Old October 2nd, 2019, 18:27   #1
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Default Still AC problems... Next step?
So a quick history. Some years ago, I had the lovely foam-out-the-vent experience. A/C became weak and then, some time after, gave up completely. Diagnosis was that the compressor had given up. I ordered up a new compressor and evaporator(?), replaced, vacced and refilled. AC was weak so I went to a professional shop to get a drain and refill. Well, that was some good money just to be told I was bang on already. That was when I found out about the blend door foam issue. Well, time got away from me and now, maybe 4 years on, maybe 5, I got around to addressing it.
So with my blend doors all metal-taped up, I hit the AC and... it's still mediocre. I drove around the block (approx 2 miles) and the temperature never really gets down beyond kinda-cool. I got the manifold out and I'm seeing 260ish high side and 50ish low-side so the compressor is working (and 110ish off). I figured maybe in the 4-5 years, I'd lost some R34A so I tried adding a little more. It seemed to get a bit cooler but hard to tell (I should get the thermometer out). After 15 minutes, there was still some in the can.
My big radiator fan is out but I wouldn't have thought that would have affected things that drastically, especially when the engine was cold after sitting all night. I'm wondering if there's a possibility the AC guys left me over-full but hopefully they know what they're doing. Any ideas?
Richy_T is offline   Reply With Quote
Old October 2nd, 2019, 18:35   #2
ToxicDoc
TDI(s): 2001 Jetta
You need that big fan replaced/operational before you can make any calls as to what's wrong. Compressor head pressure is strongly affected by the condenser temperature.
ToxicDoc is offline   Reply With Quote
Old October 2nd, 2019, 19:54   #3
Genesis
Fuel Economy: 53/48/42
Not only will that screw up your A/C performance it will kill your compressor if you don't fix it reasonably quickly due to overheating the compressor (at which point the oil cokes and then you're done.)
Genesis is offline   Reply With Quote
Old October 3rd, 2019, 09:11   #4
Richy_T
Richy_T's Avatar
TDI(s): 2000 Jetta
Default ...
Thanks guys, that was the way I was beginning to lean too. I fixed the fan before by taking it apart. Not sure if I'll try that again or replace it. The clutch is definitely engaging so at least there's a bunch of stuff I shouldn't have to troubleshoot.
AC geniuses please step up...got a weird one. rsfeller VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 September 5th, 2019 08:42
Video: Polar FIS Step-by-step Install - 2014 JSW TDI aCab VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 22 April 25th, 2019 20:10
DrVolks.com installs a Bilstein Sport and H&R Spring combo step by step video CNGVW Upgrades (non TDI Engine related) 0 May 12th, 2016 05:22
anyone interested in posting a step by step for intake manifold removal/cleanign? gboss VW MKIV-A4 TDIs (VE and PD) 2 March 7th, 2002 07:02
Wanted: Step-by-step ways to max economy/power Pete'sGolfTDI TDI Power Enhancements 0 September 10th, 2000 22:05
Page generated in 0.14334 seconds with 10 queries
[Output: 63.94 Kb. compressed to 57.45 Kb. by saving 6.49 Kb. (10.15%)]
