| VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta/Golf (99.5-2004) & New Beetle. Both VE and PD engines are covered here. |
June 30th, 2003, 19:33
#1
WOW NEW EGR BECAUSE ANTI-SHUDDER BROKEN?
hey everyone, I had the great joy of cleaning the intake and intercooler on my '00 NB today. Wow, it was fun, in a wierd sort of way but man was it clogged! I broke the plastic linkage piece that connects the anti-shudder to the EGR...just like SOOOOO many of you all have warned me about!! I even knew NOT to break it, DAMN IT I broke it! The stealership told my girlfriend that they don't sell the anti-shudder valve by itself, we had to buy a whole NEW EGR valve! Is this right? I thought for sure that they sold that thing...is there anyone out there who has bought it seperately? Hmmmm...STEALERSHIP!! EGR was 200 bucks, by the way! Now she's clean as a <turbo> whistle and runs like never before. But it still smokes some at WOT...hoping to do the VAG-COM EGR recalibration and IQ setting over the next few days. Thanks for the great instructions all!!
Took me all of 5.5 hours total including lunch and a walk to the station to get some gas and diesel to clean out the intercooler (A SMALL BIT OF SAND IN THE INTERCOOLER!!  EEEK!)
~~~~~> Scott
July 1st, 2003, 09:39
#3
awww, I wish I knew that!!!! --Scott
July 4th, 2003, 13:03
#4
soo... nobody feels my pain!??!
~~~> Scott
July 4th, 2003, 16:40
#6
Fuel Economy: numbers are good
I broke mine. Got some Goop and a short metal piece from a coat hanger and fixed it. But I heard that it depends where you break it. I broke it right in the middle so it was an easy repair.
July 4th, 2003, 19:49
#7
The shudder valve is very easy to fix. Don't even need to take the EGR off. I broke mine right at the base. Here is what it looks like:
Just take a small screw & washer & reattach the two pieces. There was already a hollow spot in the shaft, but I lengthened it a bit with a small drill bit. A shorter screw would also work
Here is the valve assembly apart. Its just held together with some barbs. Just pry it gently apart with a flathead screwdriver.
To remove the valve, just twist it out of its bracket. replacement is the opposite of removal.
July 4th, 2003, 21:32
#8
Just install a DG race pipe and forget it
July 28th, 2003, 20:02
#9
lol bawlsyTDI I did, I knew I could break it...It was funny my girl came in right when I broke it, I had told her of the "plastic piece that breaks easily" she laughed at me and said, "Well, at least you knew you were gonna break it!"
 ---Scott
July 28th, 2003, 20:22
#10
Impex sells the same EGR valve for $168.00. Next time, if you have time, you can save some money by not buying from the dealership.
Glad you got it fixed.
L
July 28th, 2003, 21:44
#11
What did ya do with the old EGR?
July 29th, 2003, 11:13
#12
lol you mean the STEALERSHIP!!! (Sadly enough, I was leaving on a 4,000 mile road trip the next morning!)
Yeah, now I have a $200 paperweight that reminds me why EGR on a Diesel engine is a bad idea! (I left it all clogged)
--Scott
July 29th, 2003, 17:46
#13
In your experience during what part of the cleaning operation is the part most vulnerable for breakage?
August 2nd, 2003, 00:46
#14
Well, the part where I was taking the plastic piece off without actually having to! Man, it really looks like it should pop right off with no problem! Instead, it breaks with no problem  I guess I could have left it hooked up and just cleaned the EGR over the engine in a pan or something...EGR mod (thanks Lyle!) says I should never have to mess with it anymore!
---Scott
November 13th, 2003, 00:33
#15
I sure hope that none of you guys that have left the broken anti-shudder broken never have a turbo or other kind of failure that blows oil into the intake. You'll have no way to shut down the engine, and it'll overrev until it self destructs.
