Old November 11th, 2019, 11:04   #1
AJ1
TDI(s): Vw golf
Default 2005 VW GOLF TDi won't start
Hi all, I'm a newbie on here so please excuse me if this question has been asked before.
I have had some medical problems recently and disappeared for a short period. I left my car to be collected by family but instead the police retrieved it by smashing the passenger window. This didn't cause any problems as my family went and drove my car back without any issues and parked it up at my daughters. She said the alarm kept going off so just kept the car unlocked. I went to collect it 5wks later and it was dead as a dodo. We have tried jump starting it, even changed the alternator and have done all of the suggestions on here of holding battery leads together, using both keys, holding left and right etc. All the dash and lights etc are working but there is absolutely nothing from the engine on turning the key, we can though hear a quiet rapid ticking noise. We don't believe it is the alarm or immobiliser as these lights are not staying on on the dash. Any suggestions will be greatly appreciated as I am totally housebound without my car.
Many thanks
AJ
AJ1 is offline   Reply With Quote
Old November 11th, 2019, 14:50   #2
jokila
jokila's Avatar
Fuel Economy: 52/45/40
So you are saying it won't CRANK over. Manual or auto trans?
Immobilzer is not the problem because that only invokes to keep your engine from running. You don't even have that yet.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod | Homelink visor
VCDS-HEX/CAN available Houston metro area.
jokila is offline   Reply With Quote
Old November 11th, 2019, 15:32   #3
P2B
P2B's Avatar
In my experience you can't jump start a diesel with a completely dead battery immediately, you have to connect the jumper cables and run the other vehicle at a high idle for 10-15 minutes before trying to start. Use heavy duty jumper cables.
The fact you have dash lights working but only a ticking sound when turning the key to start suggests this may be the issue.
Simon
Jettas for 35 years, TDIs for 16.
2003 Silver Jetta TDI GLS 300K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 230K PP520 RC2
2000 Canyon Red Jetta TDI GLS 560K
P2B is offline   Reply With Quote
Old November 11th, 2019, 15:43   #4
miningman
TDI(s): 2003 Golf
I would put a battery charger on it for a few hours......... in my experience booster cables are not all they're cracked up to be.
miningman is offline   Reply With Quote
Old November 11th, 2019, 18:26   #5
Tdijarhead
Check the short thick copper wire on the starter, they have been known to go bad and when you try to start the car everything lights up and sounds as normal, but nothing happens when you turn the key past glow.
Also as has already been said a weak battery is possible to.
Tdijarhead is offline   Reply With Quote
Old November 11th, 2019, 23:48   #6
drucifer
If no battery charger just remove battry and take it to the parts store to have it tested and charged. Maybe it's a US thing free testing and charging.
drucifer is offline   Reply With Quote
Old November 12th, 2019, 01:43   #7
AJ1
TDI(s): Vw golf
Thanks all, no it won't crank over and have had heavy duty cables from a diesel smax for 20mins and more, just dash lights and all other lights etc
Old November 12th, 2019, 01:43   #8
AJ1
TDI(s): Vw golf
Could it possibly be the starter relay?
Old November 12th, 2019, 10:02   #9
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Any chance rodents have established a new civilization under your bonnet, using your wiring to construct homes, parliament buildings, factories, cafés, and so on?
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is online now   Reply With Quote
Help, 2005 golf stalled and won't start sparkyk VW MKIV-A4 TDIs (VE and PD) 26 November 5th, 2014 19:44
1999 VW Golf TDI Won't Start TDIGOLF99 VW MKIV-A4 TDIs (VE and PD) 5 May 14th, 2012 09:24
2005.5 TDI won't start kpiazzisi TDI 101 17 December 1st, 2011 16:32
2000 VW Golf TDI WON'T START adamtrax TDI 101 4 June 14th, 2007 09:18
My Vw Golf 2000 Tdi won't start igabriel99 TDI 101 4 November 30th, 2005 15:37
Page generated in 0.15804 seconds with 10 queries
[Output: 88.23 Kb. compressed to 75.37 Kb. by saving 12.86 Kb. (14.57%)]
