Wow!! You folks really crack me up.
That section 8 quoted above is in need of some serious updating.
Let's see... Running the basic settings of the pump to 'the top' is supposed to 'advance' the timing such that you get more HP, MPGs, and less smoke. Tuning boxes are supposed to advance timing. Chips are supposed to advance timing. And yet all these things that are believed to advance timing are supposed to be good, such that they are well sought after mods. And used in combinations!!!!
Well, basic settings doesn't advance timing the way it is presented. At best, it advances timing during cranking. Tuning boxes plug into the pump fueling controls and don't interface with the NLS or COI, so they can't affect injection timing. And remember, a tuning box fakes the ECU out so the ECU cannot recompute an advanced timing for the additional fuel it is enabling. That's why tuning boxes tend to smoke. BTW, the ever popular IQ adaptation changes injection timing because it alters the IQ computation - depending on which direction you go with the fuel.
I haven't fully investigated the affect chips may have on timing, and probably won't bother. It's been said that chips advance timing, but I won't believe that unless I do the testing. After all, it has been said repeatedly, and in the TDIFAQ, that tuning boxes advance timing, even though they can't. And I mean independently of fueling, like the timing adaptation mod does.
One thing in the TDIFAQ that is correct is this:
There is a misunderstood impression that more timing advance can produce more power. The correct statement is that the *optimum* amount of timing advance will produce the most output, and anything more or less will have adverse effects.
Now it is well known that the TDI is retarded from the factory. The OEM timing is retarded from the *optimum* timing for HP & MPG. Therefore, advancing timing from the OEM settings does not guarantee that the sky will fall. You might actually end up at the optimum for MPG & HP!!!!
The other thing that y'all have to get familiar with is the timing spec:
Idle: 3° ATDC to 4° BTDC
3,000 RPM: 8° to 12° BTDC
AND THESE ARE RETARDED FROM WHAT WILL PRODUCE OPTIMUM MPG OR HP.
Now every car I've VAG-COM'ed was set to 0.4° at idle.
Gary, from your quote:
PLEASE BE FORWARNED. IF THIS MODIFICATION PUTS YOUR TIMING OFF THE SCALE, IT COULD CAUSE SEVER ENGINE DAMAGE!!! YOU HAVE BEEN WARNED!!!
What scale are you talking about?
Oh, and this mod (advancing timing in adaptation) will hole a piston? Well, Ol' Silver supposedly had wa-a-a-a-ay advanced timing that bent the connecting rods, right? Yeah, you know, that 2° and 15 bar stuff we keep seeing over & over. Well, those pistons from Ol' Silver were not impinged upon by a flame at all... in other words: The pistons were not damaged by an engine that was supposedly set up too far advanced. But then, maybe Ol' Silver didn't have over-advanced timing... but what bent the rods? Never mind... hehehe...
MaryP,
I can't believe Go Faster or Fred would put this in the TDIFAQ's without reason.......
There has been good reason to revise the FAQ before...
