Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Old October 26th, 2019, 05:23   #1
dervdave
dervdave's Avatar
Default Diesel Innovation
https://techxplore.com/news/2019-10-diesel-humble.html
dervdave is offline   Reply With Quote
Old October 27th, 2019, 12:48   #2
Lightflyer1
Lightflyer1's Avatar
I sent Sandia National Labs and Paul Miles a letter asking about what it would take to make something like this to retrofit the dieselagte involved cars with this technology. The government should take some of the billions they collected in fines and pursue this. Huge PR and some environmental gain to be had here.
Old October 27th, 2019, 13:24   #3
gulfcoastguy
The problem is that a majority of the world will no longer trust the operators to continue the nitrogen compound control process when no one is looking.
gulfcoastguy is offline   Reply With Quote
Old October 27th, 2019, 15:05   #4
Lightflyer1
What does that mean?
Old October 27th, 2019, 15:34   #5
turbobrick240
turbobrick240's Avatar
Sounds promising. If it works out, the tech will appear in new vehicles, ships etc. quite awhile before any significant retrofits happen.
Old October 28th, 2019, 21:30   #6
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Default Sandia Natl Labs develops a simple modification that greatly reduces soot emissions
An engine innovation first conceived and tested by Sandia National Laboratories has attracted the attention of big business because of its potential to cost-effectively reduce emissions of soot and nitrogen oxides, encourage the use of renewable fuels, and maintain or improve engine performance.
Ducted fuel injection, developed by Charles Mueller at Sandia's Combustion Research Facility, is able to fine-tune the fuel-air mixture in an engine to the point of eliminating between 50 percent-100 percent of the soot depending on the engine's instantaneous speed and power level.
https://youtu.be/1dijtRUZeLw
Old October 28th, 2019, 22:27   #7
Lightflyer1
Looks good. Thanks for finding that!
Old October 29th, 2019, 12:00   #8
wxman
TDI(s): Other Diesel
In a related potential technology advancement for the control of NOx emissions from diesel engines while reducing fuel consumption at the same time:
Eatonís Cylinder-Deactivation Technology Helps Commercial Vehicle OEMs Meet Upcoming Emissions Regulations
wxman is offline   Reply With Quote
Old October 29th, 2019, 12:30   #9
TDIMeister
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
I've been a proponent of cylinder deactivation for Diesels for a long time now, but the mechanisms for fuel savings and emissions benefits are different than for SI engines. As noted in the above article, the main benefit is by deactivating some cylinders, the remaining ones operate at relatively higher load; this much is in common with SI engines, but without an intake throttle, Diesels don't get the fuel economy increases of reduced pumping losses. Rather, the main benefit is that the EGT of the harder working firing cylinders is higher, therefore keeping aftertreatment systems at the temperatures needed for effective function. CDA by itself doesn't do too much for fuel economy, but small improvements can be realized when implemented with variable valve actuation/timing. Fewer DPF and SCR regens are other benefits.
http://forums.tdiclub.com/showthread...92#post3505792
Old October 29th, 2019, 13:17   #10
Lightflyer1
Cylinder deactivation sounds way more complicated and involves more moving parts than the ducted fuel injection, which seems to have no moving parts and is fairly simple once developed and installed. There were some gas engines a ways back that did this (CDA) and IIRC they suffered a miserable end.
Old November 7th, 2019, 05:53   #11
Powder Hound
Powder Hound's Avatar
Don't write CDA off so quickly. Just because it failed earlier doesn't mean that improved implementation won't realize more of the theoretical gains. There are lots of things that didn't work so well the first time it was tried, but later efforts worked very well.
Cheers,
PH
Old November 7th, 2019, 13:24   #12
Matt-98AHU
Matt-98AHU's Avatar
Fuel Economy: Depends on which TDI :)
Wow, the ducted fuel injection principles are awesome. Just a simple physical item placed around the injector more or less (and the injector itself I'm sure is altered to have a spray pattern that better lines up with the ducts).
The challenge with retrofits is there typically is very minimal room to anything else in the combustion chamber as it is. Valve reliefs are machined into the top of pistons because if they weren't, pistons would hammer the valves while the valves are closed... I found this out the hard way when I was attempting to figure out what was going on with this odd merging of two engines. Someone put a BEW bottom half with an ALH top half. BEW pistons do not have valve reliefs machined into them because the valves in the BEW head are designed to recess into the head a little. ALH and non-BEW PD heads have the valves protrude ever so slightly from the bottom of the head.
That engine was in fact hitting the valves with the valves closed... That's how little room there is.
Now, there's a smidge more room in commonrails with the wider combustion bowl and compression down to 16:1 instead of 18 or 19.5:1, but still, that ducting would have to almost be partly recessed back up into the head a little and require a different injector who's tip might not protrude into as far into the chamber as they currently do for many road-going diesels.
Where there's a will, there's a way I'm sure.
I'm not too worried about retrofits, but always good to see signs of relatively simple solutions that could kick diesel technology to the next level and maybe even simplify emissions aftertreatment systems.
Much more integrated-into-the-casting designs will eventually result, I'm sure. Just looking at the video of the flame fronts and seeing the chart of normal diesels, A/F ratio and the curve between soot and NOx generation and the much lower and nearly flat line of the ducted setup, hugely, hugely impressive difference this makes, especially for how simple a device it appears to be.
I suspect this may also have a very noticeable increase in efficiency too. I would not be surprised to see astounding differences in how little fuel a diesel uses with such a system.
I will be very, very curious to see the first OEM that goes into production with this and see how well it performs not only in terms of emissions, but power and economy as well.
Sole Proprietor, Diesel Autowerks in San Anselmo, CA. One man operation, email is preferred method of contact: email me with inquiries for service.
Matt-98AHU is offline   Reply With Quote
Old November 7th, 2019, 13:25   #13
Matt-98AHU
Matt-98AHU's Avatar
Oh yeah, there's a video here:
https://www.youtube.com/watch?v=1dijtRUZeLw
Old November 7th, 2019, 13:36   #14
Lightflyer1
Just imagine no more regens and getting rid of most of the exhaust after treatment system. A huge cost savings on these cars and lower emissions more than likely plus a boost in power maybe. Sounds like a win/win. Only problem is we will probably never see it.
Old November 8th, 2019, 13:40   #15
GoFaster
Moderator at Large
It's rather unlikely that a modification like this would reduce regulated emissions enough to eliminate aftertreatment, but it can give the aftertreatment an easier job.
Now, where to put such a physical gadget into an automotive-scale cylinder head surrounded by valves and glow plug ... I have my doubts. Still, even if this only works on engines the scale of locomotives or ocean-going vessels, it's a good thing.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
BorgWarner develops new turbocharger to help reduce diesel emissions buckeye96 TDI News/Tech 12 July 10th, 2008 12:04
B20- ULSD cut emissions greatly NHTDI Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 January 9th, 2005 07:39
OT: Ford develops backup plan for diesel emissions dilt1 TDI News/Tech 4 December 16th, 2002 09:57
Enviro Cat Reduces diesel emissions... Gary Miyakawa VW MKIV-A4 TDIs (VE and PD) 1 January 13th, 2000 05:22
Page generated in 0.16671 seconds with 10 queries
[Output: 133.60 Kb. compressed to 111.55 Kb. by saving 22.05 Kb. (16.50%)]
