Old September 14th, 2019, 06:39   #1
Darren_0203
TDI(s): 2012 mk6
Default Trans life question. Performance dmf or smf with fluid & damper, any conclusive fix?
I've stalked the forums for about 2 weeks before posting anything and I've done several hours of research so I dont have to ask to many questions about already discussed topics.
Has there been any conclusive fix to the 6spd mk6 2.0 clatter/syncro issue? I'd really like to not ruin my transmission. Does the dampner and heavier gear oil fix this or are syncros still going out with the smf setup? Am I better off getting the sach performance dmf clutch kit from darkside? Or said dmf with dampner and fluid?
My car is stock now, I'm getting a stage 2 malone tune(otw) to make it fun to drive but do intend going farther in the future
Darren_0203 is offline   Reply With Quote
Old September 14th, 2019, 08:18   #2
travis45
travis45's Avatar
I haven't heard of any one not having problems with a smf.
If we're my car I'd stick with the dmf.
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old September 14th, 2019, 09:34   #3
Yourbuddysatin
Fuel Economy: 32-35mpg
Stick with the DMF and not worry about it. No real call to go single mass.
Yourbuddysatin is offline   Reply With Quote
Old September 14th, 2019, 10:13   #4
adjat84th
adjat84th's Avatar
Yep, stick with DMF. The sachs SRE with organic disc feels just like stock and will hold around 400ft-lbs. No need for different fluid or the fluidampr with using DMF
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTB2260vklr, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
Old September 14th, 2019, 13:01   #5
Yourbuddysatin
Stock feel is key. Going from my cars to my truck is horrid. The clutch in big red is so stiff my foot hurts by the time in done driving it. Why not keep a good pedal feel and performance at the same time!!
Old September 14th, 2019, 13:39   #6
Darren_0203
TDI(s): 2012 mk6
I appreciate all the info. I've searched, reading posts from from 2012 or 2015 or whenever, I wasn't sure if this issue was ever figured out, I definitely feel better moving forward with this eventual build.
The Sachs sre kit is where I was leaning, does anyone know if the motor and tranny hold up if I get near that 390ft-lbs with more air and fuel?
Old September 14th, 2019, 13:46   #7
adjat84th
adjat84th's Avatar
The input shaft will start to flex and separate from the output shaft north of 400ft-lbs (there's a user in the UK, xjay1337 on here, that was around 430ft-lbs and was holding up for them). There's an input shaft support bracket for that, but I don't think you'll be anywhere near that power level unless you get some head/cam work and much larger turbo.
Old September 14th, 2019, 14:51   #8
Darren_0203
TDI(s): 2012 mk6
I was thinking after the clutch and eventual exhaust, getting that upcoming malone stage 4 kit, but not sure what all it comes with and how daily drivable it will be at that point. My other car is a clk55 amg with an exhaust and suspension that ive been dding since my Colorado kicked the bucket a year and a half ago so I'm used to a quick car with a stiff ride. Although I have no idea how fast a tdi golf would actually be at that 400ft-lb point.
Old September 14th, 2019, 22:19   #9
Mongler98
remember we only hear about what goes wrong here, not the millions of cars that dont have issues!
Old September 14th, 2019, 22:28   #10
adjat84th
adjat84th's Avatar
The 02q gearboxes have steel synchros (except for the first year or so after they replaced the 02m). Steel doesn't tolerate the vibrations from diesel ignition pulses that transmit through the crankshaft, that's what the DMF's purpose is. There are a couple cases where people made it past 20k miles, but that's not good enough for most people here. Taking the gearbox off and apart is not the most fun task (I've done it twice on my '15). DMF is quiet and smooth and keeps things working, it will need replacing eventually but not every oil change internal.
Sent from my Pixel 2 using Tapatalk
Old September 16th, 2019, 13:19   #11
Darren_0203
TDI(s): 2012 mk6
Are there brass or carbon syncros available for these transmissions?
Old September 16th, 2019, 18:45   #12
adjat84th
adjat84th's Avatar
Here's a picture of 02M vs 02Q synchros. At some point early on, the 02Q did have the same output shaft that was used in the 02M and therefore had brass. But after that, they went to a newer style steel synchro (cost cutting likely). I know of at least one 02Q in a 2015 GSW that was converted to brass by swapping out the 02M 1-4 gear output shaft. Some part number crunching would be necessary to see what exactly is needed, or if it's an easy swap. Finding used would be your best bet, these pieces are not cheap at all from the dealer!
Old September 17th, 2019, 09:15   #13
Darren_0203
TDI(s): 2012 mk6
Is there a tranny swap that works for this car? I ask because I got the malone stage 2 installed yesterday and while it's much more fun to drive you still have to beat it to have fun, first and second gear are so short and you have to use them to set your rpm where you need them for the next gear(hopefully I said that in a way that makes sense). Maybe that's how little hatchback manual cars have to be driven, it's been awhile since I had one. The amg is effortless in the way you drive around and hammer down, it doesnt feel at all like your beating it to death, maybe I'm used to that, idk
Is there any aftermarket syncros or kits?
It's my dd so I dont want to have it apart for months.
SMF vs DMF a good SMF?? ENG VW MKIV-A4 TDIs (VE and PD) 13 March 3rd, 2013 08:36
Dmf or smf johnjames1234 TDI 101 4 August 15th, 2012 08:18
Looking for the TDIClub DIY to change 01M trans fluid to fix sketchy shifts dubCanuck1 TDI 101 2 January 20th, 2011 11:54
Trans fluid question..... Keyser_Soze VW B5 Passat TDIs 15 November 17th, 2009 20:46
SMF & DMF performance comparions. UncleFester TDI Power Enhancements 10 February 21st, 2007 04:02
Page generated in 0.15699 seconds with 10 queries
[Output: 115.79 Kb. compressed to 97.33 Kb. by saving 18.46 Kb. (15.94%)]
