Old March 18th, 2020, 03:44   #1
ticaf
Default Timing Belt Change
I'm planning to change the timing belt/water pump myself.
Anybody has done it themselves ? any gotchas ?
I have the service manual and youtube videos, does not seem very difficult.
Is the kit from IDPARTS any good ?
ticaf is offline   Reply With Quote
Old March 18th, 2020, 04:14   #2
Lightflyer1
Lightflyer1's Avatar
It isn't hard but it is kind of an exact science. IDParts is probably one of the better places to get your kit from. Follow the directions and use the proper tools and you shouldn't have any problems. Don't deviate and go off on your own though.
Old March 18th, 2020, 08:08   #3
ticaf
iDPARts is much cheaper than OEM. Any reason to go with OEM?
Old March 18th, 2020, 08:21   #4
Lightflyer1
By OEM you mean the dealer? IDParts sells quality kits and I would have no issues buying from them and have many times. I think many of their parts are OEM sourced parts or excellent secondary mfg's.
Old March 18th, 2020, 09:55   #5
ticaf
sorry, I meant "Genuine VAG parts" . VAG parts seem to run double what IDPARTS asks. are we just paying for the name or is it actually better?
Old March 18th, 2020, 10:47   #6
Lightflyer1
Call and talk to IDParts. I think you will find that they carry "Genuine VAG parts" as well as others. As I said I would have no problems with anything they have for sale. They are a participating member here and have always provided me with excellent service and parts over the years. Many others here could say the same thing.
Old March 18th, 2020, 11:00   #7
DivineChaos
you can do it without pulling the engine mount.
DivineChaos is offline   Reply With Quote
Old March 18th, 2020, 18:23   #8
ticaf
how ? lift up the engine just enough to pass the belt and rest it back ?
Old March 18th, 2020, 20:26   #9
DivineChaos
it only has to be pulled to get the tensioner off. well if the stud is pulled it can save you an hour. 12 minute mark https://www.youtube.com/watch?v=881JtT3HMPs
here is another good one. https://www.youtube.com/watch?v=19PgrQc7wkI just skip the engine mount removal. you do need some special tools. crank retainer, cam and hpfp pins, tensioner pin, and a spanner wrench. also a good time to replace your coolant.
Old March 19th, 2020, 04:41   #10
turbobrick240
turbobrick240's Avatar
It's not difficult at all on the commonrails, just lock everything down as needed and follow instructions . Removing the tensioner stud is absolutely the way to go. Safer, faster, better.
Old March 19th, 2020, 06:01   #11
ticaf
But my car is a mk7 with CRUA engine. Engine mount has to go in order to remove the belt.
Old March 19th, 2020, 12:56   #12
740GLE
the timing system is about 90% of the same (different water pump), plus you don't have the booster fuel pump as the Gen1 cars that needs to be splayed out of the way.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old March 19th, 2020, 15:03   #13
adjat84th
adjat84th's Avatar
Motor mount has to come off, you can't pull the stud like on the CKRA.
I've pulled mine when I did the CP3 fuel pump. You can watch the video from myturbodiesel.com and it's almost the exact same. The cam lock procedure is slightly different so pay close attention there in your manual. The crank lock, cam lock from previous CR timing belt tool kits work here as well.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old March 21st, 2020, 19:12   #14
ticaf
a few questions:
1. what is the preferred method to support the engine ? (from top or below)
2. it is not very clear how to remove/reinstall the lower belt cover, there is some kind of breakable tab ?
3. the camshaft sprocket central bolt has to be loosened, then retightened using the counterhold spanner. torque spec is 100NM, how easy/hard is it ?
4. to loosened/retorque the high pressure fuel pump sprocket central bolt, is it necessary to counterhold on the camshaft sprocket with the belt on ?
thanks for any input.
Old March 21st, 2020, 20:40   #15
Nuje
Starts on page 105 of the ErWin "Engine Mechanical, Fuel Injection and Glow Plug" manual.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Timing Belt Change. Starts perfectly, But no power and can't advance timing further. airman1 VW MKIV-A4 TDIs (VE and PD) 7 February 19th, 2014 08:10
Timing belt change-can I drive for a week w/o adjusting the IP timing vtx531 VW MKIV-A4 TDIs (VE and PD) 21 March 9th, 2012 14:02
Need advice re broken serpentine belt 300 miles post timing belt change rgshredder VW MKIV-A4 TDIs (VE and PD) 44 August 18th, 2010 21:41
Golf TDI TIMING BELT CHANGE / TIMING BELT PINS POSITION grahammarkwoods Golf TDI Picture Gallery 3 October 9th, 2007 08:56
First timing belt change at 81K miles. Belt fine? teleskier VW MKIV-A4 TDIs (VE and PD) 5 August 8th, 2005 06:13
Page generated in 0.17682 seconds with 10 queries
[Output: 124.96 Kb. compressed to 103.87 Kb. by saving 21.08 Kb. (16.87%)]
