Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old July 4th, 2003, 05:09   #1
Fuel Economy: avg ~ 5 l per 100 kms
Default Product spec for Ultramar Diesel
Here is a product spec sheet for Ultramar Diesel #2, brewed at their Quebec refinery.
Utramar Diesel #2 pdf
What I found interesting to note was the periods of year during which they alter the cloud point. May - August seems to be good diesel season. Any other time of the year and you are compromising.
MWM is offline   Reply With Quote
Old July 5th, 2003, 17:24   #2
Derrel H Green
Derrel H Green's Avatar
Fuel Economy: Check my Fuelly
Only 40 cetane.
Do you use an additive to boost the cetane? confused:
Derrel H Green is offline   Reply With Quote
Old July 8th, 2003, 10:45   #3
McBrew's Avatar
Fuel Economy: 54/50/44 (usually running B100)
Only 40 cetane.
Hell, you're lucky to get better than 40 around here. 42 at Texaco.
I use an additive to boost cetane, though... it's called B100!
McBrew is offline   Reply With Quote
Page generated in 0.13704 seconds with 9 queries
[Output: 53.08 Kb. compressed to 47.90 Kb. by saving 5.18 Kb. (9.76%)]
