Old July 31st, 2003, 13:31   #1
dparnell
Default No Turn Signals & No Hazard Lights, Out of Ideas
ANY help /ideas would be greatly appreciated. My 03 Jetta TDI wagon's turn & hazard lights don't work. The 15 amp fuse for the hazard lights was blown~~~I replaced it & it blew again. Every time you open a door or rear hatch you hear a 10 second buzz. They had not been working for a couple of days & the buzz was new. So I did a search & found the "Replacing Turn Signal Module" thread. I also have a 99.5 Golf IV so I pulled the turn signal module from the Golf & it had a slightly different part # 1J0 953 235 H as opposed to the Jetta same # that ended with a J~~~it didn't work & still blew a hazard light fuse. I put it back in the Golf & it worked fine . It's a REAL PITA to go to the dealer 2+ hrs away. There appears to be a short somewhere( I figured the module but the Golf's module did the same)~~~I am out of ideas.
dparnell is offline   Reply With Quote
Old July 31st, 2003, 15:58   #2
paramedick
paramedick's Avatar
I'm sure you checked...but any chafed/broken wires in the steering column, epecially in the area that flexed when you adjust the steering wheel height?
I have seen this on cars before.
Old July 31st, 2003, 15:58   #3
concours
concours's Avatar
Divide and conquer. Using your Bentley manual, start disconnecting portions of the circuit to first figure out what the problem ISN'T, then you can find what it is. It's probably a nicked wire or bad bulb socket, if I were to guess. Good luck.
concours is offline   Reply With Quote
Old July 31st, 2003, 17:58   #4
GeWilli
GeWilli's Avatar
Fuel Economy: you keep track?
Doyle,
check all the bulbs on the circuit. one of them might have fried in a bad way.
i'm not sure what is on the whole circuit, but i'd bet as suggested you've got a fried wire or a shorted bulb or ..... check the vanity mirror lamps if they are on the same circuit. Also see if you can locate where the buzz is . . . although that does chew up fuses it might help find the location of the short?
good luck -
GeWilli is offline   Reply With Quote
Old July 31st, 2003, 19:29   #5
Birdman
Fuel Economy: 55 summer 50 winter
Instead of frying fuses find a circuit breaker instead. It will go off than reset over and over. It does sound like a wire has shorted.
Birdman is offline   Reply With Quote
Old July 31st, 2003, 20:38   #6
Norman
Norman's Avatar
Fuel Economy: 48-50ish
Gee, Doyle, you already looked at the relay/module, which was my first thought since the same thing happened on the Eurovan. Can you dig your Jetta's relay out and open it up and take a peek inside? Maybe the striker doohickie thing is hanging there in limp Richard mode... Good luck. Hey, if it's still busted by the weekend, post on the GTG forum and we'll have a GTG & meeting of the Charlton Heston Fan Club at your place; we'll even bring along spare parts to fix your lights.
Norman is offline   Reply With Quote
Old July 31st, 2003, 20:46   #7
car54
theGAME
If its an 03, isnt this fully covered under warranty? Maybe if you explain to the dealer your so far away they can just send you the new part once you figure out what it is?
That sucks...
car54 is offline   Reply With Quote
Old August 1st, 2003, 10:12   #8
dparnell
Hey Guys!!! Thanks for all the ideas. I forgot to mention this just started after a "lady" backed into the driver's side rear bumper just below the tail light. Caved in the area but it popped out on the drive home. There are a LOT of wires in that area &amp; although they look OK, I'm going to pull the bundle apart &amp; inspect each wire individually~~~esp the turn signal wire. I have a module coming on Monday &amp; an appt with the dealer on Friday. I just hate to take off all my mods &amp; I know I have some codes stored in the ECU. Once again <font color="blue"> </font> THANKS!!!
Old August 1st, 2003, 10:41   #9
Norman
Norman's Avatar
... I forgot to mention this just started after a "lady" backed into the driver's side rear bumper just below the tail light....
That's more likely your issue than the relay, now; I suppose you could just put the Jetta relay into your Golf and that'll eliminate the relay as the culprit. Check the actual bulb connections, too; I think someone already mentioned that earlier. Good luck!
Old August 9th, 2003, 09:12   #10
dparnell
UPDATE!!!!
Took the wagon to Pestige VW yesterday~~~had to get up @ 5AM &amp; thet didn't get in in to to service till about 11:30 . Anyway the problem was a relay/switch in the steering column(wife took the call). They had given me a rental &amp; told me to keep it~~~the part will be in some time next week.
Problem manifests itself like this:
No turn signals or hazard lights. You can put in a 15 AMP fuse to the hazard light &amp; try right/left turn signals~~~they won't work but the fuse will not blow. If you try the hazard light, the module itself will buzz briefly &amp; then the fuse will blow. Additionally, there is a relay somewhere in the console below the hazard light/turn signal relay that will buzz for 5-10 seconds intermittantly when you open/close doors or hatches.
I thought I would post this info to save someone some time~~~I spent hrs. Perhaps this should be in the FAQ~~~I don't know if this is goning to be a common problem~~~mine is an 03 TDI wagon.
Page generated in 0.16064 seconds with 9 queries
[Output: 93.12 Kb. compressed to 79.19 Kb. by saving 13.93 Kb. (14.96%)]
