Old April 29th, 2003, 08:01   #1
TedA
Fuel Economy: 38 mg/city
Default Acceptable tire size Jetta TDI
My '01 Jetta tires are stock 195/65/15. Are there other tires sizes that will safely fit the stock rim. I can't find any references to upgraded tire sizes..
TedA is offline   Reply With Quote
Old April 29th, 2003, 08:04   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Ted, you can check with Eric at the Tire Rack. He is the "VW guy" and can quickly tell you what is safe and what is not.
Old April 29th, 2003, 08:59   #3
20IndigoBlue02
20IndigoBlue02's Avatar
should be able to put 205/60 r15
20IndigoBlue02 is offline   Reply With Quote
Old April 29th, 2003, 10:19   #4
natebg
Anybody know if 205/70 r15 will fit? I have a set of practically new tires, and just don't want to throw them out...Would like to use if I could...
natebg is offline   Reply With Quote
Old April 29th, 2003, 11:57   #5
20IndigoBlue02
Too tall, too large of a circumference: about 5.6% larger than stock, about 5.6% slower in the speedo and odometer
Old April 29th, 2003, 12:29   #6
zanzabar
zanzabar's Avatar
I have 205/65/15's and they seem great. The 205/70/15's may be pushing it, but you'll never know till ya try!
zanzabar is offline   Reply With Quote
Old April 29th, 2003, 14:31   #7
fallingwindows
Fuel Economy: 53/46/45
So the 65's would only be 2% larger? (65% of 205mm height, right?)
I'm also wondering about larger tires. As I see it -
pros - possible fuel savings (lower rpms for a given speed), taller profile better for soaking up NEngland road abuse?
cons - more mass to spin, more stress on suspension, possible bottoming or tire scrub, handling and braking suffers
Also, I'll be picking up a set of Bilstein TC's and want to see how much ride height increases. Might make a little room for rubber.
fallingwindows is offline   Reply With Quote
Old April 29th, 2003, 19:15   #8
zanzabar
zanzabar's Avatar
I've noticed NO change in fuel mileage. In fact it goes down, maybe (wider tire, increased rolling resistance?). It also changes the odometer count by around 3%? (less miles... therefore the appearance of lower mileage).
Page generated in 0.14018 seconds with 9 queries
[Output: 78.55 Kb. compressed to 67.10 Kb. by saving 11.45 Kb. (14.58%)]
