BakoTDI
So, I got a fog light wiring kit from Ebay with fuse and relay and even though the terminal ends were not right, I was able to splice on the VW connectors from wires that I got from the JY.
So considering this diagram, I connected the wire to slot #8 on the switch harness, like this:
This corresponds to the NL pin on the actual switch shown here:
Then, I connected the lamp wires to the #2 slot on the headlamp plug (which corresponds to the pin for the black wire on the last picture):
The plug itself now looks like this and it corresponds with the pin that goes to the connector of the fog lamp.
With those wires in place, I connected the ground to a spot under the battery tray, and when I connect the power cable to the positive post on the battery, one of the fog lamps (left side) comes on. The other one (right side) comes on when activating the fog light mode. When the fog light mode is turned on, the first one (left side) turns off.
This is what the inside of each of the headlamp connectors look like (identical):
I am at a loss here and I cannot figure out what the heck is going on. I appreciate your help.
Thanks guys!
Thanks guys!
