Old May 27th, 2020, 08:05   #1
coh
Fuel Economy: ~48 mpg
Default Car stalled, won't start
Hey all,
Been a while since I've been on the forum but I'm having a problem with my 2002 Golf TDI. I took it to a local mechanic on Monday evening for some brake work. It seemed to drive fine on the way over, though I thought it perhaps felt a bit sluggish. Hasn't been driven much over the past couple of months due to the shutdown, stay at home, etc.
Anyway, the mechanic started it up, got it into the shop and did the brake work. Then he says he started it up to go on a test drive, but before he could the car "gave a big puff of black smoke" and stalled. Now he cannot restart it - engine cranks but never starts.
One problem is, the guy doesn't work on diesel engines, so if I can't troubleshoot it I'm going to have to have it towed to another mechanic for that (probably the dealer shudder). Another is that I haven't been able to get over there so I'm only able to go on what he is telling me. I've asked him to check if the glowplug light comes on when he turns the key but haven't heard back yet.
I've browsed the forum and come up with a number of possibilities...relay 109 (would that kind of failure cause the black smoke?), anti-shudder valve (can that cause stalling? I know it can be a cause of inability to start). Then there are other more complex problems such as fuel pump.
He said there wasn't any unusual noise so I'm guessing it's not the turbo. Any suggestions? I'm going to try to get over there today or tomorrow.
BTW, car is rather low mileage for its age (between 120-150k), has had regular oil changes, timing belt changed, etc. One thing that has not been done is EGR/manifold cleaning and fuel filter is probably overdue for replacement.
Chris
coh is offline   Reply With Quote
Old May 27th, 2020, 08:20   #2
Mongler98
Oh boy. Check timing marks and verify belt has not jumped or missing teeth.
I would not crank it other than by hand at the crank until you can verify that the valves are in time. Timing belt is only good for like 5 years although you can get more life from them.
Any chance you can take it to a proper diesel mechanic? We have a limits of trusted mechanics I suggest you have it towed to a place that can solve this issue. Tow at the shops expense.
Old May 27th, 2020, 09:45   #3
coh
Too late for that. It didn't happen in my possession so I have no idea how many times he tried to start it. I'm setting up towing right now.
Timing belt was replaced more than 5 years ago though I'd have to check my records to see exactly when. Hopefully it's not that. Glowplug light was coming on so doesn't appear to be a 109 issue.
Old May 27th, 2020, 10:06   #4
Mongler98
The puff of black smoke is the only reason I suspect timing. Hope it gets sorted.
Maybe this will be a good silver lining of finding a good diesel mechanic in your area
Old May 27th, 2020, 10:06   #5
miningman
TDI(s): 2003 Golf
yeah sounds like jumped timing to me as well. And without stating the obvious , you cant trust whatever this inexperienced mechanic tells you.
miningman is offline   Reply With Quote
Old May 27th, 2020, 10:16   #6
Vince Waldon
Vince Waldon's Avatar
There are a ton of things it could be besides skipped timing... no way to know until you get it to a mechanic that has relevant diesel experience, or start to look into it yourself directly and in person.
Air/fuel/timing/compression. Turbo doesn't come into play till after the engine is running so unlikely the cause of a no-start. Glow plug light on/off is a good indicator for relay 109's health... car won't need glowplugs themselves to start though.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old May 27th, 2020, 10:29   #7
eddieleephd
Fuel Economy: 38mix / 47@70-75
My first are verify timing because you want to be sure.
Relay 109 and the crank sensor that so many seem to have going out these days...
Sent from my moto g(7) power using Tapatalk
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, Bosio DLC 1019's PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is online now   Reply With Quote
Old May 27th, 2020, 11:37   #8
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Check if any of the big pipes have come loose. Handy job for a lift, remove lower engine cover.
Old May 27th, 2020, 11:46   #9
dogdots
dogdots's Avatar
TDI(s): None
Anti-shutter valve dogbone broken allowing flapper to remain closed maybe?
Non VW: 2019 F150 4x4, 2019 Hemi Trailhawk, 2011 BMW 335D, 1977 MB 280SL
www.kansascitytdi.com
dogdots is offline   Reply With Quote
Old May 27th, 2020, 12:05   #10
coh
He's not inexperienced, but he does not work on diesel engines (I use him for brakes mainly). Well, I guess you could say he is inexperienced when it comes to diesel engines but he should still be able to report effectively "what happened" even if he has no idea why.
Anyway, it's on the way to the dealer as there are no other TDI gurus within a reasonable distance. Wish me luck. Will report back when I know something. And thanks for all the suggestions, if it happened in my possession I would have looked things over and checked on the anti-shudder valve, pipes, timing belt, etc.
Old May 27th, 2020, 12:13   #11
03Wagn
Originally Posted by coh View Post
Anyway, it's on the way to the dealer.
Good luck!
03Wagn is offline   Reply With Quote
Old May 27th, 2020, 12:39   #12
coh
Originally Posted by 03Wagn View Post
Good luck!
I don't have a good feeling about it but maybe I'll be pleasantly surprised. I've used the dealer for other work in the past but never anything this potentially serious.
Old May 27th, 2020, 14:33   #13
eddieleephd
Well don't let them tell you something crazy. Ask about the things we mentioned before they do any work.
Old May 27th, 2020, 15:39   #14
csstevej
No chance it was scanned for codes before it went to the dealer?
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is online now   Reply With Quote
Old May 27th, 2020, 17:48   #15
1.9ZOOK
1.9ZOOK's Avatar
TDI(s): ALH Samurai
Fuel Economy: pending
Whenever I stall my ALH, I have to pull the 109, put it back in and it starts right up.
But it never smokes so something else is going on as mentioned.
1.9ZOOK is offline   Reply With Quote
Jetta stalled while idling, won't start Later TDI 101 15 April 18th, 2011 13:03
Help! TDI stalled and won't start. negreac VW MKIV-A4 TDIs (VE and PD) 5 August 19th, 2010 06:37
Engine Stalled, Now Won't Start. Please Help... Big Jimmy VW MKIV-A4 TDIs (VE and PD) 21 January 27th, 2010 07:20
stalled and now won't start massey860 TDI 101 16 March 22nd, 2009 20:38
Won't start after it stalled out. dmulert VW MKIII-A3/B4 TDIs 4 July 27th, 2007 09:54
Page generated in 0.15465 seconds with 10 queries
[Output: 126.72 Kb. compressed to 106.10 Kb. by saving 20.62 Kb. (16.27%)]
