Old March 20th, 2003, 04:47   #1
kell3
Fuel Economy: 47 40 38
Default TDI LOST POWER
i have a 99.5 jetta tdi with 82,000 on it and it loses power going up hills it dosent do it all the time but it dose it alot pleas help!!!!!!!!! <font color="blue"> </font>
kell3 is offline   Reply With Quote
Old March 20th, 2003, 04:53   #2
VelvetFoot
VelvetFoot's Avatar
It is probably your maf.
VelvetFoot is offline   Reply With Quote
Old March 20th, 2003, 08:26   #3
GoFaster
Moderator at Large
Read the TDIFAQ troubleshooting section. There are many potential causes, and further investigation WILL be required to identify and/or rule out potential causes.
Old March 20th, 2003, 10:57   #4
kell3
how do i tell if its the maf
Old March 20th, 2003, 18:13   #5
VelvetFoot
VelvetFoot's Avatar
First, you should read the tdifaq above on loss of power; really.
Here's my opinion:
If your power does not return, say if you are on a hill, when you turn off the engine and then restart, then it likely has something to do with your intake. Your intake could be blocked or it could be your maf. I would examine the egr valve by removing the clamp at the valve, pulling the hose, and looking inside. If it is really choked with black gunk, that could cause your loss of power. If you remove the electrical connector to the MAF, and a good chunk of your power returns, then I would say it is likely your MAF. (Note that the CEL will light. It should eventually go away after it is hooked up again, but I'm not sure when or indeed if it will without getting it cleared.)
Old March 22nd, 2003, 07:04   #6
kell3
it was the maf so i unpluged it for now thanks
Page generated in 0.17732 seconds with 9 queries
[Output: 67.70 Kb. compressed to 58.88 Kb. by saving 8.83 Kb. (13.04%)]
