, 2018, 08:52   #275
fairbanks
Default Omg!
That is a lot of work, thank you.
fairbanks is offline   Reply With Quote
Old April 22nd, 2018, 01:03   #276
LanaW
Hey people. Glad to be here.
LanaW is offline   Reply With Quote
Old July 18th, 2018, 10:45   #277
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Default Sunroof Drains
Credit to May-39
Sunroof drain location and repair-mkiv wagon
Old July 25th, 2018, 09:28   #278
redhuskers
TDI(s): passat sel
Hey everyone! I bought a 2015 VW Passat TDI SEL, I love it, but my bank called me and said the title is a salvage title. Are the TDIs that are coming back after being fixed getting a salvage title? Can't find anything online. Thanks!
redhuskers is offline   Reply With Quote
Old July 25th, 2018, 11:39   #279
BobnOH
not-a-mechanic
I wouldn't think so, answer could be in this forum-
Dieselgate - VW Group Emission Scandal
Old September 27th, 2018, 10:28   #280
elizabella42
Thank You for this...am having a difficult time navigating this website to be able to post looking for info/help on doing the clutch for my 2003 TDI wagon ...the conversion kit or stay with dual mass flywheel
elizabella42 is offline   Reply With Quote
Old September 27th, 2018, 11:42   #281
BobnOH
not-a-mechanic
Yes, the forum is a lot of info, much of it is anecdotal. Lots on this subject as well.
I wouldn't hesitate to buy the newer DMF kit, most of the fails seem to be older, cheaper factory units. I would think that for $300 you will get something that will go at least another 100k miles.
VW TDI Search Engine
Old December 2nd, 2018, 13:05   #282
Genes98bug
Cool Diesel problems
When i park my 98 bug for few days it loses prime won't start .what cause this is there a check valve in pump if not can i put one in line .
Genes98bug is offline   Reply With Quote
Old December 13th, 2018, 13:30   #283
tdiman
tdiman's Avatar
No way .. take back to where u bought demand a refund and do business some where else
tdiman is offline   Reply With Quote
Old December 18th, 2018, 19:34   #284
Satsonic
TDI(s): 2006 Jetta
Fuel Economy: 38
Like the others have said - not a chance. Salvage title is totally different then some firmware update for emissions. Only a few ways to get a salvage title, none are good (i.e. accident, flood etc...)
Satsonic is offline   Reply With Quote
Old January 15th, 2019, 06:09   #285
iluvmydiesels
TDI(s): AHU
Fuel Economy: mk3 ~43mpg
hey guys, i ve made use of this sticky at times, and for my mk3-a3 have found good info. i have a topic for my 1st post in this 'main' diy thread.
so a few days ago i was intending to swap in new power steering fluid. i had looked for info. not much in posts. i got some good info, advice and proceeded. so to help here are my result.
doing the routine once i learned a lot to get it right. heres what i did.
jack up front end, i put on stands. remove passenger tire. loosen p/s belt, you want to rotate p/s pulley by hand. check belt, you may want a new one.
now to start routine. i first get as much of the fluid out of the reservoir. have a plastic baggie ready, and a zip-tie. take return hose off, fluid will drain from both sides, the rest of the reservoir you can drain, if your not afraid of a little mess. whether or not, put baggie on, i double it up, zip-tie it. keep reservoir cap off. use a connector from the return hose and a hose extension to your fluid waste 'collector', a gallon jug like an empty milk or water bottle will work. have help to turn steering wheel, have him turn wheel a few times, check if you have fluid flowing out. just to start, lower level some. put fluid in, you turn pump pulley, while help turns wheel lock-to-lock. check fluid level while doing this. as far as a system that has really dirty fluid, and/or hasnt been serviced since new, like i did, i got into 3 bottles to fluid flush. (16 oz bottles). so keep the fluid flowing, after your satisfied, button system/hose up. now check level, keep your help, fluid level doesnt have to be topped off, not when cold or to start anyways. you turn pump a few times, help again turns wheel, lock-to-lock, a few times, again check level, if good, you can do that last part one more time, you turn pump and the help turns wheel. this part is one to make sure the pump is primed, and the rack is purged of any air bubbles. tighten belt, put wheel on, now jack car down, check stuff, like connection, last fluid, have enough in, like above the top needed cold. if ok start, turn steering wheel lock-to-lock(3 times), turn motor off, (added:edit,>)_right here, if you want to be very careful, 1st when you start motor, let idle for about 2seconds, i give it some revs, to idle, shut off, do a quick fluid check, if ok, again start, now turn wheel lock-to-lock 3 times, again shut off, check fluid level. now just to be sure before taking out for a drive, start up again turn wheel lock-to-lock, 6times will do. again, if you want to be careful, shut off and check fluid for the last time.(<<,had added:edited) --and check fluid level, if everything is ok your ready for a drive, after engine/fluid is warmed up you can 'top-off'. doesnt take much to top-off. clean up any fluid mess in engine compartment, with motor warm and engine running. i take a garden hose and clean stuff up, run motor to dry out. <becareful you can get moisture in/near starter, so i keep motor running, take for another drive to dry out. you should have success!!
<- this is post #11 in topic. i ll put up the thread link.
http://forums.tdiclub.com/showthread.php?t=495102
ok that time maybe i got the link. i was going to say as a note about my topic. i in the thread i am chided for the p/s fluid i use. like i say in the topic, as long as/i hope i dont blow seal(s), other than that happen to have a thing for my fluid/lubes that i use. its for an older mk3, a3, i do believe the b4 is the same. they insist on a certain fluid here for compatibility, i dont doubt, used my amsoil stuff here.
hopefully this p/s fluid swap/fresh-fluid flush is good info and can help.
just thinking about it this may work/be similar for a mk4, and mk2s are much the same as 3s (p/s) should work for them as well. if not somewhat rare for a 2.(<<- just as far as fluid change, for a 2)
small fleet of mk3 tdi
have exp on mk1&2, idi
other vw interests
Last edited by iluvmydiesels; January 15th, 2019 at 17:09. Reason: added some edit at the bottom
iluvmydiesels is offline   Reply With Quote
Where's all the threads LMJ Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 24th, 2013 19:59
Got some new threads... velociT General VW Discussion 5 August 8th, 2008 23:15
Want to get really old threads... BeetleGo TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 October 5th, 2006 06:02
All of the Epsilonian threads are gone! valois TDI Power Enhancements 1 November 3rd, 2000 00:15
Page generated in 0.23585 seconds with 10 queries
[Output: 125.22 Kb. compressed to 104.61 Kb. by saving 20.61 Kb. (16.46%)]
